The A2 pieces only have 3 sets of holes and should be 4 sets for B & C
Model: VTS-SB1304,04/14
  • 1 more comment
  • Marti Baity
    Marti Baity Apr 24, 2014
    My problem is not with MP3 or media players. I have a problem with a Gardenline double glider.
  • Marti Baity
    Marti Baity Apr 26, 2014
    I purchased a Gardenline Double Glider Model#VTS-SB1304,04/14
  • Marti Baity
    The two bottom end pieces labeled A1 & A2 should have 4 sets of holes for B/2 & C/2 to fit into them. Mine has only 3 sets of holes
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I have 390 Vts to the cond.EC2 and the voltages
What is model number of the TV and the power supply module?
Is the power supply made y MAGMEET?
The 24 vdc may not be ON because it is not getting PSON from main baord or there is failure in the power supply itself.
Please see my guides and my albums.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Posted on Mar 09, 2011
Firing order 2005 aston martin db9
Here's some excellent info
http://sccaproracing.com/files/VTS/06-vts-aston-martin-db9-0307.pdf
2.A.9.
Cylinder Firing Order: 1-7-5-11-3-
9-6-12-2-8-
4-10
May 16, 2015 | Aston Martin Cars & Trucks
Definition of special product in algebra types and example of special product in algebra
Product means the result you get after multiplying.
In Algebra xy means x multiplied by y
Likewise when you see (a+b)(a-b) it means (a+b) multiplied by (a-b), which we will be using a lot here!
Special Binomial Products So when you multiply binomials you get ... Binomial Products
And we are going to look at three special cases of multiplying binomials ... so they are Special Binomial Products.
1. Multiplying a Binomial by Itself What happens when you square a binomial (in other words, multiply it by itself) .. ?
(a+b)2 = (a+b)(a+b) = ... ?
The result:
(a+b)2 = a2 + 2ab + b2
You can easily see why it works, in this diagram:
2. Subtract Times Subtract And what happens if you square a binomial with a minus inside?
(a-b)2 = (a-b)(a-b) = ... ?
The result:
(a-b)2 = a2 - 2ab + b2
3. Add Times Subtract And then there is one more special case... what if you multiply (a+b) by (a-b) ?
(a+b)(a-b) = ... ?
The result:
(a+b)(a-b) = a2 - b2
That was interesting! It ended up very simple.
And it is called the "difference of two squares" (the two squares are a2 and b2).
This illustration may help you see why it works:
apb-amb-why.gif a2 - b2 is equal to (a+b)(a-b) Note: it does not matter if (a-b) comes first:
(a-b)(a+b) = a2 - b2
The Three Cases Here are the three results we just got:
(a+b)2 = a2 + 2ab + b2 } (the "perfect square trinomials") (a-b)2 = a2 - 2ab + b2 (a+b)(a-b) = a2 - b2 (the "difference of squares") Remember those patterns, they will save you time and help you solve many algebra puzzles.
Using Them So far we have just used "a" and "b", but they could be anything.
Example: (y+1)2
We can use the (a+b)2 case where "a" is y, and "b" is 1:
(y+1)2 = (y)2 + 2(y)(1) + (1)2 = y2 + 2y + 1
Example: (3x-4)2
We can use the (a-b)2 case where "a" is 3x, and "b" is 4:
(3x-4)2 = (3x)2 - 2(3x)(4) + (4)2 = 9x2 - 24x + 16
Example: (4y+2)(4y-2)
We know that the result will be the difference of two squares, because:
so:
(4y+2)(4y-2) = (4y)2 - (2)2 = 16y2 - 4
Sometimes you can recognize the pattern of the answer:
Example: can you work out which binomials to multiply to get 4x2 - 9
Hmmm... is that the difference of two squares?
Yes! 4x2 is (2x)2, and 9 is (3)2, so we have:
4x2 - 9 = (2x)2 - (3)2
And that can be produced by the difference of squares formula:
Like this ("a" is 2x, and "b" is 3):
(2x+3)(2x-3) = (2x)2 - (3)2 = 4x2 - 9
So the answer is that you can multiply (2x+3) and (2x-3) to get 4x2 - 9
Jul 26, 2011 | Computers & Internet
Ive got a 10x10 lawn and party gazebo made by summer rite ... do you know where to get instructions ?
Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
_1430.jpgTake
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieces to each end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with both silver metal fasteners on the #3 poles facing outwards)
Then connect each end of the combined poles to the end piece.
Now lay out the final set of poles (# 5 and 6), but only connect the #5 pole to the end piece first, all around the gazebo.
Okay, now we want to start adding the actual canopy. Start by pulling the corners down at each pole joint then velcroing the tarp underneath in the middle of the 3-4-3 combined pole.
Now it is safe to connect the next set of poles (#6) to the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each pole and then connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needed though I tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
May 30, 2011 | Camping, Backpacking & Hiking
I have 390 Vts to the cond.EC2 and the voltages output : con 4 are correct: 5 vts;12vts;standby=4.8vts. The output from con 5 is all 0 vts( normally is 24 vts for lighting). The led green is lihgting...
Mar 09, 2011 | Polaroid Televison & Video
Suondcard vga driver toshiba tecra a2-s336
hey i hope this will help..
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=download#
Jan 27, 2011 | Toshiba Tecra A2-S336 Notebook
How do i remove the key board
How to replace your Toshiba Tecra A2-S119 laptop keyboard ?
It's easy to break the flimsy keys on laptop. In order to better protect the Toshiba Tecra A2-S119 notebook keyboard, some friends, instead, use USB keyboard. But if you work outdoors, carrying a USB keyboard is not convenient. You still have to use the laptop keyboard. Once a laptop keyboard stops working, there is no option but to replace it. You can use these steps to replace the Toshiba Tecra A2-S119 keyboard.
1. Take out the battery and AC adapter, unplugged from the wall, enusre the laptop is fully powered off.
2. Remove those screws with a T-8 or Phillips screwdriver.
3. Turn the laptop back over and open it up. Check and see if the Toshiba Tecra A2-S119 keyboard is tucked under any plastic pieces. If so, find them if those plastic pieces are screwed into anything, and unfasten them as well. If not, it probably uses clamps that can easily be removed.
4. Remove the plastic pieces carefully.
5. Unscrew any screws at the top (if necessary) and remove the keyboard itself from top to bottom. You'll notice that the keyboard is connected with a thin, but wide, data cable to the system board at the bottom.
6. Disconnect the data cable attachment of the keyboard which will sever all the remaining attachments of the laptop keyboard with the laptop computer motherboard. To remove this cable, you have to just carefully pull it out from the socket to which it is attached. Then you can lift out the entire keyboard out of the laptop.
7. Take the new Toshiba Tecra A2-S119 keyboard out of the plastic and place it inside with the right orientation, attach the data cable.
8. Refasten the keyboard in place at the top.
9. If you had to remove any plastic pieces, carefully snap them back in and replace any screws you had to remove.
10. Turn the laptop over and replace all of the keyboard screws.
11. Put the laptop battery back in place and switch it on to check Toshiba Tecra A2-S119 keyboard functionality. If everything has gone according to plan, you should be ready to type away!
You have to remember that once you open up the Toshiba Tecra A2-S119 laptop computer for keyboard replacement, the warranty provided by the manufacturer stands void. We personally suggest that you do it on your own only if you are in a really desperate situation and there is no way you can get maintenance from the manufacturer. I hope this assists you. John
Jan 26, 2011 | Toshiba Tecra A2-S119 Notebook
VTS reader application
here is a link to download VTS Reader Application.
link 1
please write in detail if there are questions.
I will respond back
Apr 12, 2010 | Computers & Internet
How to mount amp
Turn your amp over and you'll see 4 holes one in each corner and you should gotten 4 v shapped pieces of metal with 2 holes each and 4 screws.....you normally have to mount them on manually. I hope that helps.
Mar 17, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Yamaha dsp a2
Check the A or B switches it could be they are turned off!
Sep 28, 2006 | Yamaha DSP-A2 Receiver
 Grubhead
Grubhead
