Question about Vehicle Parts & Accessories
HESITATES AT WHILE IDLING
WHEN COMING TO A STOP LIGHT WAITING FOR THE LIGHT TO CHANGE IT SEEMS LIKE THE CAR IS ABOUT TO STALL BUT DOESNT. THE RPM DROPS A LITTLE BUT GOES BACK UP WHEN I DRIVE
  • 161 Answers
Clean your idle air control(iac) valve. Most iac valves are located by the throttle plate. Clean it with carb cleaner. You can remove it for cleaning, be careful not to damage the gasket.
Posted on Apr 23, 2014
Why does my Fiesta stall while idling all the time?
Idle speed needs to be adjusted to give more revs,
Sep 08, 2016 | 2011 Ford Fiesta
My car starts hesitates the engine vibrates oil light comes on then sputters and cuts off
run the fault codes . Check for idle speed sensor and MAF sensor. It should be idling around 900rpm and the oil light coming on ( assuming you have enough oil in the sump) will be because of the very low idle rpm not pumping enough oil to maintain pressure.
Jul 21, 2013 | 2000 Pontiac Grand Am GT
Rough idling
fuel injectors may be clogged and not spraying properly
May 27, 2013 | Dodge Neon Cars & Trucks
The car hesitates when idling or stopped at light/ stop sign, and the rpm drops to zero then goes back up.
The battery was a red herring - it would not have anything to do with the problem.
Faulty spark plugs could cause a miss but probably not make the engine stall.
What you described is a classic example of a faulty idle air control valve or a dirty throttle body. The computer controls idle speed by regulating how much air enters the intake. It opens the control valve to raise idle speed when necessary.
I would check the control valve and the throttle body.
Sep 27, 2012 | 2003 Nissan Altima
Every time my car comes to a red light it powers off.why?
EGR (exhaust gas recirculation),or TPS (throttle position sensor) When the vehicle makes a stop and go into idle. The RPM is basically too low to maintain the RPM, If the vehicle runs 800 RPM in park or neutral and doesnt stall the setting is correct. If it stall in neutral or park and has a hard time accelerating you will need a TPS, The EGR can stall a engine if it stays open underload approching a stop where it doesnt close properly
Mar 15, 2012 | 1983 Ford Bronco
Idling problems
if your car is missfireing it should shoot a trouble code. does your car have a check engine light?
Feb 23, 2010 | 1997 Chevrolet Cavalier
The car seems to stall when it's idling, that is after the engine gets warmed up.. the rpm goes to under 400 and goes up to 1000. sometimes the engine stops completely when I stop at a stop light.
try to clean the throttle body with some carb cleaner, if that does not work, then you are looking at either the idle control valve, or worse the whole throttle body,
Feb 17, 2009 | 2001 Volkswagen Golf
Vehicle Parts & Accessories Logo
26 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
