Question about Riso Office Equipment & Supplies
I have a Risograph GR3770 and when it prints the middle part on the paper is light. Any suggestions?
4 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Paper tray will not lift on a GR3770
either the motor is not turning to lift it up or the gear is broken, do you hear the motor turning when the tray is pushed in? take the tray out and look in the back to see if there is anything blocking it also.
Posted on Sep 16, 2008
  • 55 Answers
SOURCE: Risograph GR3770 - cannot pul out the drum, Error
This solution is ONLY for pulling out the drum.
Open front door. If you look at the metal housing below the drum you will see a plate mounteg with two screws. Get it off and you will see a small lever. Turn it right to loosen the drum. Be extremely careful when pulling out the drum. If the drum is not in zero-position it might be a bit difficult (e.g. have a look at the master clamp). Please note that it may be difficult to insert the drum again.
Posted on Apr 27, 2011
vladmototole
  • 226 Answers
SOURCE: My HP 2100 keeps stopping in the middle of printing saying out of paper when paper's in the tray. Any suggestions?
the sensors are dirty, take it to a repair technician to clean the printer.
Posted on Nov 21, 2011
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
A risograph 3770 doesn't print when I say 'test print' and says there is a jam
Maybe it is just some dust at the sensor in the exit path! Clean the sensor in the small hole between the exit belts with a brush ...
Aug 23, 2012 | Riso RZ220 Duplicator
Risograph GR3770 - cannot pul out the drum, Error code T14. How can I pull it out :)? thanks
Jan 03, 2011 | Riso RZ220 Duplicator
Anybody know if Risograph GR hd black ink is ok for use in Riso FR machines?
Short answer is no. RISO GR HD ink is only compatible with a GR3770, a 600 dpi machine.
Mar 05, 2010 | Eagle Signal Br1 30min Reset Timer
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
RZ 220 Risograph error code A-16-525 after paper jam indication. No jam was present.
The master is stucked on the print drum,open print drum remove master and try again.
Let me know for futher help.
Jan 26, 2009 | Riso RZ220 Duplicator
Sep 16, 2008 | Riso RZ220 Duplicator
Riso GR3770 Paper Jam, Check paper feed
Sounds like you forgot to plug the High voltage transformer or a sensor back
Dec 11, 2007 | Office Equipment & Supplies
18 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
