Question about Electric Strider Mini 4 Wheel Mobility Scooter Cherry
Amigo problem what is wrong if when i press to go forward and i go but it like stutters like its grabbing somewhere like a fast stopping while it is going..
    New Friend:
  • 4 Answers
I had this problem similarly on an older trike I owned and still do.
If it stutters as it goes forwards, there is probably an intermittent connection between the wig-wag (the part you push to make the scooter go) and the rest of the electronics. It could be as simple as a loose wire or the whole wig-wag might need replacing. I'd recommend you take the scooter to your local dealer and have them reproduce the exact problem you're having and hopefully they'll be able to recommend a fix.
Posted on Apr 23, 2014
How fast does the AMIGO BAJA SCOOTER go
3.5 to 5.3mph
DF]FD, Centra, Deluxe, J9, Baja, MC, Grand Tour 1996 ... - Amigo Mobility
myamigo.com/service/amigo-mobility-scooters-owners-manuals?...18:fd...baja...Amigo FD. · Amigo Centra. · Amigo Deluxe. · Amigo J9TM. • Amigo Baja. · Amigo MC ..... your Amigo's top speed will be between 3.5 mph/5.6 kph and 5.3 ...
May 20, 2018 | Amigo Health & Beauty
A minute or 2 after starting the machine and on any setting the machine starts to stutter, lights flashing and making a fast rhythmic noise
It sounds as though power is only struggling through to the motor intermittently.
Ignoring the possibilities of loose or bad connections or expensive circuit boards the motor could need new brushes.
I have had my machine nearly ten years and it is on its fourth set even though it doesn't get used very often.
I suggest you stop persisting with attempting to make it go. If brushes are the problem you could be making things worse so that it could need a new motor rather than some routine periodical maintenance.
I could be completely wrong - sorry if I am.
Feb 04, 2015 | Washing Machines
How get menu to show language option
Press the vcr button then press menu,press the play or stop button to select vcr set up,then press the fast forward button.Press play or stop button to select language,then press the fast forward button.Press the play or stop button to select English or Spanish.Then press the status exit button.Hope this helps.
Oct 11, 2014 | Philips VR620CAT VCR
When i press to go the amigo goes but it like stutters real fast like something is catching it..
That is typically a motor issue. It could be a few more specific things such as; transaxle, parking brake or motor brush. All of which can be quite expensive to replace.
Apr 22, 2014 | Amigo Health & Beauty
How to transfer main phone number to cell number
If the featured is enabled at the phone company, grab the main line, enter call forward code (maybe *72), get stutter tone, dial your cell number, hang up. In the morning cancel forwarding, access main line, dial cancel code ( maybe *73), hang up.
Apr 08, 2014 | AT&T 922 Corded Phone
Clicking noise
Anything with a cassette in it has belts and capstans, play heads and runner rollers. The belt is likely stretched and sticky, replace it with a new belt. I use a product called rubber renue on the roller to stop it from sticking to the tape.
Oct 19, 2013 | JVC GR Video Cameras
Engine stutters or stalls after a complete stop upon engaging to go forward
You'll need to have someone scan the computer for the codes.
Most auto parts stores will scan for free in hopes of selling you some parts. Once you get the codes you can research them online or in this question.
Sep 03, 2012 | 1998 Pontiac Sunfire
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
Forward fasts on its own
you may want to try fast forwarding at 2x (that is, press the FF key twice), although the speed will be faster, it may actually stop for you, when you press play, rather than going to the end.
Feb 05, 2009 | Arris DCT6200 DTV Receiver
Electric Strider Mini 4 Wheel Mobility Scooter Cherry Logo
60 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
