Directions for old Sony Vor tape recorder
Can't remember how to operate Sony Voice Operated Recorder that uses small tapes. Uses Microcassette tapes. Want to use it. Any help is appreciated.
issy2
  • 460 Answers
SOURCE: sony m 750 V microcassete corder
Since it was not used for too long the belt inside would have been wornout, so u need to replace the belt. And a basic service from a near by electronics repair shop will definitely solve ur problem.
Thankyou
Posted on Feb 10, 2008
  • 3 Answers
SOURCE: transfer recording from tape recorder to computer
Use a cable running from the headphone jack on the recorder into your PC microphone jack. Then you can capture the audio using Windows MovieMaker software that comes with Windows XP. I have done this and it worked perfectly.
Posted on Jun 10, 2008
  • 7 Answers
SOURCE: Lanier VW-260 recording speed
Should be a tape speed switch on that unit under the door.
Posted on Jul 16, 2008
starstruck10
  • 3 Answers
SOURCE: Microcassette recorder is eating my tapes
Try cleaning the heads with a head cleaner and making sure none of the parts have become loose due to extensive use.
Posted on Jan 16, 2009
Hardtack
  • 46 Answers
SOURCE: Taped sounds are deteriorating and disappearing.
If the tapes you are using are indeed brand new, then I would assume that the heads on the tape recorder are either very dirty or damaged. Try using a q-tip dipped in alcohol to clean the heads of the recorder. Clean the rollers too and pins that guide the tape. If that doesn't work it may be a component problem. And may be cheaper to replace than repair.
Posted on Feb 10, 2009
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
The voice recording fades in some parts
- Possibly the recording head may need cleaning and demagnetizing.
- The tape itself could be damaged or even folded.
- It may be also because one or both backup pads are missing on the microcassette.
There should two pads behind the tape as shown below.
May 31, 2011 | Sony M475 Handheld Cassette Voice Recorder
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
The speed of the recorder
Difference between 4cm and 1.2 cm speed is just like SP and LP speed in VCR etc. 1.2 cm speed selection will give you more recording time on same cassette.
VOR stand for Voice Operated Recording, if you enable this vor option, tape starts recording only at that time when sense any voice and will remain Pause if there is silence.
This option will also give you more recording time at same cassette by skipping empty space.
Sep 17, 2008 | Sony M-675V Handheld Cassette Voice...
May 23, 2008 | Lanier 260T Desktop Cassette Voice...
Sony m 750 V microcassete corder
Thankyou
Jan 15, 2008 | Audio Players & Recorders
26 people viewed this question
 Grubhead
Grubhead
