Question about Simpson Garden
My washing machine will not fill up at the beginning of a cycle. You can hear it filling up but the tub is not filling with water. It is a simpson esprit 500.What could be the problem?
  • Simpson Master
  • 15,557 Answers
The drain hose is too low and water is running right out of it down the drain.
Posted on Apr 23, 2014
My top loader Simpson ezi set washing machine over fills what can I check to get it working normal again
check the small tube to the level pressure switch
check the switch is working
check/replace the water control solenoid / diaphragm
tests are
with out clothes
select a low level wash
listen as the water flows in
when the tub is about 1/2 full the water solenoid shouf make a clunk sound and the water cuts off
at the same time the wash cycle begins
if the water comes right up and there is no solenoid sound then check the small tube or the water level switch
if there is the sound but the water continues replace the diaphragm in the solenoid
Nov 04, 2016 | Simpson Washing Machines
Hi, my simpson eziset 950 when filling with water doesn't stop filling when the cycle starts. Water overflows all through the washing cycle. When I turn the tap of it stops filling.
there is a small tube running from the bottom of the tub up to a pressure switch in the control panel that is set by what ever wash level you want
when the pressure in that tube exceeds the pressure set by the knob it does 2 things
it turns off the inlet water solenoid to stop water coming in and then starts the wash cycle
as it is starting the wash cycle , it indicates that the stop solenoid for the water inlet is either still getting power or the stop valve is faulty
try replacing that water control valve first
Jan 31, 2016 | Simpson Washing Machines
My simpson eziset 7.5 washing maching does not hold water
Be sure that the drain line is above tub level.
Dec 04, 2012 | Simpson Washing Machines
Beginning of wash cycle starts agitating instead of filling w/water.
the water pressure/level switch contacts are welded together,usually the load selector switch for the amount of water lets it fill to a determined water level and the water level creates pressure in a tube from the tub to this switch and stops water fill and starts the wash agitation cycle,replace this switch inside the control panel
Mar 19, 2011 | Whirlpool Washing Machines
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer fills up only half way but water keeps trying to fill tub
That is because the water level switch get stuck when water level reaches that particular point.
The water level switch is activated either by a floater sensor or by a membrane sensor that detects water pressure/volume, depending on the model.
On washing machines it is usually a membrane switch, and that is faulty on your machine.
Feb 20, 2009 | Admiral AW22 Top Load Washer
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Garden Logo
118 people viewed this question
Top Simpson Garden Experts
John Trevino
JOHN LAPIER
ray gallant
Are you a Simpson Garden Expert? Answer questions, earn points and help others
