Question about Samsung WF337AA Front Load Washer
Samsung VRT stem from loader ( broken plastic door latch lock )
The machine wont lock and start cycle due to broken plastic insert at the latch mechinism
2 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: samsung washing machine wf431ab door lock broken
try here- https://partstore.com/Model/Samsung/Samsung/WF431ABW.aspx?SearchTerm=True
Posted on Mar 02, 2014
Door will not lock
The latch is either broken or has come loose. Check the latch to see if either applies.
Jan 03, 2015 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Door wont open on Hotpoint WM51 First Edition
This is a common and easily fixed problem. The door should NOT be opened after the wash is completed. You have to wait for AT LEAST 2 minutes to try the door, do not use force. There is a built in mechanism for most front loaders to delay the door opening, so be patient.
In your case you might have already damaged the door lock, so replace. You are lucky if the door can be opened after the lock sign goes off - otherwise you just have to change the door lock.
Click if helped.
Apr 25, 2013 | Washing Machines
Samsung vrt fl code
Check both parts of the latch mechanism. Something may have gotten stuck or the latching device may have broken
Sep 08, 2012 | Samsung WF337AA Front Load Washer
Samsung WF7700N6W1 wont start because of 'door' error, door is closed
there is a switch in the door latch that tells the unit the door is closed so it can start to operate if there is a fault or a peace of the latch has broken off the unit will read door open check the latch for any broken off peaces if it looks good replace the inter lock unit on the machine
Jun 19, 2010 | Samsung WF328AA Front Load Washer
I put some washing in my samsung J845 front loader the door will not lock before the washing can be done. my husband brought a new door latch due to the other one been burnt out and he put it back on the...
Just bang the door again until the error goes away. The door is not lined up and won't latch properly. At least that is what ours does. I usually slam the door on my machine.
Sep 29, 2009 | Samsung Washing Machines
I have the neptune front loader. The lock light wont come on and the door wont lock. During a wash cycle the water just started comming out of the door. If I hold the stop/start button manually the light...
hi there,
you have a door latch problem. the reason you can still push on the button is because this particular washer has a time delay function. i would recommend taking a look at the latch itself and possibly the wax motor that runs the latch.
Dec 04, 2008 | Maytag Neptune MAH5500B Front Load Washer
I have a front loader washing machine that wont let me open the door even though the wash cycle ended hours ago
could be a door lock problem. try hitting the door lock a couple of times, the latch could release the hook.
another solution if you have your manual, it is stated there how to open manually your door.
there is a plastic hook at the back of the switch with a ring at the end, you can pull the ring down and the door will open.
in order to get to the plastic, you need to remove the front lower panel. remove 3 screws that are holding it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Door wont open and F34 error message on our axxis front loader
This error message indicates that you have a Electrical Problem in your washing machine .
Make an attempt
  • Select PAUSE/CANCEL twice to cancel the cycle.
  • Select RINSE & SPIN, and then select EXTRA
  • RINSE (to turn off the rinse option) if there is
  • excessive water in the washer.
  • Re-select cycle and press START. If the problem
SAM ANDERSON
Sep 27, 2008 | Bosch Washing Machines
Samsung WF337AA Front Load Washer Logo
32 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
