Question about Moultrie MFH-DGS-100V2 Digital Camera
Stuck on date
New battery stuck on date and time
How do I fix my CMOS Battery Low error so I can correct the Time and Date since it's stuck on the 01/01/2004 date and won't save in my BIOS?
This is usually a very short and sweet step to complete.
After you have changed the CMOS battery over to a new one all you should have to do is go into BIOS set the date, the time and the year. Save the settings in the BIOS, exit and restart the computer.
You have to set the date, time and year in the BIOS first then change it on the desktop.
The proper battery to use for CMOS is a C2023 coin cell battery.
Hope this helps
Jan 12, 2015 | Lenovo 3000 J205 9686-A12 Desktop Pc -...
Advent 5431 date keeps changing back to 2008
IS your TimeZone is Correct?
Right click on your clock, choose Adjust Date/Time.
Click Time Zone Tab. Make sure your Time zone is correctly set.
Boot into the BIOS (setup) screens and check the date and time there. If the date is off by years then that verifies you need a new CMOS battery. Do not confuse the CMOS battery with the large external battery you run the computer with.
Jul 25, 2012 | Advent Netbook
My system time and date is not set
Go into the BIOS settings then to the Date and Time and set the Date and Time, Save the settings and Exit.
IWhen you boot up later and the Date and Time is incorrect then the BIOS battery is flat and a new replacement battery is needed. The BIOS battery keeps the laptop's configuration plus the Date and Time settings unless the battery is flat.
Apr 16, 2012 | Dell Inspirion Computers & Internet
Laptop date and time setting get disturbed automatically when i reboot my laptop
When you boot up and the Date & Time is wrong then you correct the Date & Time, then when you shut down and boot up again the Date and Time has changed. This is an indication that the BIOS battery is flat and you need to replace the BIOS battery. Install a new BIOS battery, go into the BIOS setting and set the Date & Time etc. and the new battery will keep your settings stored in the BIOS.
Feb 09, 2012 | Dell Inspiron 1464 Notebook
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
Feb 05, 2011 | Canon PowerShot A590 IS Digital Camera
The date and time are changing by themselves
I had the problem with locking on chrono function. Then I decide to replace battery, after replacement watches become crazy, hands were moving all the time, it was impossible to stop it. I remove the battery and leave watches on the table for 5-6 days, then install the battery again. No problem any more, all functions are available. May be you have the same kind of problem. Good luck!
Jul 02, 2010 | Tissot T-Touch T33759851
CoolpixS51 camera stuck on set time and date
Not 100% sure about this model, but most have another battery in the camera for the clock functions. That battery could be low.
Try looking in the manual for the clock battery and pull that and replace it. See if that helps.
Jul 13, 2009 | Nikon COOLPIX S51 Digital Camera
Date/time
there is a problem with the cmos, it needs to cleared and a new cmos battery also, if the batterys dead it can't remember the date, if its stuck on the time and date the cmos needs clearing so it can boot
kind regards and please don't forget to rate us
Dec 12, 2008 | IBM ThinkPad A21m 2628 Notebook
Fuji FinePix S5000 stuck in date/Time mode
Set date and time and camera should work. If camera asks to have date set everytime you take batteries out then the memory 3 volt battery is flat ... replace.
Jun 08, 2007 | Fuji FinePix S5000 Digital Camera
Changing the date
Go to timexaudio.com, select SUPPORT, then select PRODUCT MANUALS to get a manual.
Mar 12, 2007 | Timex Auto-set Clock Radio
Moultrie MFH-DGS-100V2 Digital Camera Logo
Top Moultrie Cameras Experts
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
