Question about Samsung HCM4216W 42" Rear Projection Television
Convergence problem Hi I just bought my samsung from my brother and it has a problem with the convergence board. It has red lines through the top of the screen and you see double picture and the red is out.Any way I was wondering if any one could tell me if the convergence board is a plug in or if it has to be soldered in,and where the board is on the tv. thanks
Sure I have this set,and have replaced my convergence board. I think there is an automatic convergence with this set because I didn't have to do any manual convergence after I installed the replacement board. Maybe I got lucky....
Take the cover off the rear of the set. (Unplug it first- duh)
Look to the top right, a board is screwed onto a metal support running horizontally across the set. I think there a 4 plugs but mark the ones red, green and blue as they have the same connectors and can be re-connected incorrectly. Unscrew the board from the frame, pop off the connections and put on the new board. My new board came with new connection cables so I replaced those also. I turned my TV on, did a Perfect focus and it looked good as new. I was really proud of myself that day.
But after you get it fixed, turn around and sell the set. I have had alot of work done on mine in the several years I have owned it.
Oh and make your brother pay for the new convergence board. The one I got was BP94-00155A.
Posted on Nov 03, 2007
Thin red line running from top to bottom of screen
What is this thin red line that is on my screen whenever my ...
Sep 23, 2010 - There is a very thin red line going from the top of my computer screento the bottom, ... If it's a single-pixel-wide red line from top to bottom it's a failure in ....have thin red lines running down the screen??some are thicker than ...
Thin Vertical Red Line [Solved] - Acer - Displays - Tom's Hardware > Forum > Displays
Tom's Hardware Guide
Jul 12, 2013 - 5 posts - ‎2 authors
hi all i am having a Thin Vertical Red Line on my Acer LED moniter ... the screen is having a part fail(cable or the screen/control board it self.).
Why is there a straight vertical line going from top to bottom on ... > ... > Samsung Galaxy S6 edge
Apr 15, 2015 - 7 posts - ‎4 authors
Just bought the Samsung Galaxy s6 edge yesterday. After I charged the cellphone for the first time and turned it back on there was this straight.
Jan 26, 2016 | Samsung UN60ES6100 60-inch LED TV
Distorted picture
You have a convergence problem.On this model you can change the convergence amp board which has the convergence IC's on it making it an easy repair.
Oct 06, 2007 | Samsung HC-P4752W 47" Rear Projection...
My samsung pcl6215r is having problems with the green screen. The red and blue colors are fine but the green wont line up with them and its making it out of focus badly. It doesn't appear to be dim or...
brent hardin,
Your description of the problem sounds like a convergence issue. You more than likely have lost the convergence ICs. They will need to be replaced and the convergence will have to be set. The green beam should not move. It is the standard which the red and green are moved to overlap. Since you have bow at the top and bottom I would replace the convergence ICs. I have a tip at which explains the problem, how to replace the parts and where to get the replacement parts.
Thanks for using FixYa and for the great rating. Great ratings will keep the experts helping to solve problems. Thank you.
Nov 17, 2010 | Samsung PCL6215R 62" Rear Projection...
Hi, My Samsung tv had the bad coloring issues described of as convergence/IC issues. Now it just has a red slanted line going across the top of the tv. In the self focus menu I get an error that says...
You can just replace the convergence board which for your model is part # BP95-00415C They are under $100 dollars and are just a plug in board. You should be able to purchase from
Aug 28, 2010 | Samsung HC-P4363W 43 in. TV/DVD Combo
Too much red in screen on Large Screen Projection TV
Try to adjust the convergence in the adjust menu. If this doesn;t help then you probably have a defective convergence board. one or more of the convergence ic's has to be replaced.
Jul 07, 2009 | Samsung Televison & Video
Green and pink shadow on my samsung 55in proj tv what can i do to fix it. i all ready fixed red and blue line but green is way off and i dont see any way to fix it
hi, this is the early signs of convergence board chip failure. you will need to replace this board in order to correct the collaboration feature. the convergence is responsible for regulating the RGB stream in you set. if it is malfunctioning, you will not be able to regulate the red blue green streams.
May 16, 2009 | Samsung HCL5515W 55" Rear Projection...
Akai/Samsung PT4299HD Convergence Problem
Ck 3 low ohm resistors 2.7 ohms they will be on same board as ICs.
Feb 13, 2009 | Akai PT4298HD Rear Projection Television
Samsung 55" model hcm5525w
its the convergence problem in your power supply board
please check out this links
for convergence board ics reparing it your self
and for convergence settings
Oct 05, 2008 | Samsung HCM5525W 55" Rear Projection...
Flashing red lines on Samsung hcl4715w rear projection
The convergence board wont correct the problem. You need to replace the two Convergence ICs on the sub board STK392-040 and you will be back to normal. See my response above. That site will help you get it back to normal.
Dec 21, 2007 | Samsung HCL4715W 47" Rear Projection...
HCM4215W Green convergence problem
Hi Greg,
Sounds like you have a bad convergence chip in the convergence board. Unfortunatly, about 80% of the rear projection sets I work on have this similar problem. I suggest that you change both chips ( there are 2 of the same ) and remember to use heat sink compound as this is why you not have the problem ( excessive heat destoys electronic components). Good Luck
NC Electronic
Mills, Wyoming
Dec 19, 2007 | Samsung HCM4215W 42" Rear Projection...
Samsung HCM4216W 42" Rear Projection Television Logo
59 people viewed this question
Jerry Greenberg
Jerry Greenberg
