Question about Trueblue TB-10EL Blueooth Headset
True blue headset help
Bluetooth show charging but headset wont come on
How to fix H350 Bluetooth headset? why wont it charge?
You should charge it via wall charger so it charges faster.
Jun 26, 2014 | Motorola Mobility Bluetooth Hands Free...
Setting up my blue tooth
You need to pair it with the phone, working on phone settings, what is phone model?
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do I turn it on. Is the red showing or not showing
To turn the Explorer 240 Bluetooth headset on, press and hold the call control button until the indicator glows blue. You will hear ascending tones. The headset will then show intermittent flashes of blue. You should only see a red light when powering the headset off or if you are charging the headset you will see a solid red light. User guide is included in this link.
Plantronics Explorer 230 User's Guide
Aug 03, 2011 | Plantronics Explorer 240 Bluetooth Headset
Mic is synced but cant use online
my problem is the mic wont syncronize and wont respond to my voice and i cant hear other people through it .it still flashes blue and charges fine
Aug 30, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Why wont my headset blink the blue light
Hi there...
It's probably not charged enough.
Make sure you plug in to your USB connector, and charge it before you try turning it on again.
Hope I helped!
Tom
Jun 20, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
I cant get my plantronics ex 233 bluetooth to connect to my ps3
when i charge my bluetooth, the light is red for a few minutes but it goes out and its not charging anymore. Please help
Mar 04, 2009 | Plantronics Stereo Earbud Headset for Use...
Bluetooth wont turnon new unit out of box
Pardon me if you have already tried this but with my em236c I had to hold the Answer/End button for about 15 sec before it flashed red/blue. The manual doesn't say how long to hold it. It took a couple of tries for me. Hope this helps.
Jan 05, 2009 | Southern Telecom Emerson Bluetooth Headset...
Connect trueblue bluetooth headset to Samsung Eternity cell phone
I had the same poroblem. I turned the phone off and then restarted it. That worked for me. Try to make a phone call and see if you can hear it on the Bluetooth.
Also... compliments of Best Buy Troubleshooting -
Bluetooth Troubleshooting: Phones & Headsets
Problem #1:
Headset and phone are turned on, but you don't hear anything in the headset, i.e., there is no dial tone.
Action #1: Make sure your phone is Bluetooth-capable. If it is not: A. Buy a new Bluetooth-capable phone. B. Purchase a Bluetooth adapter for your non-Bluetooth phone. The adapter will allow your phone to interact with a Bluetooth headset.
Problem #2:
It's a Bluetooth-capable phone and Bluetooth headset, both are turned on, but you still don't hear anything.
Action #2: Make sure your phone, headset, and, if necessary, adapter are fully charged before attempting to synch the Bluetooth connection between the two devices - in many cases a blinking blue light will indicate the headset is charged.
Problem #3:
Everything is charged, but still not working.
Action #3:Before two Bluetooth-enabled devices can communicate with each other, they need to be initially synched up to each other - also referred to as linking or pairing.
A. Find "Communications" or "Connections" on your phone's menu screen and explore within to locate "New" or "Bluetooth."
B. Push the main button on the headset until the light shines solid blue and is NOT blinking. C. Select Bluetooth on phone menu. Within Bluetooth you may need to select and highlight "Devices" or "Find Devices" (depending on where you are, there may be other Bluetooth devices available).
D. While the headset light is solid blue, open the Bluetooth link (or Find Devices) on your phone's menu screen and scroll through until you locate the headset you wish to synch up to. Your phone will automatically begin searching for Bluetooth devices within 30 feet of itself.
E. After a short period of time, your menu screen should say "connected" or "devices paired". Make sure you click or select the device name to finalize the connection. If you have successfully paired the two devices, you will hear a dial tone in the headset. Congratulations! You've joined the Bluetooth world.
Note: After a couple of minutes showing solid blue, the light on the headset will start blinking; you want to pair up the phone and headset while the light is still unblinking. This is important. If the light starts blinking before you can complete the connection, you will need to turn the headset off and on and start over.
Problem #4:
You've followed all the instructions in this guide, and your Bluetooth connection is still not functioning properly.
Action #4: Take out your manual and carefully reread the section on synching up Bluetooth devices. If you still can't get things properly connected, we suggest you call the manufacturer regarding this issue.
Motorola: 1-877-MOTO-BLU for troubleshooting, or www.hellomoto.com
Jabra: 1-800-327-2230 from 8 a.m. to 8 p.m. EST for technical support; or www.jabra.com
I hope this helps.
Dec 19, 2008 | True Blue TB-50CR Bluetooth Headset
Trueblue TB-10EL Blueooth Headset Logo
26 people viewed this question
Top Trueblue Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Trueblue Radio Communication Expert? Answer questions, earn points and help others
