Question about Music
Technics sa dx 950 sound goes off after playing 5-10 minutes
I have a Technics PR-305 Digital Piano. I turned on the power it worked when i played it, the next time I turned on the power it didn`t work, can the Electronic board be repaired to work again?
Your best bet would be to contact Technics customer service to locate the best repair shop in your area and to check on the availablity of parts for your specific model.
Jan 06, 2016 | Music
I Have a Technics PR-305 Digital Piano that I have and really like. I went to play on it on October 12th. Certain notes with different chords weren`t sounding.
it can be repaired or replaced if the boards are still available
Take it to an authorized service to have it repaired and failing that some shops that repair micro wave ovens have the technical ability to repair items of this nature
may be a good radio technician or radio repair shop could also do the repair as it is basically an electronic ( wireless/radio) that is controlled by keys
Oct 14, 2015 | Music
Hi I have a Technics PR-305 Digital Piano, that I had since the fall of 2001. I went to play on it on it today Some of the notes in the chords weren`t sounding.
Sometimes the contacts under the keys get dirty and must be cleaned. To do this you have to disassemble the keyboard,
carefully remove the PCB under the whole keyboard, locate the not sounding notes, remove tre siliconic stripe with the contact and gently clean the inside black conductive rubber pills with a cottonfioc and alcool.
Also clean the contacts on PCB.
Oct 12, 2015 | Music
Thomas playmate color glo organ series 1200
This is not one of the newest organs around. The organ still could have real switches. Like silver threads touching when a key is pressed. sully some oxidation on these contacts should not be noticed while playing, but if you can reach the contacts, try some Contact cleaner on the contacts like Deoxit in the US and Kontact 60 in Europe.
Jul 13, 2014 | Music
Technics organ will not play
Need more info.... using line out or does it have built in speakers, make sure if it uses an ac power adapter that it is the correct one (AC vs DC output and voltage\amp rating makes a difference). Is it moved often, was anything dropped or spilled on it, etc? Age... model number and you say organ I'm guessing it's actually an electronic keyboard?
Jul 04, 2013 | Music
How to fix my amplifier head??
Flick your finger nail against the preamp tubes. This will tell you if any are microphonic which most likely the case. It usually takes a few minutes for them to begin squealing.
Jul 10, 2017 | Behringer Bugera 1990 Classic 120W Tube...
Music Logo
13 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
