Question about Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair
Can a bad ac relay in a 1999 chevy truck keep ac from blowing cold air
Ac doesn't blow cold air, and has a new compressor
  • 3 Answers
It could be your inline filter witch is called a orifice tube Check the pressure sensor next to the accumulator and check the fuse box for the ac compressor fuse
Posted on Apr 23, 2014
Blows cold when first started and then blowes warm
I would replace the AC compressor cycling switch it may be sticking have seen it a number of times. The switch is located in the receiver dryer on the passenger side of the engine compartment. See picture below.
If this isn't the problem the AC compressor relay may also cause this, flip a coin.
Sep 13, 2012 | 1999 Ford Taurus
Where's the fuse for the AC on 98 Olds 88?
So what does the fuse that blows, protect?
You need a wiring diagram & start to test
the components most likely to cause a high
current draw & blown fuse.
Don't keep replacing it.
You know the fan control circuit works, but the
compressor doesn't stay on. Did you monitor
the compressor as the fuse blew?
May have a module for compressor & fan
If so one side failed
The compressor clutch could be bad
May 24, 2012 | 1998 Oldsmobile Eighty Eight
2003 chevy s10 - keeps blowing out AC fuse. Will work for a couple minutes then compressor quits working. Check the fuse, it is blown out. Put in a new fuse, works a couple minutes, then quits, fuse blown...
Unplug the a/c compressor, there will be a plug near the pulley. Install a new fuse. Start the vehicle and turn the a/c on. Wait about the same amount of time it took for the fuse to blow in the past. Did the cues blow? If no replace the a/c compressor, the clutch has gone bad. If yes, than the wiring between the fuse and the relay or the relay to the comps sore is grounded. A careful inspection of the wiring should reveal the problem.
Jul 03, 2011 | 2003 Chevrolet S-10
I have a 2003 toyota corolla. My AC would blow cold air for a min or two then when the compressor shut off it would no longer blow cold air or come back on. A new compressor was put in it but it did not...
the ac clutch relay is the problem. It is located in the under hood fuse box. It is a $10 part. The relay will make a clicking sound when activated but the contacts inside are burnt causing no electrical flow to the ac compressor. Simply unplug and replace. The relay is labeled M/G CLT .
replace or blow out the cabin air filter as well. It is located behind the glove box. Instructions are in your owners manual.
Oct 31, 2010 | 2003 Toyota Corolla
1999 Alero: where is the a/c control tempature :problem is wh...
WELL TURN ON AC MAX COLD HIGH TO SEE IF COOLANT FANS TURN ON.IF NOT YOUR REFRIGERANT SO LOW THAT THE AC REFRIGERANT PRESSURE SENSOR WONT CLOSE CIRCUIT TO TURN ON COOLING FANS.MEANING YOU NEED HAVE AC CHECKED AND CHARGED.ALSO CHECK COMPRESSOR FOR POWER IF NOT YOU HAVE BLOWED FUSE OR BAD RELAY.IF FUSE AND RELAY GOOD YOUR AC COMPRESSOR CLUTCH COIL OPEN OR THE AC CONTROL SWITCH IS BAD.IF COMPRESSOR IS RUNNING WHEN YOU TURN ON AC YOUR AIR TEMPERATURE ACTUATOR NOT WORKING.
May 17, 2010 | 1999 Oldsmobile Alero
99 plymouth grnd vygr van- installed new ac still don't cool
Your problem could be the blower fan relay or control modual that is bad have both checked iut.
Sep 16, 2009 | 1999 Plymouth Grand Voyager
A/c does not stop blowing hot air? system has freion but doesnt blow cold.
I would first check the low pressure cycling switch. Next the compressor clutch. I am assiming you already checked the fuses. I hope this helps.
Thank You,
Roy
Aug 08, 2009 | 1999 Chevrolet Silverado 1500
Ipcw Chevrolet S10 / S-pu 1998 1999 2000 2001 2002 2003 2004 Head Lamps Projector Clear Chevy Only-1 Pair Logo
78 people viewed this question
Top Ipcw Office Equipment & Supplies Experts
 Russ Hill
Russ Hill
Bill Boyd
Are you an Ipcw Office Equipment and Supply Expert? Answer questions, earn points and help others
