Question about Onkyo Audio Players & Recorders
Cfm hi i buy a av receiver 470 but it dosent work well, te volume it has to be over 30 to became to listen something
    Genius:
  • Onkyo Master
  • 1,054 Answers
That's normal on today's receivers.
Posted on Apr 23, 2014
How do you raise the volume? Mine is weak with it all the way up.
With the deck off av off, press setting, audio, menu will come of you need to set the amp gain to high. Volume will now go to 50 not 30. Cheers.
Jul 28, 2014 | JVC KW-AVX740 Double-DIN DVD/CD AM/FM...
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
How to hook up cable to the sony trinitron tv?
In most cases you will take the Audio/Video out of TV (This is if you are trying to listen to your TV sound with your AV receiver. Plug in red and white to red and white on the back of your receiver where there must be a TV-in plugs on it. Turn down the volume on your TV. You only plug your Yellow wire if you want to control your video through your A/V(Audio-Video)Receiver.
This will allow you to listen to your TV in an amplified volume.
If you have a DVD Player and you hook it up by either Co-axial or Optical cable now you can hear real home theatre.
Please get back to us if you have any further query or else accept the solution.
Thanks for contacting fixya.com
Nov 01, 2010 | Televison & Video
I have a Yamaha RX-V992 receiver and I would like to install a Bose 901 active equalizer Where will I connect this to my receiver? Thanks, Mark
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. Assuming you want the 901's as part of your multichannel sound, you need to get a dedciated power amp just for the 901's and you don't need to use a Tape Monitor loop.
You can draw the Front Left and Right signals out of the Main Out connectors, go into the Active EQ's Amplifier IN Connections; then Out of the EQ's Amplifier OUT Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
Run through the speaker level settings with the new amp at a suitable volume setting (if it has a volume knob; many don't). Then leavethe amp volume control alone.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed and control the volume on everything.
This is roughly how I do it.
Mar 17, 2010 | Audio Players & Recorders
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
My speakers wont work suddenly unless I am using my headphones
Make sure in the volume mixer that it is using the right sound device. You most likely have it set to the wrong device output. When you plugged in the headphones in kinda automatically switches, but to use the speakers again you have to do it manually. Just hook up a cheap av receiver to your computer and use this headphone input instead. a 100$ 5.1 av receiver beats any pc speaker system.
Aug 01, 2009 | Toshiba (4CH-VOUT) Sound Card
No sounds
Test one speakers at other amp to ensure its working. Amp is going into probable protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If sound connect speakers and av cables one by one and test each one on its own until amp switches off, or no volume. Investigate from there were prolem is.
Feb 25, 2009 | Pioneer VSX-D710S Receiver
Volume high but no sound only a very low static sound
Make sure the unit is not swiched to tape monitor. Check to see if all inputs and outputs are wired properly. Unplug unit and let it sit unpowered for a half hour to reset micro-processor which may have locked up. When you power it up again, listen for click of speaker relays. Make sure to turn volume down BEFORE you power up. If none of these work, take unit to pro tech for check up. It just might be a simple fix, cheaper than replacement. Good luck.
Apr 02, 2008 | Aiwa AV-D67 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Audio noise on cold start
hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Mar 19, 2006 | JVC AV-32750 32" TV
20 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
