Question about John Deere Garden
My snapper mower engine stalls after a short time
  • 26 Answers
That sounds like a carburation problem.a carb. Rebuild and fresh fuel should solve your problem.
Posted on Jun 17, 2014
  • 653 Answers
SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
Posted on Apr 07, 2009
  • 125 Answers
SOURCE: snapper comet rubber drive
Get a new drive wheel.
Put mower in neutral.
Stand mower on rear supports.
Remove the four bolts holding the old wheel.
install new wheel.
Posted on Jun 16, 2009
  • 138 Answers
SOURCE: I have an 80's model 10HP rear engine Snapper
Sounds like you have problems inside your gear box, The easiest way to check this is to stand the mower up on it's backend and try to turn one wheel and hold the other. You should be able to do this if you get any bucking or the rear end locking up your problem is going to be in the gearbox. FYI make sure you lock your clutch pedal down so the drive disk does not contact the friction disc
Posted on Aug 11, 2009
sawdust46694
  • 398 Answers
SOURCE: How much oil should my snapper rear engine 14 hp
The way i would do it. get 2 qts drain and flush oil out of engine. put the drain plug back in. remove the fill plug and fill with oil. i fill mine to the first thread under the fill and ckeck plug hole. keep the rest for adding if required.
Posted on Aug 30, 2009
  • 133 Answers
SOURCE: Snapper rear engine riding mower won't turn over.
First take off the engine shroud and clean the magnets on the fly wheel. Also the two little prongs that are really close to the fly wheel. I use fine sand paper or emery cloth.
Second take the sediment bowl off of the carb and use carb and choke cleaner to clean out any varnish that has formed. If the bolt that holds the bowl on has a little weep hole clean it also. You can spray entire carb and any little ports in it and use an old tooth brush to give it a good cleaning. Reinstall the bowl and then try starting it.
Good luck and let me know if this helps.
thanks roundo4
Posted on Sep 02, 2009
Drive Disc on bottom of engine intermittently freezes and engine stalls out and remains frozen for some time 17.5 HP B&S on Snapper 3317523BVE 7800254 - Snapper 33 Rear-Engine Rider
check for grass and other material that is wrapped around the shaft above the disc and acting like a brake
when it is clear check for failing bearings on the disc shaft
May 14, 2016 | Snapper Garden
Why does snapper rideing lawn mower stall when brake is relased?
Hi Jerry:
These machines have a lot of safety switches intended to protect the operator.
If no-one is sitting on the seat (activating that switch), releasing the brake will shut the engine off.
That's the first thing I'd be checking.
Hope this helps.
Cheers.
Nov 01, 2015 | Snapper Garden
Grease plug locatiom snapper rider
if it's a rear engine rider with a 28 or 30 inch deck the grease fitting is underneath the deck... If it is a rear engine rider, close the fuel off and stand the mower on end but for a short period of time only. This applies to ALL rear engine riders from Snapper up until about 2 years ago when they made a SERIOUS mistake and redesigned them
Sep 11, 2014 | Snapper Garden
Why will my Snapper riding mower NOT go into gear? forward or reverse?
what kind of snapper... RER ( rear engine rider ) tractor style, model number will help greatly here because snapper has made mowers since the dawn of time !!!
Aug 23, 2014 | Snapper Garden
Engine starts fine. Go to release the brake and it stalls. Snapper pro 61"
u have a bad switch or a wire touching somewhere maybe the sit switch
Oct 14, 2013 | Snapper Pro S200x 27 Hp Kohler 61"...
Snapper mower engine
The RER mowers have a vent on the filler cap that must be opened to allow air in to replace the fuel that is burned. They also have an inline filter that could be plugged, but allow enough fuel to slowly seep into the float bowl and run for a short time.
I would check those two things, look for crud in the tank at the outlet, and check the float bowl for being dirty or having water. A 1/2" wrench will remove the float bowl. Be sure to drain the tank, or catch the fuel that will flow with the bowl removed. If the fuel does not flow, it is also possible the fuel line has started to disintegrate internally, while looking perfect on the outside. Pull the fuel line from the carb inlet to check gravity flow from the tank.
May 25, 2013 | Snapper Garden
Lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Jul 25, 2009 | Garden
Garden Logo
19 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
