Question about Symbol MC3090 Mobile Computer
Wavelink update 5.1 to 7.1
Is there a way to update Wavelink Telnet Emulator from 5.1 to 7.0.02 without having to reenter all the Wavelink licenses. I tried to update a PDT and it worked. But the Wavelink license of version 5.1 is no more valid for the Wavelink version 7.0.02.
The idea of updating the software is to get real info of the RF signal strength on the PDT screen. With the version 5.1 Wavelink and a PDT 3090 the RF signal strength is misunderstood by the Wavelink software.
I'm using a 3090 PDT with Windows CE 5.0 installed.
  • 97 Answers
Re: Wavelink update 5.1 to 7.1
Unfortunately you wil need to purchase new licenses for wavelink if you want to update to their latest unless you have a license maintenance contract with them, in which case the upgrade would be free.
Posted on Mar 26, 2009
  • 53 Answers
The prelicensing that comes with the symbol units is only for version 5, to upgrade you need to buy a license. its part of the marketing
Posted on Nov 09, 2007
0 characters
3 Points
Camera not reacting
Motorola Customer Phone Number Shortest Wait Best Support
Phone Number
  • Talk to a Human
    Press 2 then # then 5 then 5
  • Call Time
    Average Wait: 17 mins - Mon-Fri 7AM-10PM; Sat-Sun 9AM-6PM CST
Motorola Calls You Instead
Mar 21, 2014 | Motorola MC65 Data Collection Terminal
How do I type underscore character on MC9090 keypad?
If using Wavelink, you can type it by pressing SHIFT, Blue Key, N
Apr 05, 2012 | Symbol Motorola MC9090 Mobile Computer
Unit will not boot. Screen reads
"Check serial Input" is just part of the cycle on boot up. It checks for a key press on boot up so that it can access a hidden menu. A cradle, serial null modem cable and hyper-terminal is required to bring up this menu
You can try and re-install the operating system.
Download the latest image from Intermec (you will need to register) and then load the image onto an SD card.
Remove the front cover just above the scan engine; 2 slot head screws and insert the SD card. Cold boot the device. Take off battery and hit the reset button a few times. Re-install battery.
Image will begin to reload.
Detailed instructions are available with the download.
NOTE: The latest image downloads from Intermec not longer have the Telnet application pre-installed. If you require the telnet client then select a previous version, but then also not that there are usually 2 versions EX25 and non-EX25 scan engine type.
If you need any more help then please do not hesitate to contact us:- or TEL 01202 620955
Oct 29, 2009 | Intermec CK31 Portable Terminal
We have the PDT 6846 scanners for our warehouse and I am needing to know that configuration password is? Thanks
default passwords for these guns are:-
case sensitive.
or TEL 01202 620955
Oct 20, 2009 | Symbol PDT 6846 Portable Terminal
Connect PDT6846 to Wavelink COM Server
you can get it from they are quite good and still offer the files for the older terminals. however, you may need to get a license from them in order to use it on the pdt.
Jun 05, 2009 | Symbol PDT 6846 Portable Terminal
PDT 6846 not communicating with host
It is timing out. You need to reload the sofware. I have all versions depending on what you need. You can always contact me by phone or email 630-622-2024 Please visit our website
Apr 29, 2009 | Symbol PDT 6846 Portable Terminal
How do you incorporate the Symbol PTC-960SL with a system?
To answer your question there are a number of ways to use the PTC960SL in a system. The main 2 ways are by batch process or Telnet session.
The batch process requires a custom program to be written for the device either in DOS or TCAL. This would then produce a single file or a set of files which would then be downloaded to a host pc using a cable or cradle.
The more common method is to have a Telnet Server running and the PTC960SL logs into the session using a Telnet client, AirvuAnsi for example. The Telnet Server holds the menu structure and database manipulation for the PTC960SL. The PTC960SL only emulates what’s running on the server. A permanent connection is required to keep the session open. This is done by either using a stable wireless network or a network controller which keeps the sessions active even if the hand held device goes out of range. This would mean the PTC960SL would have to have a wireless card within it.
Apr 12, 2009 | Symbol PTC 960SL Portable Terminal
Peoblem Loading the main app
Next you will need to load the application that you require. LWP and UPD just contains part of the OS and the radio drivers. What application are you planning to use? Telnet application?
Apr 03, 2009 | Symbol PDT 6846 Portable Terminal
My Intermec CK31 just hangs, it scan and there is a sounf beeping but the touchscreen is not working and even the keyboard.
Sounds like you could have a main logic board problem. Try restoring computer to factory defaults from the intermec settings.
Mar 06, 2009 | Intermec CK31 Portable Terminal
Symbol MC3090 Mobile Computer Logo
420 people viewed this question
Top Symbol Data Collection Terminals Experts
Gareth Cockram
Gareth Cockram
Vish Iyer
Vish Iyer
Are you a Symbol Data Collection Terminal Expert? Answer questions, earn points and help others
