Question about Solo 662 667 Chainsaw Muffler W/ Bolts Nice
We're can I purchase the muffler and everything that goes with it
Or what muffler assembly can I use such stihl husky what? Anybody? I was told 345 husky
    New Friend:
    Problem Solver:
  • 9 Answers
Any chain saw store should be able to get what you need. Check what kind of saw you have, model number, etc. and then use the internet to find a way to order parts.
Sthil and Husqvarna are two different brands.
Husqvanrna saws are often refereed to as Huskys
Google Search "345 Husky muffler parts":
http://bit.ly/1igUxjF
Google Search "chainsaw parts / Stihl, Husqvarna":
http://bit.ly/1gSCye7
Posted on Apr 24, 2014
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
My stihl 021 runs for 30 seconds then stalls
remove the muffler and run it after finding that it runs fine open the muffler and clean the screen inside (it is made to open to clean it)
Jun 22, 2012 | RTO Spur Sprocket For Stihl 017, 021...
How to remove Stihl 025 muffler?
You need to pull a little harder, lol.
Dec 07, 2011 | Stihl Garden
I have been told that my Stilhl F585AVRE brushcutter needs a new coil and that they are no longer available it is otherwise in very good condition so I would like to have it repaired - do you know where I...
Hi, an fs 85 coil assembly is available from any stihl dealership. Not sure who told you it is not available but they are wrong. Regards Phil.
Aug 28, 2011 | Garden
My weed eater sounds like its ready to die, looses power runs like it ca,nt get eithr gas or air
if it's an older unit start with pulling the muffler and cleaning exhaust port and spark arrestor. while muffler is off sta.rt the unit and check for improvement. if no improvement clean & adjust carb. if improved with no muffler, test again with muffler installed. if unit goes back to running poor replace muffler.
Jul 12, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
The automatic oiler on my sthil ms 390 is not working, the oil is running out of the front under the muffler instead of oiling the chain how do i fix this?
If I had an IPL we would attempt a repair but I do not, and Stihl IPLS are proprietary.
I am going to recommend you do search here:
ArboristSite.com Chainsaw thread (free to join)
http://www.arboristsite.com/forumdisplay.php?f=9
I did for "Stihl MS390 Oiler" and found many threads. This being one of the best although it does not address your exact problem.
THALL10326 and Lakeside are both Stihl mechanics. You will find them most helpful.
http://www.arboristsite.com/showthread.php?t=65495&highlight=stihl+ms390+oiler
If you do not find an answer please post your problem there. Someone there has seen and repaired what you have. I think the oil pump or connector has failed. Both are behind the inboard clutch. If internal clutch parts must be removed they have a left handed thread (tighten to remove). HTH
Lou
Jan 14, 2010 | Garden
Husquvarna 45 starts up but back fires through the carb , has new carb kit new plug and a different coil. run but back fires . run like its not getting enought gas. could it be out of time?
All things are possible. The flywheel is keyed using a woodruff key. They rarely jump time. If the new coil meets the manufacturer's specification there is no logical reason for this. If my saw, my local Stihl dealer (Husky is closer, I prefer local Stihl mechanics) wold be providing a problem diagnosis/ repair estimate. Inform any mechinic about everything you have done to the saw.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Good Luck
Lou
Nov 20, 2009 | Husqvarna Garden
What is the fuel/oil mix ration for a 345 Husqvarna Chainsaw?
Page 19 of a 2007 Operator's Manual 50:1
HusqvarnaUSA.com
06 1500198
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Husqcarna 345 and I just need to know what the oil to gas ratio should be. The maunual was loaned and lost.
Your manual can be found here:
HusqvarnaUSA.com
06 1500198
Your manual says for each gallon of premium fuel add 2½ ounces of premium 2 cycle oil. 30 minutes spent in front of the TV while reading your manual is time well spent.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few months. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Nov 06, 2009 | Husqvarna Chain Saw 20" Bar
Husquavarna 350 chainsaws
there is a spdecial tool but you dont need it. i use small flat screw drivers between drum and shoes and fit new springs with a circlip pliers
Oct 11, 2008 | Husqvarna Forest & Garden No.967012396 345...
Solo 662 667 Chainsaw Muffler W/ Bolts Nice Logo
108 people viewed this question
Top Solo Garden Experts
Jim Parker
Jim Parker
Colin Stickland
Colin Stickland
Are you a Solo Garden Expert? Answer questions, earn points and help others
