Question about Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel
The letters OP appearing on the control panel of my electrolux refrigerator, what is wrong?
    Scholar:
  • 126 Answers
Either the freezer sensor is open in freezer display -or- the fresh food sensor is open in refrigerator display.
The repair is to check wiring between thermistor and board. If the wiring is OK, then replace the defective thermistor (temperature sensor).
Posted on Apr 23, 2014
  • 1 more comment
  • pwrsce Apr 23, 2014
    If the op is in the freezer display there is an issue with the freezer sensor or circuit, if it is in the fresh food display the issue is with the fresh food sensor or circuit. In ice water the sensor should have a resistance of 32,000 ohms at 32 degrees.
    These checks can be made from the main control beneath the unit that is behind the kick plate. The sensors are at the j3 connector The wires are gray with white stripes for the fz and gray with black tracers for the fresh food sensor.
    Also if the resistance check from the control shows the sensor to be good the control needs to be replaced.
Why the sign "replace" air filter keep appear even there is a new filter just installed?
Hello Michele,
From what you have described the replace air filter light on your Electrolux refrigerator continues to stay lit. I see that you disconnected power from it for a minute and the light was still lit. I would recommend performing a power reset on it and you can do that by unplugging for at least ten minutes. That will allow all of the power to drain out of the refrigerator for a full restart. If that does not work there may be an issue with the control panel of your refrigerator and a technician may need to be contacted for proper disassembly of your refrigerator. This will help you avoid any future issues within your refrigerator. -Matt
Dec 29, 2015 | Electrolux EI23BC56IS (226 cu ft) Bottom...
I have control panel off wiring and circuit board look fine still cf code
Thank you for your post, friend!
From the information you have provided your Electrolux refrigerator is displaying an error code of "CF". "CF" appears to be a communication failure this could be a possible issue with your control panel or wiring harness. I understand that you have the board off and everything looks good so this could need to be further evaluated by an authorized technician. Hopefully this is helpful. -Matt
Feb 12, 2015 | Electrolux Refrigerators
The power fail keeps coming on and the beeping is non stop. What should I do? I have an electrolux model # JSI-26
Thank you for your post, Ian Jamal Karim!
From my understanding your Electrolux refrigerator is beeping and the power fail display continues to appear. Based off the information you have provided you could have a potential issue with your control panel or thermostat within your refrigerator. I would recommend performing a reset on your refrigerator and you can do that by unplugging the power cord or flipping the household circuit breaker off for roughly ten minutes. If that does not help to resolve your issue I would suggest contacting a technician for repairs to be completed. Hopefully this information is helpful. -OOS
Jan 22, 2015 | Electrolux Refrigerators
How do I adjust freezer temperature on Electrolux refrigerator?
Hello friend, thanks for your inquiry!
I see that you would like to know how to adjust the temperature within your Electrolux refrigerator, EI23CS55GS1. To adjust the temperature you would use the control panel on the front of the freezer door. There should be a "-"or "+" near the freezer temperature control and that is how you would adjust the temperature within your refrigerator. Be sure to check and make sure that the control lock is not on or you will not be able to adjust the temperature. Any adjustments made within the refrigerator need at least 24 hours to stabilize. I hope this is has been helpful. -Matt
Oct 18, 2014 | Electrolux Refrigerators
Beeping and fridge tempt is flashing 59
Hey friend, thanks for your post!
Is your Electrolux refrigerator displaying any error code? Typically if something is wrong the appliance will display an error code. I would perform a reset on your refrigerator which you can do by unplugging your power cord or flipping the household circuit breaker for ten minutes.
If that does not help correct your issue it may be a problem within your control panel or sealed system. I would recommend having a professional come out to properly diagnosis and repair your refrigerator. I hope this information is beneficial. -Matt
Oct 06, 2014 | Electrolux Refrigerators
Display panel on Electrolux wave touch French door refrigerator will not adjust temperature. Ice or water won't' dispense either.
Hello friend, thank you for your post!
Based off the information you are describing it sounds like your control panel is locked. Can you check to see if the control lock is lit up? If so, please hold down the control lock button for 3 seconds and it should allow you to operate the front panel. If not you could be experiencing a problem within your control panel and may need to have a professional come out to diagnose it. I hope this helps. -Matt
Sep 10, 2014 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Op er on samsung Control panel
Unplug refrigerator for 5 minutes then plug in to reset control board. It is trying to recover from a communications error
Aug 10, 2013 | Samsung RF265AA Bottom Freezer French Door...
Electrolux wine cooler ''af'' code flashing
Believe it or not we had the same problem.... The air filter should be changed about every six months but it is just charcoal or baking soda or something like that and is not attached to any sensors. To reset the flashing light, make sure the control panel is unlocked then hold down the on/off and (-) buttons and it will reset.
Good Luck! Elisabeth
Aug 30, 2009 | Electrolux Refrigerators
Electrolux RM212,F, wont cool on gas but appears to be ok on electric. The flame lights but can only feel a slight chill in the freezer box, and the flame does not seem to adjust with the control.
May 13, 2008 | Electrolux Refrigerators
Electrolux 25.9 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Steel Logo
94 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
