Question about Samsung Microwave Ovens
SMH 9207ST no power when connected to outlet
Oven does not power up at all
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 144 Answers
First thing I would check is to see if the fuse in the microwave has burnt out, the top cover can easily be removed but make sure that the power is disconnected first and be careful as high voltage is involved
Posted on Apr 24, 2014
3 Suggested Answers
SOURCE: Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Posted on Jan 22, 2011
heatman101
  • 43501 Answers
SOURCE: i have a 9207st door
The door latch needs to close a switch to tell it that the door is closed... that switch is bad...
You will need to replace the latch/switch...
Basic Microwave Oven Troubleshooting Tips
Here is a tip that will help you with the online buying...
How to Buy
Appliance Parts Online
heatman101
Posted on Feb 09, 2011
The control panel of microwave dead. No lights on the panel. There is power to the outlet
If it worked after unplugging and reinserting, it is possible that there is a wiring problem with the plug and wiggling the wires "re-made" a connection. Try plugging in to another outlet to eliminate a dodgy outlet problem.
Mar 26, 2015 | GE Microwave Ovens
No power - not the outlet or a fuse
If the internal fuse in the microwave is good, then it could be a bad wiring connection somewhere in the oven, or a thermal cutout has failed.
Jun 26, 2014 | Samsung SMH9187 Microwave Oven
No power to Samsung SMH 9151
The main fuse in the microwave oven has probably blown.
Mar 28, 2012 | Samsung SMH9151 Microwave Oven
I have a samsung microwave oven,model smh 7185,does it have an internal fuse?
Most MW do have an internal fuse, most likly a 10 amp ceramic (HRC) You can replace with a glass one but if it blows it could rupture
Jan 30, 2012 | Samsung SMH7178STD Microwave Oven
No power to microwave
Hello
Check the Power Cord
Verify that the power cord is properly connected the outlet; the plug might have been removed to make way for another appliance. Do not connect the microwave to an outlet via an extension cord or plug adapter; the oven must be directly connected to an outlet.
Switch the Outlet on
Turn the outlet on, if possible, using the switch on the wall behind the counter or on the plug itself. Some microwaves have a separate power switch that must be in the correct position before you can begin cooking.
Reset the Oven
Unplug the oven, wait a few seconds and reconnect the power. A power surge could have temporarily rendered the oven inoperable. The oven should start up as normal when you connect the plug to the outlet.
Check the Fuses and Breakers
See that the fuse or breaker protecting the oven's circuit is still active. Replace the fuse if it has blown, or reset the breaker to restore power to the oven. Stop using the microwave if it repeatedly blows fuses or trips breakers.
Oct 04, 2011 | Microwave Ovens
Microwave pops hose breakers. Microwave gets
The problem is in the microwave oven, you have a short in the power supply or it could be a defective door switch, either way the unit needs to be checked out.
Feb 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
The oven is totally dead. No light, fan etc. Replaced fuse internally, found no current at the fuse. Outlet has 120 v. Oven was run empty prior to going dead! Any thoughts?
check power between power cord connection and inernal fuse,start at cord connection and work way to fuse conn.eliminating possibe problem area
Oct 11, 2010 | Maytag MMV5000 Microwave Oven
Jun 24, 2009 | Samsung Microwave Ovens
Microwave Ovens Logo
65 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
