Question about Emerson Televison & Video
Black line through middle of emerson led tv screen
Water got into the bottom of tv near the onboard controls(power switch, volume controls). The buttons stopped working for a bit but started to work again but their is a black line going from top to bottom in the middle of the screen about inch to inch and half thick
    Top Expert:
  • Emerson Master
  • 74,482 Answers
Sounds like panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Screen-shots to defective LCD panel are given. You can compare it to that of your TVs'.
Posted on Apr 23, 2014
  • 5 Answers
SOURCE: hyundai 42inch plasma tv
Had the same problem.  Was quoted $800 to fix.  Searched the internet for 6 months and found this thread on avforums.com
http://www.avforums.com/forums/showthread.php?t=462873&highlight=black+line+on+plasma&page=4
Read through all the posts.  Very simple fix, but you have to have some mechanical inclinations or you can cause more problems than you started with.  I was up to 5 of the black lines, but decided to attempt the soldering these guys did and fixed it all for the cost of a soldering iron!  Even if you decide not to attempt it, it gives you somewhere to start to tell a technician.
Posted on Oct 16, 2007
circuitcity
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
SOURCE: I have a Phillips 42
I wanted to share my solution to this problem. Not only is it an easy fix (aside from taking the tv apart) but it also explains some of the strange methods I've read that have worked, such as taking out padding from behind the boards or putting a magazine under one side and even tapping on the tv for a temporary fix.
Granted its only been a few days of it working but I tell you this....It's not done the half black screen once! And trust me when I say it was doing it constantly.
Ok so first off the problem definitely lies in the upper/lower buffer boards. On the model mentioned by the OP (same model I have) it's located on the same side as the power button (right side when you are looking at the tv).
Ok so you've got the tv openned face down on a non static surface. Btw I was shocked at how many youtube videos I found of ppl working on their tvs while its laid flat on their sofas!
When you are looking into it you will see on one side there are two vertical boards hooked up to another board more towards the center. These two boards are your upper and lower boards that provide the upper and lower picture. The problem I was having was in the lower section of the tv going black so obviously that corresponded to the lower board. (They are labelled upper and lower if you look closely)
So here is what I did:
I noticed the lower board was not sitting flush so I unscrewed the one screw on the bottom and noticed how much of a gap was in the screw hole. The problem was it was screwed down in such a way that one of the connections going to the main board was not making it's proper connection. So I just gave it a little push towards the center, held it, and screwed it back down.
That's it! It's fixed now. No need for replacing anything. Just poorly drilled holes and a few things not lining up correctly!
So hopefully anyone else that's having this same problem might have some luck in using this fix. Good Luck!
Posted on Mar 15, 2009
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
  • 1623 Answers
SOURCE: Techwood TWP4210 Plasma tv
a resistor has developed a dry joint or failed on the data connectors of the plasma panel,there are eight at the top of the plasma. An easy fix if you know what youa are doing,
Posted on Nov 06, 2009
How can I fix volume control
How do I stabilize volume on a television? : hometheater
https://www.reddit.com/.../how_do_i_stabilize_volume_on_a_tele...
RedditAug 31, 2014 - We have a Samsung Smart TV - 52". My mom is a hardcore movie watcher, and I have very sensitive hearing. It's a constant battle because I'm ...Missing: lc320slx
Funai Emerson LE220EM3 Owner's Manual - ManualsLib
www.manualslib.com > ... > LCD TV > Emerson LE220EM3
Emerson LE220EM3 LCD TV pdf manual download. ... LCD TV FUNAI LC320SLXService Manual ... Model # Screw dimension •. ... Tv, Switching On Your Tv And Putting It In Standby Mode, Adjusting Volume, Switching Channels ... Clock setting tostabilize the PC screen and Phase Canadian French rating, then press OK.
Nov 26, 2015 | Sylvania Televison & Video
Why does my TV show discolored vertical bands and can I fix it at home?
The T-con board controls the picture elements on the screen. Usually replacing this board will solve the problem. If you can touch the screen and the lines disappear and later reappear, that says the screen itself is defective. The only fix is to replace the entire screen.
Oct 10, 2015 | Hisense F42K20EGB 42" LED 1080p 60Hz
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jun 27, 2015 | Emerson Televison & Video
Emerson EWF2004 has a horizontal line in the middle of screen some color can be seen the rest is black. I disconnected cable, unplugged tv line remains how can I fix it?
This sounds like an analog TV. If so, the vertical oscillator or vertical drive output needs to be fixed. You will need a schematic to do the job.
Feb 25, 2015 | Emerson EWF2004 20" TV
Trying to program dish remote to 32" Emerson HDTV
Here are the codes for your Emerson TV: 733, 632, 627, 684, 123, 537, 590, or 526
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the TV Power button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Aug 07, 2011 | DISH Network IR Remote Control
Dont know where to hook up the power and leads on the p4m80 -m4 to get power
missed placed the manual of the m935dlu motherboard having problem hooking up the panel switches the led sw, hhd sw, reset sw, suspd led and pwr sw
Jun 29, 2009 | Biostar P4M80-M4 Motherboard
Black screen with a line of the picture running
The vertical sweep generator is dead. The circuit that controls the lines being drawn from top to bottom has malfunctioned or died. This not something you can fix, you will need a professional.
Apr 02, 2009 | Emerson EWF2703 27" TV
Sony Plasma PFM 50 ci black screen
. Check blink of leds
check the 5 v control voltage.
check Ysus and Zsus board.
check Voltage sc, Vs and Voltage a .
Yareth De Matos - Venezuelan -
Mar 28, 2008 | Sony PFM-50C1 50 in. Plasma HDTV
Televison & Video Logo
110 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
