Question about Samsung DMT400RHS Builtin Dishwasher
Samsung DMT400 continuous drain and fill - Samsung DMT400RHS Builtin Dishwasher
We had the same problem and thanks to a woman who posted a solution in January, we were able to fix it at home at no cost. The solution is to pull out the unit, remove the panel on the left side of unit, tap on the clear box that is at the bottom of the unit ~ it has a float in there that got stuck, therefore signalling the dishwasher that there is a low water level. After tapping on that, the float came back up to the top of that clear box (we started the dishwasher before this procedure in order for the water to flow into the dishwasher). That's all it took. I then put a cup of white vinegar into the dishwasher to clean some of the gunk out of the unit. Our unit is only 1-1/2 years old. Hope this helps.
Posted on May 02, 2014
Over-level water error samsung dishwashere
Over-level water error Samsung DW80F600UTS - ApplianceJunk.com
appliancejunk.com > ... > Forum Index > Dishwasher Repair
Dec 14, 2014 - 10 posts - ‎4 authors
Over-level water error Samsung DW80F600UTS. ... "heavy" lights flashing which my owners manual tells me is a "over-level" water error. .... Samsung DishwasherDW80F600UTS - High Temp Error (smart auto + normal lights). Samsung DW80F600UTS, drain code on
Jan 27, 2015
Samsung DMT300RFS/XAA OE Error
Apr 29, 2014
Samsung DMT400 over level water error
Oct 29, 2013
Samsung Low Level Water Code
May 14, 2013
More results from appliancejunk.com
Over-level water error - Fixya
Jan 11, 2016 | Samsung DMT400RHS Builtin Dishwasher
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
Nov 23, 2015 | Samsung Dishwashers
My Samsung 13Kg Top Loader WA13G7Q1 continuously drains out the water when the drum is being filled , what could be the problem
Either your in house drain pipe is too low or your drain pipe is down into the drain too far and this causes a siphon effect. Pull drain line up out a little at a time until it stops draining while filling. Good Luck!
Jul 28, 2015 | Samsung Washing Machines
How do i unlock my samsung dishwasher
It depends on the model. For example, IF you have a DMT400 series, although the light ABOVE the Low-Rinse-Aid light is lit, you press and hold the SANITIZE light for 3 to 5 seconds. Other models are different, but if you look closely at your dishwasher control console, you should see some small print that will say something like "Child lock/unlock, (Hold 3 sec)".
Mar 01, 2015 | Samsung Dishwashers
Where is the float switch on a dmt400 ?
There is no "float switch" per se, but the case-break assembly on the left side of the dishwasher takes the place of the float by measuring the amount of water going into the machine by spinning a small turbine.
Sep 01, 2014 | Samsung DMT400RHS
How to remove the case sensor on samsung dishwasher dmt400
Unplug dishwasher. Remove panel on left-hand side (by removing 2 screws). Remove the water inlet valve baffle on the inside of the dishwasher by turning it counter-clockwise (use long-nose pliers). Tilt case-brake assembly out from the top. Unplug electrical connectors. Use pliers to loosen clamps and slide down the rubber hoses. Remove hoses, then remove case-break assembly.
Aug 02, 2014 | Samsung Dishwashers
How do you troubleshoot samsung DMT400 series dishwasher?
disconnect from power for 30 minutes then restart and see if it resets itself
May 31, 2014 | Household & Kitchen Appliances
Samsung washing machines water drains continously
The drain hose is too low, you need to lift the height of the drain hose as it is siphoning and won't be able to fill to the required level.
Mar 05, 2012 | Washing Machines
Samsung DMT400RHS Builtin Dishwasher Logo
202 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
