Question about Toshiba 40RV525U 40 in. LCD TV
Can get only 1 channel to program on my toshiba
To program i press the input button on remote repeatedly until ANT/CABLE is selected. 2. then press the menu button on the remote control using the arrow buttons, select and highlight the INSTALLATION and press ENTER. Select the icon in the top menu associated with terrestrial, this is the icon furthest to the left that looks like an antennae. Select and highlight INPUT configuration and press enter. Using the left/right arrow buttons, select anntenae or cable as desired then select done. Press the channel return button to go back to terestrial menu. Select channel program and press enter. Select start scan to begin channel program, and it starts it programming sequence but will only find one channel, used to get 10 channels.
  • Toshiba Master
  • 1,525 Answers
Hi if the tv has dtv just select air digital only thanks
shaun
Posted on Mar 25, 2017
  • 362 Answers
SOURCE: Toshiba 26AV502U Won't Pick Up Channels
Hi albertogiler, I am happy to help, you will need to attach a antenna to the tv to pick up OTA over the air signals, depending on your location you may be able to use a set of rabbit ears, I have provided a link to a site that will explain in depth. http://www.antennaweb.org/aw/welcome.aspx
Let me know if this helps and please rate this solution. lone99star
Posted on Jan 13, 2009
  • 18 Answers
SOURCE: I want to set the remote to change volume on TV
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Posted on Oct 18, 2009
  • 5223 Answers
SOURCE: toshiba tv 32kv500b, when tryin
I suspect you are seeing the Main Menu for the source that you are currently using. Press the Source button (TV/AV on the TV itself) and make sure you are on TV source. The menu will have a set of icons if it is set for analog and a vertical list in digital. Select Setup (use the up/down arrows for digital and the left/right for analog - it's the first one in the list) and click OK. Then select Installation (third one in the list) and then press OK. Next select Automatic channel scan (first one again) and press OK. You will see a warning prompt, highlight Yes and click OK to scan for digital channels. When it is done, it will ask if you want to scan for analog channels.
The manual is available here: http://www.toshiba-om.net/LCD/PDF/English/Country_Specific/KV500-32-English-Specific.pdf (direct link to the pdf)
I hope this helps.
Posted on Dec 16, 2010
rommelalilin
  • 2178 Answers
SOURCE: Toshiba 37HLX95 no audio only on over-the-air
Swap input 1 and 2 and see if you get same result - could be a bad tuner in the set (#2).
Posted on Dec 30, 2010
  • 5223 Answers
SOURCE: I hooked up an indoor antenna to the TV and select
First try moving your antenna around (see the sites listed below for the direction to point the antenna to get a signal). If the antenna has an amplifier, try unplugging that unit. (When an amplifier fails, no signal gets transmitted.) Similarly if you have several TVs sharing one antenna, remove the splitter and directly connect the antenna to this Toshiba to make sure that it isn't causing the problem.
You may be in an area where an iindoor antenna may not work for you. Tall buildings and trees can scatter the signal to the point where a digital tuner can't get enough signal to "read" the data. Again use the results from the sites listed below to check what stations are likely to be received in your area.
Different TVs have different tuner sensitivities. An amplifier may help bring in enough signal to get the channels. (Signal loss is inevitable. However, if the signal is sufficiently poor, an amplifier may give you more noise and won't help.)
There are two sources for a site specific list of channels: Antennaweb.org and tvfool.com . Antennaweb assumes an external antenna and is very conservative in the list of channel that you should receive. (It lists two channels from one transmitter in my area.) Tvfool will indicate the channels that you should get with different antennas (indoor, outdoor, amplified signals).
A rare issue can be that the tuner in the TV has failed. The only way to check that is trying the TV with different antennas (or in different areas - one with high signal strength).
I hope this helps.
(ATSC (digital OTA signals) are either enough to read or not. You can't get the fuzzy signal of an edge of range analog signal.)
Posted on Aug 15, 2011
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Feb 16, 2011 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I have a small elemet tv with a en21645e remote control. My grandson did something to the remote and now I only get the local channels not cable channels although I have cable hookup
The little tyke has most likely pressed the INPUT button on the remote control and switched the TV away from the external input setting required for watching cable TV.
You did not state the model number of the TV and some TVs function differently with regard to the selection of external inputs, but you should be able to return to watching cable by pressing the INPUT button slowly but repeatedly until you can see the picture from the cable channels again. The INPUT button is located in the top right corner of your Element remote.
If an input selection menu appears on screen when you first press the menu button, use the arrow keys to highlight another input, then press ENTER to select it. I can't tell you which will be the correct input as I don't know the model number of the TV and it depends on which type of cable you are using to connect the TV to the cable box. You should try each input in turn until you are able to see the cable channels again. Please make sure the cable box is switched on when doing this!
If you are still having difficulty, please reply to me from within this page with the model number of the TV and the type of cable you are using to connect the cable box to the TV. I will then be able to provide exact instructions for switching your TV back to the cable input.
Hope this helps.
Regards,
BElectric
Jan 28, 2011 | Element Televison & Video
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
How do you set up the Soya TV. Is it cable ready?
Yes, your TV is cable ready. To set up, you will need to use the original remote and complete the following steps.
1. Connect your cable box to your TV using either antenna (RF) cable or component A/V
2. Press the "MENU" button on your remote
3. Select "CHANNELS" using the up/down arrow buttons on your remote and press "OK"
4. Select "SCAN CHANNEL" and press"OK".
5. Select "CABLE" as the source and press "OK" to tune
The TV should now automatically tune the cable stations and exit the menu. If you need to exit the menu and/or start again just press "MENU" on the remote again.
If you have no picture, press the "INPUT" button on your remote repeatedly until the input is on "TUNER" if you are using an RF cable or "COMPONENT" if you are using component A/V cable.
Your TV should now be setup for watching cable.
Please post back if you need further assistance.
Regards,
BElectric
Dec 05, 2010 | Soyo MT-SYTPT3218AB 32 in. LCD Television
No channel 3, the tv goes from channel 2 to 4, can't use the cable box
Two options...
1. Connect the Cable Box via RCA cables (Yellow/Red/White) or Component cable if you have a HD cable box and select the appropriate input on the TV to view your programs. This will provide the best picture quality as well.
2. Make sure the cable box is on. Using the original TV remote type in the channel 03 and if this tunes to the channel then go to the TV menu and then go to Set up and then select add/erase and select add.
If typing 03 did not tune in channel 3 then using the TV remote select menu then go to set up and then make sure TV / Cable is set to cable then on the cable box press the channel button a couple of times and then select auto program on the tv.
Jan 03, 2010 | Toshiba 27AF44 27" TV
How can I Program this to comcast digital cable.
Most universal remotes work the same. Try this. Just keep in mind when you select your item select cable.
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• T he unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Sep 25, 2009 | Brookstone 538744 Remote Control
Code list forToshiba television is ineffectual
You tried all of the following codes?
018,021,023,071,085,090
Doing as follows
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Try this if so
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Jan 08, 2009 | RCA RCR311B Remote Control
Toshiba 40RV525U 40 in. LCD TV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
