Question about Toro Garden
How to determine the oil level on dip stick
I just received a new toro super recycler lawn mower 20381. I used manual that came with the mower to set it up. In the manual the dip stick has criss-cross lines, as shaded area to show max oil level, the real dip stick doesn't have such shaded area but it has two holes. I assumed that the upper hole shows max level and the lower hole shows min level of the oil. Am I right? I tried to contact the toro mower customer service but they don't know such things and sent me to authorized dealer that is located who knows where. Is any body know how to determine max and min level on dipstick of my toro mower?
  • isaak goldman Apr 23, 2014
    Thank you Tom. Now I just more confident that the oil level is OK.
    Top Expert:
  • Toro Master
  • 33,294 Answers
In other products, the upper hole is max and the lower hole is min. Somebody at Toro forgot to change the manual when the dipstick was reengineered.
Posted on Apr 23, 2014
My toro super recycler bogs down while mowing. I have fresh gas, just changed the oil and filter. Any suggestions?
check and be sure the blades are sharp. if the blade gets a rounded edge it wont cut properly and will bog down trying to cut.
Aug 15, 2016 | Toro Power Lawn Mower
PTO wont engage how can you check
PDF]Owners Manual - Mowers Direct
www.mowersdirect.com/manuals/20382OM.pdfSuper Recycler® Lawn Mower. Model No. ... Whenever you need service, genuineToro parts, ... This manual identifies potential hazards and has safety.
You can download the above from google.
You can also check if there is a safety feature keeping the PTO from engaging.
Jul 17, 2015 | Toro Super Recycler Super Bagger Lawn...
Oil leak toro recycler 6.5hp lawn mower
Sounds like the bushing is bad where the crank shaft comes out.
May 19, 2013 | Toro Garden
I put too much oil in the mower over the past couple months. Two days ago the mower began steaming. I shut it down immediately. Today I did an oil change and cleaned the mower up but after I started it,...
If you already changed oil and it is at proper level on dip stick let it run for about 5 minutes to burn out any excess oil in cylinder, if it continues to smoke you probably blew a gasket or seal on engine.If that is the case you are looking at buying a new mower unless if it under warranty or you have a cheap mechanic.
Aug 30, 2011 | Toro Lawn Mower With Toro Power Tools
How much oil should I put in my toro self propelled briggs & stratton lawn mower
if your motor doesn't have a dip stick fill the oil to the sight ring inside the fill tube, try and not overfill , this will cause seals to blow out due to increased pressuer
Jun 20, 2011 | Toro Power Lawn Mower
Just bought a toro lawn mower did not have a manuel, I want to know how much oil should I but in mower at first?
hi there
if the engine brands is briggs and stratton
the general amount is 0.6 litre or fill it up untill the oil level reaches the full mark on the dip stick
use sae 30 oil
if its tecumseh use 0.7 litre
cheers pauly 46
Jun 02, 2011 | Toro Garden
I have a Toro Super Recycler GTS 6.5 HP. Upon starting the mower white smoke comes out of the exhaust (silver housing) on the front. The smoke stops after about 2 minutes of running. Any ideas??
Oil level too high? *(check oil level with dipstick fully screwed down!)
or
Leaking valve guide *(rare.)
Cylinder walls not sealing well and oil leaking past rings. *(less rare...nothing you really can do about....just getting used up)
I would change the oil and be very careful to fill only within the full range.
Then, run the unit once to clear the muffler out.
Good luck and be careful!
Jul 21, 2010 | Toro Super Recycler Super Bagger Lawn...
Garden Logo
176 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
