Siegler oil stove
Changed a fuel oil filter and now cannot get oil to stove
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 180 Answers
You need to bleed air from line, look for bleeder screw and unscrew while trying to start unit. Don't unscrew all the way, when oil comes out, screw back in and unit should start. Screw should be on filter housing and one on burner motor (where fuel line comes in).
Posted on Apr 26, 2014
What type of oil do you recommend for my 2005 6.6 Durmax. And should I change the fuel filter at every oil change.
Rotella T 15w40 is the standard for diesel engines. I would highly recommend changing the fuel filter every oil change.
Feb 15, 2017 | Cars & Trucks
207cc 1.6 Gt Fuel Filter location
What do want to change the fuel filter for they never need changing here in europe as the fuel delivery pumps in the fuel stations have micronic filters inside the pumps ,europeon law so it shouldnt need changing unless it corrodes away that is if its a metal casing .Their is a gauze filter on the fuel pump inside the tank but if this motror runs ok leave well alone and stop playing around trying to a boy racer sunday mechanic job ,change the oil every 5/6000 miles with a oil filter every third oil change and use the cheapest diesel/petrol engine oil you buy ,gap the plugs every other oil change and it will run like a dream ,stick to putting a boom boom box in and stick go faster stripe and leave it alone
Nov 29, 2013 | 2008 Peugeot 207 CC
Changing fuel filter and transmission fluid on a 1990 gran prix
just follow the fuel line and you will find the fuel filter ,but if its running ok then just check the fuel lines for deterioration and leave well alone ,the fuel pumps at the garage have filters in them so you shouldnt need to change the filter unless the metal casing is rusting,as for the transmission again if it works ok then do not disturb as its only hydraulic oil and it doesnt get dirty like engine oil but if your gearbox is showing signs of bad changes and you can see bits of worn brake band in it then change the vehicle as even if you change the oil it will pack up with or without a oil change.
Jul 15, 2010 | 1990 Pontiac Grand Prix
My toyo lazer 30 won't start, and the EE2 problem comes up.
With an EE2 message you have a problem with the stove igniting during start up. If you continue to try you will end up with an EE22 and the stove will be locked out. If so, un plug for 20 minutes. While you are waiting check out you fuel system. Low fuel, no fuel, dirty filter on tank and stove. Be sure to bled the air off the top of the filter when you change it.
Keep us posted.
Tom
May 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Solid fuel stove linked to oilsystem with two zone
Put a temperature operated control (aquastat) on the piping of the wood stove so that if it is on, it will interupt the circuit wired to the oil burner at the X&X terminals of the boiler control.As the wood stove cools off, it will close the connection allowing the oil system to fire.
Mar 04, 2010 | Honeywell Electronic Programmable...
Fuel filter
There is no need to change it frequently. If there is a loss of engine power or if throttle cuts out then may be its the time to change fuel filter. It is recommended by peugeot to change fuel filter (but depends on fuel purity) after every 36000 miles.
You can clean it yourself
Dipp the whole filter body in carosine oil tank and leave it in there for about 20-30 minutes
Pour some petrol in filter with the help of plastic piped and apply a slight air pressure (use a piece of pipe to blow) in the reverse direction (marked with arrows) of fuel supply to clear residue and heavy oil composite that clogged in filter.
Repeating the cleaning process 2-3 times will clean the filter to reuse it without the need of a new one to buy.
Jan 06, 2010 | 2005 Peugeot 405
Laser toyostove will not ignite
Zen,
When you ran out of fuel the filter trapped some air in the very top. You need to loosen the fitting on the fuel line right at the filter and let the fuel run of a minute. This will clear the air from the top. On the way out to the filter unplug the stove. Leave it unplugged for 20 minutes. This will clear the EE22 message. Now you can restart your stove.
Tom Hawkins
hawkins111@gci.net
Apr 07, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
MPI kerosene Monitor Heater
need to bleed air out of filter at oil tank crack open the screw on top it will bleed out air wait until oil starts to run out then tighten back and bleed at heater on right side lever inside hole push and let off slow 4-5 times and restart
Nov 02, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
