Question about Hobart D300 Stand Mixer
D300, shaft stops under load only in first speed.
I have had mixer apart three times. Every component is free and in good shape. I have replaced the spring strips in the one way clutch, but the shaft can be stopped when running in first speed by simply grabbing the shaft. Second and third speed, I have not been able to grab the shaft to see if it stops, but my cust has no complaints with second and third speeds. Slowley this is driving me crazy. Any insight would be appreciated.
  • 68 Answers
SOURCE: Whining noise in all three speeds.
There is only one bearing in the back a an A200, the rear motor bearing. Page 12 -- Otherwise I'd look for something rubbing the motor. (wire, capacitor shield) The two back side covers are easy to remove, two screws each.
http://www.hobartlink.com/extranet/extranetmanualsandcatalogs.nsf/57866D624A678E7385256CB0007232DA/$File/F-19357%20(05-95).pdf
The timer is also in the link. The part is not cheap, but easy to install.
Posted on Jun 21, 2008
SOURCE: gear problem
Cheers Bigg t for the reply, I got the mixer fixed by our local ish catering equipment supplier, they said it was a damaged fibre gear, repair cost £190 plus our transport costs to get the mixer to them.
It is now working well and making bread every morning.
Posted on Aug 24, 2008
SOURCE: d300 hobart mixer
i have a spare unit for dsale 1500.00 cdn
Posted on Oct 23, 2008
bigg t
  • 640 Answers
SOURCE: Beater mechanizim runs very slow and will not change speed
It sounds like you sheared a key in the transmission.Does any gears work?were you using 1st gear for dough?
Posted on Jan 16, 2009
SOURCE: A200-T Hobart Mixer 1st speed have no torque
Check the spring pin that locks the motor shaft to the main drive gear in the gear box. You should be able to turn the motor from the back at the cooling fins and watch the shaft spin in the gear, that is if the pin is sheared. That is a common problem. if you plan on keeping this machine for a while, i recomend that you spend a little more on a quality spring pin,
mechanictony-
good luck.
Posted on Jan 20, 2009
Do you have videos on how to fix a D300 hobart mixer transmission
I don't think they ever made a video for that.
The grease in the D300 is sticky and runny, and has to be removed out the top once the bearing plate is removed. On the top of the main shaft is the first gear cluster and a bevel gear beneath it. If necessary, use a pulley, BUT KEEP IT AS ONE ASSEMBLY.
Once it's out, the rest comes apart easily. Just lay out the components as you find them. Clean and inspect.
The first gear is made of the bevel gear as a base, a center hub with an outer ring gear, and a stepped cover on top that sits under the top bearing. Between the ring gear and the hub are 10 rollers and spring plates which bias the rollers into the shallower end of each roller seat.
You can get instructions and diagrams here.
https://my.hobartcorp.com/resourcecenter/Pages/FilterByModel.aspx
search model number d300. near the bottom of the options is form F-3492-N. That has detailed instructions for the older version.
Mar 02, 2014 | Food Mixers
Kp2671 stops and starts
It is not going to be a problem with the motor. It is going to be a chipped/damaged gear, a bent planetary center shaft pin, or possibly the planetary itself.
The first thing you need to do is take the mixer apart. You are going to have to clean of all of the gears and inspect them very closely. I recommend using paper towels and wd-40. If there is any damage, the gear will need to be replaced, in some cases the pin that sits between the worm follower gear and bevel gear can become bent, if it is, it also needs to be replaced. If all of the gears, bearings, and the pin are in perfect shape inspect your planetary assembly. In some cases the center shaft, which is pressed into the planetary can become loose, so it will still spin under no load, but as soon as you put something in the bowl it stops spinning.
Here is a link to the KitchenAid service manual. This will walk you through how to take the mixer apart, and put it back together: http://lib.store.yahoo.net/lib/mendingshed/kitchenaid6qtservicemanual.pdf
Please let me know if you have any questions, or need help with the repair.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Feb 15, 2013 | KitchenAid KSM103 Professional 5 Series...
Hobart d300 spins but slips under load
sounds like you have a sheared key in one of the gears. which speed is it slipping in or is it all 3speeds
Dec 04, 2009 | Hobart D300 Stand Mixer
How to remove key from D300 Mixer to replace stripped gear
Keys are removed using a small punch and a hammer. The punch of choice is called a ***** punch
Jul 10, 2009 | Hobart D300 Stand Mixer
My Hobart D300 mixer appears to be leaking oil/grease
Hi,I'm a hobart tech and repair these mixer's often.If you see oil in the drip cup then the center shaft seal in the transmission is worn.If there is oil near the transformer then the motor shaft seal is also bad.Hobart doesnt release their service manuals to the public but if you go to their site www.hobartcorp.com you can register for free and get a parts manual thats helpful.If you need help with the repair let me know,i can step you through it.
Mar 17, 2009 | Hobart D300 Stand Mixer
mechanictony-
good luck.
Jan 17, 2009 | Hobart A200 Stand Mixer
Problem with Hobart D300 Mixer
Sounds to me like the shifting yokes are locked up,or a broken shaft.Is there any noise?
Dec 11, 2008 | Hobart D300 Stand Mixer
Hobart d300 mixer
the main shap on this type seizes onto the bearing hub you need a shaft puller or use a jack placed under the the main shaft aand a board across the bowl lift arm and slowly jack up the shaft make sure you take off the lower mixing hub assy. first also remove as much as you can of the secondary shafts first and the shifter
Dec 03, 2008 | Food Mixers
Hobart d-300 mixer
To Whom it May Concer: At the school I work we have a Hobart D-300 Mixer. When we mix bread dough it pulls alot of current and trips the breaker. The max current draw on the name plate is 10.1 amps. I have seen the current go over 30 amps during the mixing process. Under no load the mixer pulls 7.8 amps. I dont have any information about this machine on paper and I can only go so far with troubleshooting.
My questions to you are: Is it normal for the mixer to draw 7.8 amps under no load? And is their a manual online I can look at so I can check the oil levels and make sure I do not have a low oil/needs greasing condition.
Thanks for your help and time,
Kenneth Clayton
Spartanburg Schools Dist#2
Apr 16, 2008 | Hobart D300 Stand Mixer
Second Gear
Sorry so late for the reply.When the product slows down---how slow?can you grab the shaft and stop it from moving?What product are you mixing?
Feb 05, 2008 | Hobart D300-6036 Mixer
Hobart D300 Stand Mixer Logo
138 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
