Question about Samsung SW62ASP Top Load Washer
Were is the valve
The water is coming but doesn't fill up,can be the valve,thanks
  • 957 Answers
The water valve is located where you hook up the hoses to the washer in the back of the washer.
Posted on Apr 23, 2014
Maytag bravos doesn't use enough water
see this causes and fix it.
God bless you
Water comes in very slow This is usually a water valve problem or an inlet screen blocked. 1st check your inlet screens of your water valve. Turn your house water valve off to the washer, undo the fill hoses and inside the water valve, you will see a silver screen. If the screen is filled with water deposits, clean it out and re-install into valve. Don't forget to check your fill hoses also, some hoses come with screens that also may be clogged. Your cold water valve usually clogs before the hot water valve, all that sediment settles in your hot water tank and not in the screens. If you are on a well system, your screens usually clog more often. If your screens are good, then most likely your water valve needs replacing.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool Dishwasher Model Du850SWPB3 Changed out Water valve, float switch, Still doesn't fill with water. D/w runs in all cycles , just NO WATER.
What ya need to check is for power coming into the water valve from the control board by using a mulitmeter set to measure ac volts and when the dishwasher is running...during the times the unit is supposed to fill their should be power into the water valve.
If ya do not have power into the valve the control is going to be the problem,if ya do indeed have electric power into the valve during the fill times ya need to check the house water supply and make sure GOOD water pressure is available at THE VALVE
GENE
Sep 30, 2011 | Whirlpool Dishwashers
I fill the tank up, but it seems too light to be full, so I drain it and it only has about 1 gallon if that in it. Whats wrong?
How are you filling the tank, and is this in an RV or what? Open pressure relief valve when filling and when water comes out pressure relief valve, you know your close to full. If it doesn't come out there when valve is open, check for by-pass valve(s) in wrong position and not filling the tank.
Aug 11, 2011 | RTO Atwood Water Heater - 6 Gal LP
Ice maker does not produce ice, it was clogged with ice. so i fixed that . the tube coming down from the top was what was clogged frozen . red light is flashing twice repeatadly. need info to fix. thank...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 27, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water from ice maker running through freezer and on to floor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and divert the water. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Dec 03, 2009 | Amana Refrigerators
Whirlpool GR2FHTXVQ00 fridge. Water dispenser
You can thaw out the fill tube and replace the inlet valves.
Oct 13, 2009 | Freezers
The water dispenser unit has a tube coming into the back of the fridge. Anytime you dispense water, it will also leak from this tube in the back. Also, about once a day or so, it will sound like water is...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. You can thaw the fill tube and replace the water inlet valve.
Sep 27, 2009 | Jenn-Air JFC2087HRS Side by Side...
Not making ice
Sep 24, 2009 | GALAXY Microsystems 25.4 cu. ft....
Ice maker fill tube froze up,tube has no blockage.
Sep 14, 2009 | Refrigerators
Our icemaker does not fill with water
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung SW62ASP Top Load Washer Logo
19 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
