Question about Samsung CLP 300 Laser Printer
I have a solid red light and the software says DEV. Home Error. I have tried everything Samsung has asked and I still get the error. The first error said driver damaged. I removed the drive and all Samsung software, went to the Samsung download center and downloaded the latest driver, installed it from the desktop and now get a Dev. Home Error. Please HELP!!!
  • 12 Answers
This can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
Open up the right side (power cord side) of the printer (take off top cover, then take off side cover). Then, find a solenoid (little metal square) that touches the white plastic vertical spur gear. Take the spring off the solenoid. Now, put the spring back on - only this time you will attach one anchor point to the middle of the spring as to pre-stretch the spring for more tension.
The problem is that the spring gets weak over time / the cogs round out over time and the solenoid finger is overcome by the spinning cogs, and resulting in selecting the wrong developer.
More pictures of the solenoid on Facebook:
http://www.facebook.com/#!/photo.php?pid=55779771&id=2257206&fbid=10100154259704133
Posted on Jul 10, 2010
    Champion:
  • 220 Answers
The main drive assy is faulty.Had changed several and it worked.
Posted on Jun 24, 2009
    Brigadier General:
  • 4,090 Answers
Sounds to me like the ink carriage is had up against the stop button. make sure the cartridge is at the R hand side of the printer
Posted on Jun 20, 2009
Dban problem ( crash : "dev/sda" )
Use fdisk and / or format from command prompt. Easy and no fuss. gl
Nov 03, 2012 | Computers & Internet
Dev. home error
Dev. Home error can be fixed by stretching out a solenoid spring on the power cord side of the printer. The solenoid acts as a clutch to stop the spinning developer actuator at the right spot.
Dec 31, 2009 | Samsung CLP 300 Laser Printer
Red status light. Dev. Home Error?
The Transfer Belt has a defect. Perhaps it is disrupted.
Aug 02, 2009 | Samsung CLP 300 Laser Printer
Right out of the box, my ML-2510 has a solid red error light
You should install the software prior to connecting the printer, to make sure the provided drivers are ibstalled and not the generic ones that come with Windows.
Jul 22, 2009 | Samsung ML-2510 Laser Printer
Deve home sensor error
You could try replacing the Image Unit (but these are quite expensive). This error actually refers to an optical sensor located in the gearbox (RHS of machine). The sensor controls the drive to the individual dev units, hence the "dev home error" if it malfunctions.
Probably a job for an engineer.....
Jun 19, 2009 | Samsung CLX 3160fn All-In-One Printer
Brand New printer status led RED, Smart Panel error "dev home"
Samsung CLP-315 Dev Home error
It appears that the Dev. Home error is very common for Samsung printers. It obviously has different reasons. In my case I solved it by stabilizing the deviation clutch. It was too unsteady and the dev. sensor recognized a fault.
The dev. clutch is situated under the right cover, which is the power supply side of the printer. To remove this cover you need to firstly remove the top cover, which is held by two screws on the front. Then uncover the right side by unscrewing one screw on the back, near the power supply inlet and unclip a couple clips on the top side of the cover. After removing it you have to find the deviation electrical clutch. Check if it is too unsteady. If it easily moves, you need to somehow stabilize it, in my case by a couple of leather straps under it, so that they press it up and make it steady: 5_19_2012_1_08_58_pm.jpg
After that simply check if you have stabilized it properly. If you have the green light must turn on after switching the device on.
NB! Be extremely careful when power is ON, because there is high voltage running. I'd suggest that you would stabilize the thing with non metallic item to keep safe. Good luck!
Apr 13, 2009 | Samsung CLP 315 Laser Printer
Home dev. error
reinstall the affected dev assy, or try to removed and put back again
Oct 25, 2008 | Samsung CLP 300 Laser Printer
SamSung CLP-300 laser color printer does not print. Status red light is on all the time. When check with service center they said it is Dev.home error and take it to service center. What is the problem...
I had the same problem and look it up in service manual,
there the say Home of development is not checked or checked at a abnormal time. solution Clutch of development or mainbord must be checked.
when i opened the right side cover i vind out that the development clutch moved two parts do it was suppose to move one part, when i tightened the spring on the solenoid the problem was over and the clutch stopped at the right place. its easy to do.
Aug 03, 2008 | Office Equipment & Supplies
Samsung CLP 300 Laser Printer Logo
753 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
