1994 Tectrix Personal Climber H-100 Model has no resistance when stepped on pedals but lights up and can hear it just spin what needs to be done.
Climber was working fine till was stepped on before turning on and just spins with no resistance. Noticed Err reading but Err reading now doesn't come on.
  • Brenda Garrett
    Brenda Garrett Apr 23, 2014
    1994 Tectrix Personal Climber Model H-100 belongs in the category of "Stair Climber" was catagorized incorrectly for whatever reason.
  • 51 Answers
SOURCE: Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Posted on Jul 24, 2007
  • 7 Answers
SOURCE: washer doesn,t spin
two possibles here, if the drain pump is clogged and therefore the unit will not go into a spin. After pumping, it will error out and just shut off. If the pump is ok, then the motor control unit has failed.
Posted on Oct 28, 2008
localwonder
  • 6784 Answers
SOURCE: Spin cycle doesn,t work
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
Posted on May 27, 2009
  • 30 Answers
SOURCE: i need a Tectrix Personal Stair Climber repair
Testing by FixYa Staff
Please do not rate this post!
We apologize for any inconvenience.
Posted on Jul 14, 2009
  • 1937 Answers
SOURCE: Kenmore 110.23832100 post rinse cycle spin problems
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23832100
See the Whirlpool service manual for these washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Sometime spinning points to a few places.
First, Kenmore top load washers use a motor coupler to transmit power from the motor to the transmission for agitating and spinning. If the coupler is worn or damaged (the prongs on the motor or transmission shafts are broken) the machine may agitate but may not spin.
Second. These washers use a clutch to transmit power to the tub for spinning. If the clutch is worn, it may not be able to transmit all of the power from the transmission.
Third. These washers are whats called Top load, Direct Drive Neutral Drain. This means that when the washer goes into spin mode, the "neutral drain assembly" has a built in mechanical timer that allows most of the water to drain and then begins the spin cycle.
If the cams in the neutral drain assembly are broken or, as we found onours, a spring on one of the cams is broken, the machine won't spinwithout help.
Forth: These washers use a spin tube, driven by the clutch and connected to the tub with a "basket drive block" If the tabs on top of the spin tube have broken off or aren't inside the slots in the drive block, the tub may not spin.
All of the diagnostics start with pulling the cabinet.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
With the transmission out you have access to the motor coupler and clutch. Check both before proceeding.
If the motor coupler and clutch look OK, I'd pull the tub and spin tube and check the tabs on the spin tube and drive block.
If all else appears OK, the problem points to the neutral drain assembly.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Oct 28, 2009
Petal does not return like it should on tectrix climber
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I would suggest checking the the drive clutches on the transmission assembly. If they are not free spinning as they should, the pedal will not be able to return all the way up.
Sep 10, 2015 | RTO Tectrix Personal Stair Climber
Where can I find the power cord & supply for a Tectrix Personal Climber 304021 OR can anyone tell me what the AC output and amperage is for the external power supply so I can improvise.
I do not remember them having an external power supply, just a cord - does this one look like it will work?
http://www.sportsmith.net/itemform.aspx?item=P1314007&ReturnUrl=/productsearch.aspx?dsNav=N%3a10509-750001
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Nov 21, 2014 | RTO Tectrix Personal Stair Climber
Que es error 5 tectrix personal climber
Error 5, No Slack, Cybex/Tectrix Climbmax 2000/3000, 700S and 800S Steppers Probable Cause An error 5 on the Tectrix Climbmax models 2000 and 3000 as well as Cybex stepper models 700S and 800S indicates the following:
a) Test switch is in test mode.
b) Possible cut in display cable.
Corrective Action a) Adjust slack switch.
b) Inspect display cable; Replace cable if necessary.
Error 5 No Slack on Cybex and Tectrix Steppers Climbmax 2000 3000 700S 800S
Apr 10, 2014 | RTO Tectrix Personal Stair Climber
My Tectrix stairclimber powersup but will not start running
Tectrix Cybex Stepper Personal Climber Parts SPORTSMITH net
You should check your power supply for proper voltage output first. Check for at least 110v. The following video will show you how to use a multimeter.
Jan 14, 2014 | RTO Tectrix Personal Stair Climber
Parts
This cable can be ordered from our Website. Please have your exact model and serial number ready. The following link will take you to our Tectrix stepper page.
Tectrix Cybex Stepper Parts Climbmax Personal Climber 2000 3000 Model 150...
May 07, 2013 | RTO Tectrix Personal Stair Climber
I have Tectrix Personal Climber. The on/off
No I believe that switch is the problem your Tectrix PC Is part of Cybex International and their phone # is1-800-677-6544 now if they do not have this part then call National Gym Supply @ 1-800 496-7278 the Personal Climber and The Climax ( commercial unit) uses the same switch assembly.
Feb 16, 2010 | RTO Tectrix Personal Stair Climber
Need to find part numbers for bearings on a tectrix personal climber stair stepper machine
Those are always marked on the bearing shield itself. Look for a number that looks like this: RS 6802 RS or 6104 R.... it will be a letter/3 or 4 digit number/ letter combination.
Jan 10, 2010 | RTO Tectrix Personal Stair Climber
I need a Tectrix Personal Stair Climber repair manual, I believe the clutch on mine is slipping or broken
Jul 14, 2009 | RTO Tectrix Personal Stair Climber
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
