Question about Frigidaire GLEQ2152ES Electric Dryer
Gas dryer sounds like rumbling at times, gas igniting sound
2 Suggested Answers
hunter19_46m
  • 7482 Answers
SOURCE: Dryer making rumbling sound like the load is
Hi bford57...
Sounds like your drum rollers need replacement or oiling.
Please rate me
Posted on Sep 16, 2011
I get a rather loud rumbling sound when I first start up the dryer the drum is turning but still getting the rumbling sound but not as loud.
Sounds like you need rear rollers or you have a bad blower wheel. If you turn the dryer off and still hear the rumble for a few seconds its the blower wheel. If the rumbling stops instantly then you have bad rear rollers. Hope this helps.
_MJ_
Dec 14, 2010 | Maytag Dryers
Dryer initial had rumbling sound when started and then quieted down to normal. It now makes a rumbling sound through the complete dry time
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Aug 31, 2010 | Maytag MDE2600 Electric Dryer
MaytaG MODEL # MDG4000BWW. Rumbles and sweels as
check the rollers,the pulley and if it shakes as bad as it sounds the blower wheel is probably damaged
Jul 31, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My dryer rumbles when it is spinning. But it also
The drum support rollers are worn. This will cause loose belt tension and a rumbling sound. You will need to pull the drum to find the rollers at the lower back of the drum. Check the roller shafts for wear and replace them at the same time as the rollers if needed. Check the belt and tensioner for wear before reassembly. This should fix ya...
May 08, 2010 | Dryers
Loud rumble sound, Vent hose vibration
That model of neptune dryer had a problem with the blower housings cracking. When the housing cracks, it binds forward into the blower wheel making a loud "rumble" noise and vibration. If you open the door and manually turn the drum and you hear a rubbing noise and feel alot of resistance, then you have a cracked blower housing and need to replace it. It is not an easy job to replace, so if your not familiar with dryers, you should have a technician replace it. Let me know if you have any further questions. shane
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes rumbling noise intermittently
It sounds like a faulty roller under the drum. Need to pop the top of the dryer, then remove the front -- you'll probably easily spot the faulty part.
May 06, 2009 | Maytag Dryers
Maytag gas dryer
The spindle or shaft turning the drum may be bad. The motor as well could be slowly but surely grinding to a halt.
Jan 25, 2009 | Maytag Dryers
Kenmore gas dryer
Hello gage400,
happy to assist you,
You said, Your dryer tries to light up, then a rumbling noise and the gas shuts down
this sounds as if you may have a bad igniter and the system shuts down when it fails to ignite.
best you call one of the servicer s available here on the fixya.com web sight sight!
This is not something you want to play around with in a gas dryer!
You do need hands on service.
Bless you,
keep me informed and tell me how you are!
huuum
Please give me a good rating before you sign off.
Thank You
Sep 14, 2008 | Kenmore 95087 Gas Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
16 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
