Question about HP Photosmart C4400 series
My printer has new carthridges prints from computer but does not make copies
The message in the printer when i push Star Copu (black or color) I get a message SCAN FAILURE UNABLE TO COPY OR SCAN
    Scholar:
  • 126 Answers
Try scanning from MS Paint or Acrobat & see if it works. If it does, the HP/Vista software is probably at fault. If not, the scanner is probably faulty.
Did it ever work or did you just plug it in? (Did you load the correct drivers?)
Posted on Apr 23, 2014
My hp photosmart c4400 wont make copies
Printer will not work without Color cartridges. You need to install color ink even if your using Black print only.I work for HP but my posts and replies are my own.
Make it easier for other people to find solutions, by marking my answer with \'Accept as Solution\' if it solves your problem.
Click on the BLUE KUDOS button on the left to say.Or Still having Problem Then follow Us For
HP Support "Thanks"
Apr 22, 2014 | HP Photosmart C4150 All-In-One InkJet...
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I had been out of color ink for a few months, so just printed using black&white mode. I installed a new color cartridge, and the computer is not acknowledging that a new cartridge is in. It will only...
Start, control panel, printers, your printer, printer preferences, advanced. Uncheck the complete-a-print boxes and also check to make sure the print in black & white box in unchecked.
Rick
Sep 12, 2011 | Dell 926 All-In-One InkJet Printer
Error message:right (color) carthridge missing
Maybe the cartridge is not seated well in the cartridge carrier or just needs cleaning. Follow the instructions on this link to the Lexmark website on How to Clean the Print Cartridge Nozzles and Contacts Manually. If this doesn't help yet your cartridge is a genuine Lexmark cartridge, I suggest you contact Lexmark Technical Support for further assistance. Genuine Lexmark cartridges shouldn't cause you that much trouble.
Jun 09, 2010 | Lexmark X7350 All-In-One InkJet Printer
Hp printer won't copy
the ink inside of the cartridges is gelled.
Feb 06, 2009 | HP Office Equipment & Supplies
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Black ink does not print
I have a problem about my printer here. it doesnt print black color even if i replaced it with new cartridge...anyone have solution about this pls help....joy
Feb 16, 2008 | HP Photosmart C3150 Printer
Cartridge problems
Clean the heads, printer is not reading new cartridge or refilled cartridge. You may also have a paper jam if alignment is affected. Check for little jams, post back if no go lilacgerry xxx
Dec 28, 2007 | Lexmark X4270 All-In-One InkJet Printer
Hp printer deskjet 920c
My HP deskjet 920c won,t stop blinking, eventhough I have changed the
color and black and white carthridge. It will not print.
Oct 23, 2007 | HP DeskJet 920c InkJet Printer
Computer doesn't print color
Have you tried to reinstall the printer driver?
Jun 29, 2007 | HP OfficeJet G55 All-In-One InkJet Printer
Computers & Internet Logo
67 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
