How to take out toner part from printer to change it
How to take out toner part from the printer to change or to refill toner
    Sergeant:
  • 205 Answers
What brand & model is it
Posted on Apr 23, 2014
  • 26 Answers
SOURCE: printer toner refilling
you can fill it by yourself.
1. buy good qulity magnatic toner powder.
2. basic for oppening 12a toner is 2 SIDE SMALL PIN, YOU CAN EITHER PUT THESE PINS INSIDE THE TONER WITH THE HELP OF HAMMER AND NAIL.OR OTHER TRICK IS TO FIRST OPEN THE GEAR SIDE TWO screw BY PHILIPS SCREW DRIVER and pick up drum then with the help of l type sharp longe nail try to pull pins from inside to out side this by process you see you get two part of toner cartridge one is wast chamber another is main chamber smaller one is wast cleane it .
open the both side of main chamber by unscrewing 4 screw ond pour the toner power powder in that main hopper and do all the steps in vice versa. your toner is filled TAKE A TEST PAGE.
I can frovide you photos step by step mail me inkcity@rediffmail.com if neded
Posted on Jun 01, 2008
SOURCE: my samsung ml 1640 printer refiling after eror
I have solution about this problem
Mail Me Ketanmchauhan@yahoo.co.uk
Posted on Mar 23, 2009
  • 77 Answers
SOURCE: error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Posted on Apr 28, 2009
bhagyavichar
  • 414 Answers
SOURCE: Refilled toner for ml 2245 samsung printer doesn not print
dis is quite common problem..don't panic..
did u change / replace the cartridge with original spare or refilled it??
this kind of problem often follows with an unbranded cartridge change and or refilling..!!
least chance of the defective cartridge itself causing such problem..!!
however always try to use genuine refill packs/toner..
..contact ur system admin/vendor....
Posted on Oct 26, 2009
SOURCE: samsung ml-2240 printer is not accepting refill toners please hel
my samsung printer is model ml-2240 is not accepting refill toners please help, it is showing message that toner is exuasted, even though i refilled it, plesae help?
Posted on Nov 01, 2009
Which one refill kit I need on this page?
HP Easy Refill Kit for (HP) Color Inkjet Cartridges Printer
Jul 10, 2012 | HP Easy Refill Kit for (HP) Color Inkjet...
I change my toner, and i have msg. "ORDER
Must be an aftermarket or refilled toner cartridge. These toner cartridges have a chip on them that must be changed when refilling or remanufacturing the cartridge. It looks like you got a cartridge where the chip has not been changed. I would return it for another cartridge.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 13, 2011 | HP LaserJet P3005 Printer
I have samsung ml-1640 printer, i refilled my toner past two times, but now printer is not working, it say "refill your toner", somebody says "only use orignal toner, don't use refill "...
Try changing the fuse on the toner. Otherwise, there are is a way to reset the sensor by opening the back cover and short circuit a chip. (check google for that but be very carefull and also check revision of printer. e.g. A, B,..)
Oct 27, 2010 | Samsung ML-1640 Monochrome Laser Printer
I have got my samsung 4300 toner refilled,and the display shows toner exhausted .the person who got my toner recharged told me that samsung 4300 printer has some inbuilt chip,which needs to be changed...
Hi
The person refilling your toner needs to install the correct chip onto the toner cartridge. The chip stores the number of pages printer by that cartridge and is unique to each model printer, therefore an incorrect chip will not work. Good luck with that
Oct 06, 2010 | Samsung SCX-4300 Monochrome Laser...
ML-2510 Laser Printer : persistent blinking red light
Dear
This problem you will be noticed when toner is 90% empty.
Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
Nov 11, 2009 | Office Equipment & Supplies
Oct 26, 2009 | Samsung ML 2010 Laser Printer
I have refilled the xerox phaser toner it is asking for toner card
Dear,
Is there any chip identifier for that toner. If there you have to change the chip. Otherwise yiu refilled wrong toner posder for that toner.
Cheers
Jaggu
Oct 18, 2009 | Xerox Phaser 3100MFP/S Laser Printer
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
Lexmark error: 33.64
Change Toner cartridge.
Do not refill your toner cartridge in the same place anymore ;) Do not refill them like 10 times ;) Use original toners for your MF/Printer
Maxi
Feb 18, 2009 | Lexmark All-in-One Printer with PictBridge
12 people viewed this question
k24674
jasbo
jasbo
