I have a Toshiba Satellite laptop with Microsoft windows on it. I have not updated to 8.1. When I try to touch the screen it will not work. It just stopped one day. I'm not sure how to fix it.
SOURCE: Can't stop Win XP Toshiba Satellite laptop from going into standby.
on the desktop right-click properties and go to the tab screensaver.Then change the time before screensaver appears or click power and adjust the settings as you want.Hope this helped
SOURCE: Toshiba Satellite laptop w/ blank, black screen & blinking cursor
the hard drive is not checking in correctly. go into your f2 function which is your bios. see if in there during the boot options if you have a hard drive showing up. if you do, you would need to check if the hard drive has failed or the o.s. is corrupt.if you do not see a drive there, its failed, check to see if its seated correctly. if it is seated correctly the drive has failed and will need to be replaced.
if it shows up, and if you have your restore disk, load it and select repair. it will look for the hard drive and any windows installations. if it does not find any. then the drive is bad and will need to be replaced, in the event it does find the windows installation then continue to repair the machine software.
Let me know what happens when you try this
Good Luck!
Ruben
SOURCE: Toshiba Satellite L310 problem , display cannot appears
If the screen went blank after the driver install, sometimes clicking the mouse on the screen will bring the picture back. It sounds like the monitor is having a conflict with the resolution the driver is throwing out. Reboot the laptop and when you see the Toshiba splash screen, tap F8 until you see the multiple boot menu. Scroll to Safe Mode with networking and reboot. If the screen comes up, go to the control panel > System > hardware > display adapter > click on the plus sign and double click the reported adapter.click on driver tab and select roll back driver > click yes to any prompts and click ok. Reboot normally and see if that clears the problem.
SOURCE: WEBCAM DRIVER OPEN FAIL. Toshiba M300 satellite
Go here and download the driver utility for your webcam.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2228766&rpn=PSMD8U&modelFilter=M300-ST3402&selCategory=3&selFamily=1073768663
SOURCE: Toshiba satellite C655 laptop has black screen
Turn the computer off all of the way by holding in the power button until it shuts off.
Turn it back on and immediately start tapping the F8 key. It should bring you to a menu that has an option for going to "Last Known Good Configuration". Choose that option and see if it boots up.
If pressing F8 doesn't bring you to the menu - you may need to run diagnostics on the computer. To get to the diagnostics, attempt to boot to the Boot Menu by pressing F11 or F12 at the boot screen and see if it gives you the option to run diagnostics.
