Question about Garden
Engine runs only for a short time then stalls
    Champion:
  • 279 Answers
Bad/old fuel (must be less than 40 days old) clogged fuel filter(if equipped), oil level correct?
Posted on Jun 03, 2014
2 Suggested Answers
  • 6 Answers
SOURCE: fuel problem
sounds like a fouled plug.
Posted on Jun 22, 2012
Run air for a short time, engine stalls, will crank but not start until sits for few hours run fine other times
When you run the air, the high speed fans should kick on. Check fuses and relays.
May 24, 2015 | Cars & Trucks
3800 engine
its either you have an incorrect ignition timing or a bad ignition coil
Jun 25, 2013 | 1995 Pontiac Bonneville
Fuel problem
Jun 22, 2012 | John Deere Garden
Black smoke from exhaust, rough idle, black soot on plugs
signs of a bad fuel pressure regulator-- the vehicle will run rough, the engine will not start ( usually in the mornings,) many times engine starts but stalls shortly after starting. a bad regulator can result in fouled plugs. replacement is only cure. 1- black soot on plugs-2-black smoke from tailpipe-3- running rough-4- stalling, good-day! repost if need be.
Aug 10, 2011 | 1994 Suzuki Sidekick
Would a bad oxygen sensor on my 1996 ford explorer cause my engine to die after driving it a distance?
no, the only way an O2 sensor might cause the engine to stall is if the heater shorted out with the power supply and every time we have seen that the engine will not run at all. if you have a stall hot check the idle control motor the year is right for a bad one.....HAVE FUN
Jan 25, 2011 | Ford Explorer Sport Cars & Trucks
92 lumina apv stalls after sitting short time
here are some signs of a bad fuel pressure regulator: the vehicle runs rough, the engine will not start(usually in morning) MANY TIMES ENGINE STARTS BUT STALLS SHORTLY AFTER STARTING. a bad regulator can result in fouled spark plus, and fuel milage will decrease noticeably. the only cure is to replace regulator. what makes it fail usually it gets a tear in the diafram and it cant maintain fuel pressure. hope this helps toolman,
Mar 18, 2010 | 1992 Chevrolet Lumina
Stalling and bucking!
Injectors, even if one is bad, the increase in resistance in the SFI system kills the other injectors too. When it starts to run bad, unplug injectors one at a time to see if it runs better.
Feb 23, 2010 | 1990 Buick Century
Ariens 2 cycle snowblower runs a short time then stalls.
That sounds like a float problem. When you tip it back it is raising the floats letting the fuel go through the carb. But when back at normal it closes the the fuel feed and thus stalling the engine check the float assembly.
Jan 22, 2009 | 2002 Husqvarna TE 400
1990 tempo stalls
try some STP gas treatment that contains a lubricant for the fuel pump and also have the fuel filter replaced
Aug 05, 2008 | 1990 Ford Tempo
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
