Question about Computer, Chip, Cruise Control for Ford Fiesta
Cruise control burns out transmission
Using cruise control on f 250 burns out transmission
    New Friend:
  • 41 Answers
I don't see that happing unless you are towing a house.
Posted on Apr 24, 2014
2007 Jeep Liberty traction control light starts flashing on highway and then can't use cruise control anybody know what it could be Ty
that is normal for cruise, ( its goes dead, when there are other dangerous conditions, or jeep gets lawsuit like TOY did)
did you scan it yet.
that be first. (after checking fuses)
look for ABS failures. or Traction control)
or get car serviced?????? like oper guide stated, for this error?
Jul 25, 2015 | Jeep Cars & Trucks
Tip
ALARM, CRUISE CONTROL, and STEREO Wiring Color Codes for 1996 Honda Civic This...
This FixYa Tip is for the purpose of installing an Alarm, Remote Starter, Cruise Control, and / or Car Stereo into the vehicle listed in the subject line.
The wires listed are the ones you will need to successfully complete the task.
Some vehicles require additional relays and / or modules to bypass factory security. If they are required - it will be in the NOTES section below the wiring colors.
The following FixYa TIP is good for all Honda Civics for the following production years:
1996
STEREO WIRING COLOR CHART:
Constant 12V+: Blue/White
Switched 12V+: Yellow/Red
Ground: Black
Illumination: Red/Black
Dimmer: n/a
Antenna: Driver's Pillar
Front Speakers:
Left Front (+) Blue
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers:
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
NOTES: Retain Keyless entry with secondary Harness Listed Below
Additional Accessories:
Metra Brand Dash Kit: 89-30-7891 - 99-7891 - 99-7898
Metra Brand Wiring Harness: 70-1720 W/Keyless Entry # 70-1720T
Metra Brand Antenna Adapter: n/a
ALARM / REMOTE START WIRING CHART:
Constant 12V+: White - Ignition Switch Harness
Starter: Black/White - Ignition Switch Harness
Ignition: Black/Yellow - Ignition Switch Harness
Ignition 2: Yellow - Ignition Switch Harness
Accessory: White/Black - Ignition Switch Harness
Tach: Blue - Coil
Brake Switch: Green/White - Brake Switch
Trunk Pin: Blue/Black - (-) Driver's Kick Panel
Parking Lights: Red/Black - (+) Driver's Kick Panel
Head Lamp: Red/White (L) Red/Blue (R) - Steering Column
Hood Pin: n/a
Door Trigger: Light Green/Red - (-) Above Fuse Panel
Door Lock: Green/White - (-) 2 pin connector taped to blue connector behind fuse box
Door Unlock: Green/Orange - (-) Module Behind Radio
Horn: Grey - Steering Column or GREEN connector behind radio
NOTES: - none -
CRUISE CONTROL:
Constant 12V+: White - Ignition Switch Harness or Use Hot Side of Brake
Switched 12V+: Black/Yellow - Ignition Switch Harness
Ground: Use Chassis Near Cruise Control Module
Hot Side of Brake: n/a - Brake Switch
Cold Side of Brake: Green/White - Brake Switch
Tach: Blue - Coil
VSS Wire : Blue/White - Driver's Side Dash Footwell, Grey connector.
NOTES: PPM - 4000PPM
ROSTRA Control Arm # 250-3421/250-1483
ROSTRA Throttle Adapter #250-4249
Vehicles with Manual Transmission require Clutch Switch.
Some vehicles may require a speed signal generator and/or other parts/adapters not listed above.
Rostra® Cruise Control module switch settings may differ if you use a speed signal generator or magnets and a pick up coil.
Thanks for using FixYa!! Please see my other tips on GPS, Car Audio, Large Appliances, and more.
on Apr 03, 2010 | Honda Civic Cars & Trucks
99 f 250 cruise control
check for 3 things, pay attention to see if , when your no not using the cruise control, do you leave it on. check and see if you have frayed wires, that has the possibility of grounding out, also check the cruise control circuit for damage. start with those.
Apr 23, 2014 | Computer, Chip, Cruise Control for Ford...
My cruise control wont engage in 97 cavalier
The best suggestion would be that the cruise control needs replaced. The problem could be in your column but this is rare. Cruise controls can only take so much abuse and many people are unaware of the abuse they give. Constant on and off or accelerating manually while cruise control is on can burn up your cruise control.
Jun 10, 2011 | 1997 Chevrolet Cavalier
2005 f250, 6.0 diesel overheats when towing a 8000lb camper with the cruise control on
Turn cruise control off. You should never use cruise control when pulling a heavy load. It puts more strain on the transmission and engine.
Aug 27, 2010 | 2005 Ford F 250 Super Duty
I have a 2003 f-250 sd 4x4 i just replaced the transfer case motor for the third time took it to ford and they said the transfer case motor was bad yea it might be bad but the reason its bad is because for...
You might check into the old Cruise Control Recall. If your model needed the repair I read some other goofy things happen after the truck was repaired.
I believe it was on the internet Blog for F150 trucks (Yours has same parts) that the 4x4 indicators and transmission controls are messed up because the Cruise Control repair does not fix all. Brake lights do not work and so on.
Do an internet search and when you find the articles copy them and bring them to the Dealer. This defect could be frying your parts. Also if you are not the original owner of the truck check the gear ratios on the front and rear axles to match.
Apr 05, 2010 | 2002 Ford F250 Super Duty SuperCab
Cruise control not working
chk your vacuum line that go to the cruise control unit start there
Jan 15, 2010 | 1993 Dodge Ram 350
Loosing power at cruising speed
have you had the transmission flushed? it seems to be caught in a limbo. where the calibration of the speedo and the transmission are not compatable. Now as wierd as that seems it happens usally like when going up a hill if you have a manual trans. and cruise locked in. it cant hold that speed and moves to a different speed if you dont down shift. Or perhaps your cruise control cable is slipping. is it vacume over mechanical? pop the hood and make sure all your hoses to cruise control are tight and no leaks.
Feb 12, 2009 | 1998 Mercedes-Benz C-Class
Xtype
Hi,you might try just to disconect your battery for five minutes ,this will reset your computer and may solve the problem, Good Luck
Jun 27, 2008 | 2004 Jaguar X-Type
Computer, Chip, Cruise Control for Ford Fiesta Logo
71 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
