Question about Westinghouse Kitchen Ranges
I have Westinghouse oven and on the top of this oven stove is also attached.i covered top stove with foil paper to be saved from stain but today I noticed by removing paper that a big burnt mark is there I dint know how to remove it now?
  • Westinghouse Master
  • 3,368 Answers
I believe the burn mark is some of the foil paper that got hot. I would try a wet and soapy rag placed on the stain and kept wet for several hours then with a scotch bright carefully see if it will come off. This may take several tries.
Posted on May 01, 2014
  • 1462 Answers
SOURCE: bosch range model #hes236
there is no easy answer to this except elbow grease. however, i often put aluminium foil on base of oven with no problem. did you leave it there during self-clean when temp is very high?
Posted on Mar 29, 2007
SOURCE: tin foil baked onto bottom of gas range oven
rape it
Posted on Oct 09, 2008
SOURCE: frigidaire compact 30 elec. stove.
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
Posted on Dec 04, 2008
tzweeb
  • 318 Answers
SOURCE: Oven vents on front are stained and ugly. How do I clean them?
sorry but you wont be able to remove the "stain" what has happend is the paint used by maytag has become discolored from the oven vent heat and the only way to correct it is to replace the panel. they are available but for about 80 bucks. you could try to paint the panel but it will do it again.
Posted on Dec 28, 2008
SOURCE: How do i clean my flat stove top electric stove
There is a special solutiun to clean electrc stoves
Posted on Jan 18, 2009
How do I wire Westinghouse oven pon 663 to stove top Westinghouse pon663' ive piggybacked stove top to oven but the stove top is not getting as hot as it should
I shouldn't be like this, but what the hell are you doing messing around with something you don't understand and could kill someone!!??
Apr 04, 2016 | Kitchen Ranges
Hi, I have a wonderful Maytag speckled black smooth top stove. Over Christmas someone caused a big (2 " diameter) stain. I've tried everything to get it out. is it possible to have a new ceramic...
Ceramic cooktop cleaning tips - especially for 2-in difficult-to-remove stain:
Best Idea: "Cerama Bryte" + plastic scrubbie
Cerama Bryte is specifically designed for this cooktop, works on stains, avail at Hardware Stores.
Other ceramic cooktop tips:
1. "Soft Scrub" plasic scrubbie
2. Comet cleanser + sponge
3. Single-edge razor blade held at 45-degree angle - scrapes off material
4. "Cook Top" cleaner (WalMart) + Mr. Clean "Magic Eraser" abrasive pad
5. baking soda on damp sponge
6. soak stain for awhile with Formula 409, Fantastic, or citrus degreaser ("Orange Clean")
7. ammonia + water - in a 1:1 solution
8. Easy Off oven cleaner - it foams on the stain and does the work for you - let it sit 20 min.
9. the nuclear option:
Cerama Bryte under a plastic scrubbie under an orbital sander with sandpaper removed
(just the pad down on top of the scrubbie), after pre-soaking in Citrus Degreaser.
The sander is a power tool which only saves your joints, and speeds up the chore.
Jan 17, 2011 | Maytag MER5775Q Electric Kitchen Range
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Ihave a ge ceramic top stove,everytime I self clean the oven it stains in the front of the oven get worse.I have tried everything.My stove is bisque and the stains are an ugly yellow.
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Jan 06, 2010 | KitchenAid KESC307 Electric Kitchen Range
Cant get food stains removed from top of stove i use a special cleaner and a special scrub and it still doesnt come off. it can be any kind of stain. the new stove tops are very hard to clean. any help...
I recommend a product called of all things "barkeepers friend". It comes in a can with holes in the top to sprinkle the powder out of.
Moisten the stubborn area and sprinkle this product on the stain then add enough water to make a paste. Make sure the paste covers the entire stain. LET IT SIT FOR AT LEAST TEN MINUTES. Then rub with a wet cloth. It always works for me and I have a black stove.
Jul 27, 2009 | Stoves 12 in. (1248-1100) Electric Cooktop
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
Dec 28, 2008 | KitchenAid KESC307 Electric Kitchen Range
Self-cleaning heat stains on the front facing panel
Use DeBruce polish. We Use Debruce Polish on all our cooktops and ENAMELED SURFACES. Debruce also works on stainless steel polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Nov 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Jun 07, 2008 | Ovens
Kitchen Ranges Logo
65 people viewed this question
Top Westinghouse Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Westinghouse Kitchen Range Expert? Answer questions, earn points and help others
