Question about LG 42PX5D 42 in. Plasma HDTV
Problem with picture and humm
Half the screen has a beautiful striped side and the other half has picture with green color.
There is also a hummm.
    An expert whose answer gotĀ voted for 100 times.
  • 317 Answers
Re: Problem with picture and humm - LG 42PX5D 42 in. Plasma HDTV Flat Panel Televisions
Call tech ...suggest y-sus
Posted on Nov 26, 2007
0 characters
3 Points
Can be T con board or the LCD panel itself . Only be able to confirm by replacing the tcon board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. Seach for TCON Board article
Mar 21, 2016 | Flat Panel Televisions
I have a Vizio SV47oxvt1a flat screen LCD TV with a video problem. Half the screen (right) half displays different colors then the (left) half. Picture is clear both sides, just divided in half.
Most likely the screen driver has failed, thay atached to the screen and not replable! ps I don't fix flat screens under 46'' any more because of price.
Aug 06, 2013 | Vizio Flat Panel Televisions
Panasonic plasma TH-42pz700 has left hand side of screen distorted
The set uses two boards to drive the screen --one for each half or side.
Different names are used like sustain or in LCD sets inverter.
Apr 02, 2012 | Panasonic Viera TH-42PX80U Plasma TV
Have 32inch vizio wife got it wet green went half white now that half is is striped with colors is it dead or not is it worth fixing
try puting somewere warm for a couple of days to dry out,try it again if still not workimg you could have it checked out to see if it worth fixing
Oct 22, 2011 | Flat Panel Televisions
Half screen showing picture other half showing color lines
This is a catastrophic and known failure of older Toshiba sets, not much you can do, try to take out a retrospective extended warranty, wait a month and claim, good luck.
Apr 19, 2010 | Toshiba REGZA 52RV530U LCD TV
Sharp 46" 6 months old see rainbow colors from left to right
Did he change the big video board?The main backlight video baord that the prob.
Oct 23, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Half of my screen will turn in to vertical colored stripes
T-con board. Check lvds cable for tight connection.
Sep 15, 2009 | LG 42LC2D 42 in. LCD HDTV
I have a 42' LG plasma that has now has a 1 1/2 inch verticle stripe on the right side. It used to come and go but now rarely goes away. Any ideas?
I believe that this could be a type of "burn in". If you watch anything with a black stripe on the sides or bottom of the screen often, then this could be the problem. My suggestion is to watch things that have no black side bars for a while (>week) and see if this eliminates the problem.
Good Luck!!
Jun 11, 2009 | LG 42PC3D 42 in. Plasma Television
Half screen activated only
When only a half screen is produced, it is usually a upper or lower buffer board, if the top half is blank then it is the upper buffer, and of course if it's the bottom half then it's the bottom buffer board
Sep 15, 2006 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
LG 42PX5D 42 in. Plasma HDTV Logo
53 people viewed this question
Top LG Flat Panel Televisions Experts
Are you a LG Flat Panel Television Expert? Answer questions, earn points and help others
