Question about Hotpoint TDL15 Electric Dryer
How to replace bearings in hotpoint tdl 15 - Hotpoint TDL15 Electric Dryer
Change hotpoint wmd 962 g uk drum bearing
Hotpoint dont sell the bearing for WMD962 seperately. You have to replace the whole drum unit.
Dec 01, 2012 | Washing Machines
Hotpoint TDL 52P trips RCD at fuse box when switched on at socket
hi martin it sound like bad earth this could be anythink check the plug for loose wire check the socket for loose wires if check motor wire in the washer also check circuit board connections if all wires are ok you could have a faulty motor hope it helps
regards
shaun
Nov 14, 2011 | Washing Machines
Hotpoint TDL 14 Dryer. Motor is working but drum not turning?
Remove the top cover and check to see if the belt is o/k, or could be collapsed rear bearing, remove the rear cover and check the drum bearing.
Nov 22, 2010 | Hotpoint Dryers
Hotpoint TDL 31. Seal between drum and door seems worn
Yes espares.co.uk will have parts and advice, sounds like you could have bearing problems...if its noisy on spin....
Apr 08, 2010 | Dryers
Smoking tuble dryer - hotpoint aquarius tdl-54
Hi, the part is called relay. If its smokey, is short-circuiting. Find the info at the back of your HP drier, and get the part replaced.
Cheers
Feb 19, 2009 | Dryers
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Hotpoint Aquarius Tumble Dryer TDL 31
Replaced with a new unit as not cost effective to repair.
Feb 16, 2009 | Hotpoint TDC32 Electric Dryer
Hotpoint TDL 52P tumble dryer stopped working. When switched on just get a high pitched electrical buzz and the drum does not spin
Sounds like a broken drive belt.
R emove top cover and check the belt.
I t should be round the drum, check toi see if it is still tight..
Nov 27, 2008 | Dryers
Hotpoint TDL15 Electric Dryer Logo
15 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
