Question about Kenmore Refrigerators
Main control board
Where is the main control board located. there is no access panel in the back.
  • Kenmore Master
  • 4,654 Answers
Kenmore model number looks like this 795.51313012
I am here should you need me, Thanks John Tripp Appliance 911
Posted on Apr 23, 2014
How do you access the electronics on whirlpool model wtw7040dw
Do you want to access the main control board? If so, unplug the washer then pull it away from the wall. Remove the screw holding the top rear panel in place. Remove the rear panel. The control board is held in place by another screw. Note the power wire is connected to the back of the control board. See this page for a diagram: http://www.appliancepartspros.com/console-and-dispenser-parts-for-whirlpool-wtw7040dw0.html .
To see the wiring to the pump and motor, start with opening the washer as if to clean the pump filter. If needed remove the lower back panel.
I hope this helps.
Jun 30, 2017 | Whirlpool Washing Machines
Burner don't light no spark
the starter module that controls the TICK/TICK spark, is located in the main board, Digital Clock. To access it slide out the stove, screws are in the back, panel access and you will see the wires going into it, just take out the old board and replace with the new one. Not hard to do, my board was 200, but a new stove was 900. you can light it with a BBQ lighter for $2. My oven kept shutting off.
Mar 04, 2015 | Kitchen Ranges
Machine beeps continuously and display gives an E90 error code. What is wrong?
If this is a Zanussi washer then E90 indicates a communication error between the interface board (control panel) and the main circuit board. Unplug the machine from the power! and take the top off the machine, if you stand in front of the machine on the left side you should see the main circuit board along with a blue multi-wire cable going from it to the control panel (interface board). There is most likely a poor connection at one end or the other or maybe even both. This will generate an E90 error code. You need to remove the control panel by removing the screws located behind the soap drawer and also the plastic clips located along the top rail, disconnect the blue cable from each board one at a time and then plug back in making sure to firmly seat the connectors. These can become loose from miniscule vibrations from the machine operating. Put everything back together plug back in and it should work.
Mar 12, 2011 | Washing Machines
Where is the defrost timer locate
The timer is the main control board behind the refrig , behind the 8X10 panel . If you have a defrost problem , Pull the refrig out and remove the 8 " x 10 " panel . Behind this panel , is the main control board . Unplug the refrig . Remove the BLUE plug from the board , with 3 larger wires going to it . Looking at the blue plug , the sequence will be wire1,wire2,space,wire3 . Get a short piece of insulated wire , and strip about 1/4 inch from each end . Insert 1 end into wire2 , and the other into wire3 . Plug the refrig back in . After about 3 min , look in the freezer , at the bottom , behind the crisper , look for a red glow . If no red glow , unplug the refrig , and reassemble the plug and cover . This no glow , indicates a shorted defrost heater . It is also advisable to replace the defrost thermostat ( pt. number WR50X10068 ) when replacing the heater . To access these parts , you will have to remove the inside rear wall of the freezer . The heater , is at the bottom of the coils , held on with 2 screws , and the thermostat , is the 1 " cylinder , with a blue and pink wire going to it , clipped on the top left of the coils .
If you do get a red glow , then the # 4 thermistor is bad . This tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp and when to cycle off due to selected temperature .
I have never found a control board causing a defrost problem .
Aug 04, 2010 | GE GSS25XSRSS 36" 25.4 Cu. Ft....
I have a Ge refrigerator (model # PDS22MIsacc) it seems to be running alright, but the temperature control panel will not light. we are unable to change tempertures.
you will need to replace the main control board located on the rear panel behind an access panel,this board controls all temps and digital readouts,when the readout goes dark this board is the culprit
Apr 27, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
The "cancel" button for the upper oven on my Maytag mer6751aaw gemini electric range just stopped working. To turn off the heat I had to unplug the whole thing! Is this something I can fix myself, or must...
Hi. due to the fact that the control is one whole piece, this will require you to replace the entire main control board. The cancel key is integrated into the control board. There is an overlay that protects the circuit, but it is a separate part, and is not connected to the main board. This repair will require you to disassemble the entire control panel. The board is located just behind the control panel piece.
Click here to view a diagram of the control sector, and panel.
The control board is labeld number three on the diagram, and the control panel is labeled number 1. There are four screws on the back side of the rear cover. Once these screws are released, you can access the board, from the rear of the control panel. The part number for your replacemnt board will be W10166967
  • NOTE_ If you are not comfortable with totally disassembling your control panel, and replacing this main control board, i would suggest to call for service. this job is not easy.
Nov 30, 2009 | Maytag MER6751A Electric Kitchen Range
No temperature display on my GE Profile PFS22SIS
I think is just the display board next to the cold control.
Oct 01, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
Mcu and ccu
MCU = Motor Control Unit. A control board that is located in the rear of the washer at the bottom adjacent to the drive motor. Remove the back panel for access.
CCU = Central Control Unit. A control board that is located directly behind the wash tub. This is the main "brain" of the washer. You can access by removing the washer top panel.
Jun 30, 2009 | Washing Machines
LCD controller board location on Vizio L37
Display controller is usually under the Main board which you remove to get access to it. Display controller connects to the suis-boards which then send signal to the screen of the TV.
Mar 17, 2009 | Vizio L37 Television
Refrigerators Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
