Question about Amigo Health & Beauty
When i press to go the amigo goes but it like stutters real fast like something is catching it..
Cant push the amigo when i press the release lever and it stutters when i go forward
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 67 Answers
That is typically a motor issue. It could be a few more specific things such as; transaxle, parking brake or motor brush. All of which can be quite expensive to replace.
Posted on Apr 30, 2014
Amigo problem
I had this problem similarly on an older trike I owned and still do.
If it stutters as it goes forwards, there is probably an intermittent connection between the wig-wag (the part you push to make the scooter go) and the rest of the electronics. It could be as simple as a loose wire or the whole wig-wag might need replacing. I'd recommend you take the scooter to your local dealer and have them reproduce the exact problem you're having and hopefully they'll be able to recommend a fix.
Apr 22, 2014 | Electric Strider Mini 4 Wheel Mobility...
Explorer hatch release
There is a spring in the latch assembly that pulls the catch open when you press the button/lever. It may be broken which will need the unit to be replaced. Use something like a round blade of a screw driver and open the catch as you press the button/ lever.
May 11, 2013 | 2003 Ford Explorer
My 1995 jaguar starts but i cant get the shift to work
with the ignition on press the brake can you her aclick from the gear lever area i suspect not the lever is more than likely stuck in park the soleniod that releases the gear lever
is not being powered the most likely cause is the brake light switch on the brake pedal you can get it out of park by removing the little plug near the gear lever and pushing something like your key in to the hole to manually release the gear lever there is also a relay under the j gate that may be faulty/dislodged or the release soleniod itself faulty
Mar 27, 2013 | 1995 Jaguar XJ6
Bentley gt bonnet release
Pop opens the hood
Pull or push the hood release until you heard the hood pop opening whether the hood release is inside your vehicle. However, you need to look anywhere for 2013 Bentley Continental GT W12 and through the grill, carefully feel under the grill and finally behind the bumper to find a lever, arm, button or handle if the hood release is apparently at the front. And then press, pull or push it from the front to back, side to side until finally it can release the hood.
Even though the hood will just open a tiny, it will possibly be stopped by a safety catch which is a metal lever. You should release the hood when you pressed one way or other in order to open all the way. When you are driving, this gizmo accidentally avoids opening the hood.
Raise the hood fast with one hand
Feel along the station between the grill and the hood for the safety catch with the other hand. The rest of the way is to release and raise the hood.
If it is necessary, secure the hood
It is fine if the hood can stay up easily all by itself for 2013 Bentley Continental GT W12. Only if it does not like that, you should have to find a hoop prop which is a thin and long metal rod attached to the bottom edge of the opening hood or to the underside of the hood. In other words, either lift or lower the rod and fit the finishing of it into the slot which is provided to hold it.
https://electronicshelponline.blogspot.com/
Mar 03, 2012 | Bentley Continental GTC Cars & Trucks
S864XOP Ford Fiesta Zetec cannot open bonnet - when I pull release lever under steering wheel bonnet does not release completely (when push down on bonnet I can hear the catch click closed). Any...
get assistant to push down on bonnet whilst you pull the lever ,then once you pull back the lever and hold it back they try to lift it so it clicks up a bit then you open it by the safety catch
Apr 24, 2011 | Ford Fiesta Cars & Trucks
I laid down the rear seats to move some stuff with the car, but one of the seats seems to have locked down and i cant find a catch to release it
Hello and welcome to FixYa!
Please try this, push the back rest to it's full then release the lever. This will unlock the back rest.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 15, 2011 | Daewoo Lanos Cars & Trucks
I need to put more memory chips in. where do I do it--the monitor or tower? how do I open the cover?
The memory goes in the tower on the motherboard. Most cases come apart by unscrewing screws on one side of the back. Some have a little lever on the back that, when pushed, releases the side of the case that is opposite the motherboard.
Some cases have a button (large or small) that is recessed into the top and maybe the bottom of the case. When pushed these buttons release the catch inside the case and you can swing it open.
Once open, you will see the memory slots. By pressing the catches on each end of the memory chip, you can release them and lift the chip out. Note the position of the key on the chip socket and the slot in the memory chip when reinstalling memory.
Jan 01, 2010 | Compaq FS7600 17" Flat Glass Monitor
The hood will not release to open. I released the inside lever & the hood poped up a little. In the grill there is a plastic "T" lever that you pull to release the hood. I have pulled it hard & the...
So I gather that the release inside the car has release the hood's primary catch, but the T handle is not release the secondary catch to allow the hood to fully open.
If this is the case, take some lithium grease or WD-40 (lithium grease is much better and lasts much longer) and spray it onto the catch assembly.
Try pulling on the T handle some more after a few minutes of the grease soaking in and see of that releases.
If that doesn't work, then take a long flat screw driver and press it against the catch gently hit the screw driver with a hammer (you should be trying to push the catch towards the driver's side of the car)
You may need someone to be pulling on the T handle as you hit the catch with a hammer. I actually had to do this with a jetta before....
Nov 20, 2009 | 1998 Volkswagen Passat
Battery is low, Hood release will not open the hood
You'll need two people for this fix:
Have one person sit in the car and be ready to pull the release lever. Have the other person outside in front of the hood. Count to three together, and on "three", have the person outside push DOWN on the hood as hard as they can while the other person simultaneously pulls the release lever. Keep the release lever pulled as the person outside lets go of the hood. This may take several attempts to get the timing right. In this situation, what is usually happening is that the spring-loaded hood is pushing up against the release catch hard enough to stop it from moving when the lever is pulled. Pressing down on the hood relieves this tension just long enough for the catch to let go.
Sep 24, 2009 | 2000 Cadillac Escalade
Seat locked down
usaully they have on a lever on the side of seat push/pull
Mar 28, 2009 | Amigo Health & Beauty
Health & Beauty Logo
64 people viewed this question
Top Amigo Health & Beauty Experts
James Rose
Level 1 Expert
Tom Chichester
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
