Question about Krylon Crystal Clear Spray Triple-Thick Glaze 12 oz. can
Frosted finishing instead of clear - Krylon Crystal Clear Spray Triple-Thick Glaze 12 oz. can
Clear top coat is not thick and glossy. Appear to lack luster and is a dull finish.
have you used the correct paper for prints. Photos need gloss paper not regular paper
Jan 18, 2015 | Office Equipment & Supplies
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
Water comes out from under the refrigerator every three or four days. I checked everything under. The water hose is find no leaks. The water tray under is empty. Is not a large amount of water maybe...
I dont know if you have a side by side or the freezer is on top,but thats a fairly common thing and the following is what i already wrote before what to check when it leaks like your experiencing.
SIDE BY SIDE
The water is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water draining into the pan where it will evaperate,it's pooling on the freezer floor and freezing, in many case when the floor indent is full the water will leak onto the floor.By pulling the refrigerator out from the wall,there will be a tube behind the service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
FREEZER ON TOP
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
I hope this will hepl you to fix that leak,
GENE
Aug 17, 2011 | Refrigerators
My automatic defrost freezer in my frig does not drain the water down to the drip pan. Instead the water is coming through vents inside the frig directly under the freezer. this is an older Amana. We...
If the drain isn't stopped up than the water isn't draining into the drain.
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Aug 11, 2011 | Refrigerators
Ice forming on the bottom of the freezer
The ice is from the melted frost of the defrost cycle. The drain at the bottom of the back wall of the freezer is blocked so instead of the water drining into the pan where it will evaperate,it's pooling on the freezer floor and freezing.By pulling the ref. from the wall there will be a tube behind teh service panel on the right side when looking at it from the rear,that tube can be removed and cleared,then clear the nozzle it connects to inside the freezer.
I hope this helps,
Gene
Aug 04, 2011 | Maytag 25.6 cu. ft. Wide-By-Side...
I have a frost free model FP532BDP & the water is coming into the fridge instead of out the drain & into the evaporation tray, I have taken the panel off the back & tried to run a piece of wire...
It is probably frozen. The easiest way to clear is to unplug for 24 hrs. and leave the doors open. To speed it up you need to remove the bottom and rear panel in the freezer. After getting rid of the ice keep poring boiling hot water into the hole in the drain trough under the evaporator. Soak up with a towel and repeat till it clears if not clear after 10 to 15 min of this try inserting a wire .
Mar 03, 2011 | Frigidaire Refrigerators
Front defroster on a 1996 Saab 900s does not work at all.
have you tried the heater with th air cond on
Jan 05, 2009 | 1996 Saab 900
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
Fridge not cool
the coil is frosted over and no air is being pushed to the fridge it may clear up after a few defrost cycles or remove the food from the freezer and allow it to thaw completely (12hrs) the ice behind the back wall takes a long time to thoroughly melt or you will have soild ice instead of frost and then it will never thaw soild ice.
Sep 29, 2007 | Maytag MFD2560HES Bottom Freezer French...
Krylon Crystal Clear Spray Triple-Thick Glaze 12 oz. can Logo
27 people viewed this question
Top Krylon Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Krylon Air Tool and Compressor Expert? Answer questions, earn points and help others
