Question about Health & Beauty
I have a pride quantum 6000 electric wheelchair and I've recently noticed that the big tube by the wheel moves up and down when I drive is that normal as I'd never noticed that before
  • 175 Answers
Yes, that is normal, it is part of the shock absorption system.
Posted on May 08, 2014
  • 103 Answers
SOURCE: elctric wheelchair, flashing rapidly the error display
Have the batteries load tested and be sure that the chair is in gear.
Posted on May 26, 2009
  • 32 Answers
SOURCE: wheelchair problem
sounds like you might have locked joystick by mistake. Try pressing and holding down the on/off switch for 5 seconds.
Posted on Jul 12, 2009
SOURCE: Jazzy Select 6 Indoor Power Wheelchair: Hi! I just inherited a used Pride Mobility Ja...
There should be a place to plug the charger in on the front of the joystick. It is a round three pin connector
Posted on May 20, 2010
wcdoc1953
  • 280 Answers
SOURCE: Pride Jazzy 1121 power wheelchair has leaked oil
There's not too much you can do about the gearbox leaking oil. The gearbox will usually leak at the top gasket or seals. I suppose you could try to re-torque the bolts holding the top gearbox flange, but the other seals are usually leak due to age or overheating. If you pull it apart to re-torque the bolts, you might as well replace it along with the motor and brake. The gearbox grease stains are hard if not impossible to remove from carpeting and flooring.
If the motor drags you could have a bad brake which indicates you should replace the entire assembly. If the chair veers to the right you might have one motor spinning faster than the other due to age or damage. You can go into the programming menu with a hand held programmer and adjust the steering correct to compensate for the motor difference.
The bottom line is that you are due to replace at least one brake/motor/gearbox very soon. I usually replace them as a pair since the other side will also need replacement soon.
The motor/brake/gearbox assembly will run you about $700 for each side. Labor cost will be about 1 to 1.5 hour per side.
This is an older model Jazzy which was very sturdy, reliable and popular. You should evaluate the condition of the other components when deciding how much to spend on the repair. Replacement for a comparable chair has gone up considerably and I personally don't think the motor quality is as good. Hope this helps.
Posted on Jan 09, 2011
  • 692 Answers
SOURCE: pride jazzy quantum 1420. working fine until
Could be in sleep mode try pressing the on/off button twice to get out of sleep mode if that doesn't work then you have a joystick problem and it needs to be replaced Hope this helps
Posted on Mar 04, 2011
It started running lower and lower even thought it was fully charged, now the last couple of day I've been getting bus overload and it will not charge
Quantum 6000 - Pride Mobility Products
www.pridemobility.com/pdf/owners.../au_q6000_om.pdf
Pride MobilityQuantum 6000 .... WELCOME to Quantum Rehab, a division of Pride Mobility Products ... The symbols below are used on the power chair to identify warnings, .... Lowpressure may result in loss of control, ... If you must stop, start up again slowly and then accelerate .... Avoid tall grass that can entangle the running gear.
[PDF]Quantum 6000Z - Pride Mobility Products
www.pridemobility.com/pdf/.../intl.../au_q6000z_om.pdf
Pride Mobilitythis power chair and must perform all of the procedures in this manual. The symbols below are used throughout this owner's manual and on the power chair to identify ... NOTE: The Quantum 6000Z and its components are not made with natural ..... Turn the adjusting screw to raise the front of the armrest or to lower the front ...
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
35 posts - ‎30 authors
Feb 05, 2016 | Quantum 6000 Power Chair - Used Electric...
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
www.fixya.com/.../t26033304-quantum_600_wheel_chair_work_says_s...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Jan 01, 2016 | Health & Beauty
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
I have a Quantum 600 xl with a squeaky suspension. I have silicone spray to lubricate it, but don't know where to put the lubricant.
Try the wheel bearings first.
[PDF]Pride Quantum 600 Xl Owners's Manual - Scootaround
www.scootaround.com/.../manuals/.../Pride%20Quantum%20600%20XL...
Quantum 600 XL. I. INTRODUCTION. SAFETY. WELCOME to Quantum Rehab, a division of Pride Mobility Products Corporation (Pride). The power chair you ...
Sep 13, 2015 | Health & Beauty
I have a quantum 6000 electric wheelchair where can i get a replacement battery charger
Gosh I am sorry but have NO knowledge Re: Quantum chair chargers but unless you got your chair and equipment from Scooter Store. which got shut down by Feds due to fraud, you might contact chair's supplier and ask about getting a replacement for your destroyed charger's source.
Failing that, does your city/county publish a "throw away" paper? Sometimes one can find powerchair's equipment posted there. That might be worth a try.
I am sorry not to be familiar with Quantum mobility aids! Anybody else, please?
Jul 09, 2014 | Pride Jazzy Select 6 Indoor Power...
Pride jazzy quantum 1420. working fine until today. when turned on, lights by joystick all flash on and off repeatedly. chair does not move. Any suggestions?
Mar 03, 2011 | Pride Mobility Products Quantum Jazzy 500...
I have a quantum 6000 chair and whenever I need to raise my chair for a period of time, my legs just dangle and begin hurting. Any suggestions or solutions for a temporary foot rest while my chair is...
Jal Check with your provider and ask them for a pair of Elevated Leg rests for your chair. They might have to install the holders for the leg rests but that is an easy job. And they are fairly inexpensive and can be put on and taken off easily. Hope this helps you
Nov 12, 2010 | Pride Mobility Products Quantum Jazzy 500...
Do wheel berings need maintenance
No, by the time the wheels wear down the bearing will still be good.
Dec 12, 2009 | Pride Mobility Products Quantum Jazzy 500...
Health & Beauty Logo
89 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
