Question about Garden
John Deere LX178 Lawn tractor Surges and Dies
After 30-40 min. the tractor surges and then dies. After sitting for an hour it starts right up and runs again for another 30-40 min before surging and quitting again. I have replaced the fuel lines, filter and verified the vent in gas cap. Ignition Module? It is a Kawasaki liquid cooled v-twin 15hp.
  • 711 Answers
It sounds as though the coil is heating up and shorting out. Do you know how to get to the coil to replace it? Anyway check the coil by inserting Phillips head screwdriver into the coil wire, hold by the handle so wire is 3/8 to 1/2 inch from the cylinder head or bolt and crank the engine and look for blue spark. No spark or weak yellow spark the coil is bad. Do this check the next time it quits on you. If you need instructions on how to get to the coil, get back to me. Hope this helps, plese post solved on fixya.com.So I get credit for a solved problem if it does. If not, check back and give me more info.
Posted on Apr 24, 2014
SOURCE: Hello. My John Deere mower has started surging at
I have a john deere 420 rider. It would surge at a higher speed. It is a hydrostatic and there were 2 bolts on the transmission that were loose. now it runs beautifully smooth,
Posted on May 04, 2009
  • 218 Answers
SOURCE: My 18 hp twin cylinder Briggs and Strat. Craftsman
Hi..my name is Keith...and the engine is running too lean..and with you choking it..it richens the mixture..so its a carb problem..and that could be several things..1)..is the main metering jet needle on the bottom of the float bowl needs to be turn out until the engine runs smooth..or 2) the carb to engine gasket is bad and its sucking air..or 3)..the passage ways in the carb is stopped up..i hope one of these will help..if not please write me back
Posted on Jul 10, 2009
SOURCE: I have a lx 255 john deere wont start
You have a defective ignation coil. When the engine gets hot, the winding in the coil opens and the engine stops. After it cools down, it will again make contact and start again. If you don't know where the coil is, follow the wire from the spark plug. The spark plug wire is attached to the coil from the factory. It's easy to replace with a 1/4 inch socket set. Set the magnet to coil gap with a standard business card.
Posted on Jul 27, 2009
SOURCE: My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Posted on Dec 31, 2010
rockitman187
  • 2559 Answers
SOURCE: Have a 23HP Intek
Sounds like the muffler maybe clogged up a little causing to much back pressure or a bad oil pressure switch
Posted on Jul 01, 2011
How to remove the old lower hood on a john deere lx178
Don't worry I'm sure you will get the solution of your problem, just check the link I attach.
JOHN DEERE LX172 LX173 LX176 LX178 LX186 LX188 LAWN GARDEN TRACTOR Service...
Apr 29, 2017 | John Deere Garden
JD lawn tractor starts hard, can only idle and gas drips out of tube on carb until warm,it runs for 20 mins. then starts surging and dies,wait awhile, then starts.
try removing the carby and cleaning out the needle and seat area
the float pushed the needle up into a seat that can get hair , grass bits , dirt between the needle and the seat and then the fuel becomes uncontrolled and flows out the carby
I suggest a clean , blow out oul of the jets and work from there
May 13, 2016 | John Deere Garden
Mower only runs with choke held open
Have you cleaned filter on carb unit? My filer gets plugged with dry grass and does this. I have to remove filter and clean out grass even though the cover is on tight, don't know why but it does. Hopes this helps.
Sep 23, 2014 | John Deere Tractor Starter 285 345 2243...
Shorts and engine slows or dies
Find the shorted wiring and cover it, to prevent another sorted.
May 01, 2012 | John Deere Tractor Starter 285 345 2243...
09 JD X 340 27hp Kawasaki eng\ surges
Hi
That is a fuel problem caused by stale gas you will need to remove and clean the carb with carb cleaner.
Sam
Jan 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Oct 02, 2009 | Garden
John Deere 65 mower cuts for about 20 min. then dies, will start right up again, cuts maybe 5 min., dies again
You have a partly clogged fuel line or the vent in the gas cap is clogged.
Sam
Jul 18, 2009 | John Deere Garden
Garden Logo
227 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
