Mitsubishi WS-65511 65" Rear Projection Television Logo
Posted on Apr 23, 2014
Tv won't stay on
It turns off right after it is turned on
dERREK
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Apr 26, 2014
dERREK
Contributor
Level 1:
New Friend:
Answers
5
Questions
Helped
909
Points
13
Lamb is gone out you need to replace it with a new one
My Vizio 4K TV won’t stay turned off! No matter if I use the remote that cane with the tv, the directv remote, or the button on the tv. It will turn off for about 2 seconds and then turn right back on!...
You need to disconnect the power from this tv, then press and hold the power button down for 15 seconds to drain the charge off the circuit boards inside. Then plug it back in and start over. If this does not solve the problem you may need to have it checked out by a repairman. You should still be under warranty so report the problem and file a warranty claim.
Toshiba tv won't turn off/ stay on
Try unplugging your television for a half an hour or so. It might reset to original settings, Your problem might be input lock features. If you can get to the menu after unplugging your tv for awhile we might be on the right track. I'm just looking thru a Toshiba manual that I have.
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Philips 32" tv won't stay on
Quite possibly one of the heat sinks has come loose or a power supply cooling fan has failed.
Have you tried blowing it out using canned air?
Tv won't turn on. It turned off after a few minutes and won't turn back on. We opened it up and replaced the fuse.Didn't change anything. A friend said that it just seems to not be getting any...
does the power light flash three times slowly then stay off? If so chances are its just the CP150, cp120 and CP114 capacitors. There is the RCA repair kit by that same name available from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
My 42LD450 won't stay on! It turns on for a few seconds and works fine, then the screen flashes then comes back on, then flashes again after a couple seconds, then turns off. Rinse and repeat. Tried...
I hope that you can use the warrantee.
Otherwize, it must be possible to repair it with a fried comfortable with electronic because the problem is not permanent. This kind of problem is usually an old capacitor or a bad connection (soldering).
It would be important to check if changing the ambiant temperature fixes the problem. (I.E. move it to the seller for 2h and try..)
Regards,
4helpful
2answers
Tv has been turning off right after you turn it on then after a few attempts it would stay on now the power button on front turns green, it tries to come on but then turns off.
Sounds like high voltage power supply has gone bad. You can try purchasing new PS online and replacing yourself if handy or you will need to bring in for service.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
