Question about 1994 94 Ford Explorer Light Bulb-1994 Ford
Grinding front end
Replaced both calipers, router & hubs and both inner and outer bearings in front end and am still getting a whirring noise from the front end
  • GE Master
  • 17,115 Answers
Its your tires, inspect them for uneven wear.
Posted on Apr 22, 2014
Loud grinding/clunking noise when driving, lessens when I press the brake
Loud Noise Unknown Origin - Ask the GM Technician - GM-Trucks.com
www.gm-trucks.com > ... > Ask the GM Technician
Jun 30, 2006 - 7 posts - ‎3 authors
I get a loud clunking, grinding noise while turning to the right only, and ... I moved the passenger side tire to the rear driver side just in case it ...
can bad wheel bearing/hub cause loud clunking noises?
www.jeepsunlimited.com/.../showthread.php?...loud-clunking-noises
Nov 12, 2009 - 14 posts - ‎6 authors
driving home, i noticed some metal clunking sounds coming from the front driversside. at ... hmmmm....if it's grinding, then probably a bearing.
Front Clunking sound when driving straight. - TDIClub Forums
forums.tdiclub.com > ... > VW MKIII-A3/B4 TDIs
Dec 21, 2011 - I have a sporadic clunking noise from the drivers side front end. '98 jetta ... If I try to coast it gets really louder and more pronounced. ... whirring orgrinding could be several things: wheel bearing, brake pads due to a caliper ...
Quick Guide to Diagnosing Differential & Driveline Noises ...
Dec 26, 2015 | Cars & Trucks
Replace cv joints
Hi Douglas, I'm glad to help. My first suggestion is to get to complete shaft. This way you want have any problems later on. It's not that much more expensive and you'll be glad you did. Below is the procedure for replacing them.
FRONT DRIVESHAFTS
REMOVAL
  1. Raise vehicle on jack stands or centered on a frame contact type hoist. Refer to Hoisting in the Lubrication And Maintenance section of this manual for the required lifting procedure to be used for this vehicle.
  2. Remove the cotter pin and nut lock Hub And Bearing To Stub Axle Retaining Nut from the end of the stub axle.
  3. Remove the wheel and tire assembly from the vehicle.
  4. Remove the wave washer Wave Washer from the end of the stub axle CAUTION: Wheel bearing damage will result if after loosening hub nut, vehicle is rolled on the ground or the weight of the vehicle is allowed to be supported by the tires.
  5. With the vehicle's brakes applied to keep hub from turning, loosen and remove the stub axle to hub nut.
  6. Remove the two front disc brake caliper to steering knuckle attaching bolts Front Disc Brake Caliper Attaching Bolts
  7. Remove the disc brake caliper from the steering knuckle. Caliper is removed by first rotating top of caliper away from steering knuckle and then removing bottom of caliper out from under machined abutment on steering knuckle Brake Caliper Mounting To Steering Knuckle
  8. Support disc brake caliper assembly by using a wire hook and suspending it from the strut assembly Correctly Supported Disc Brake Caliper Do not allow the brake caliper assembly to hang by the brake flex hose.
  9. Remove the brake rotor from the hub and bearing assembly Remove/Install Brake Rotor
  10. Remove nut attaching outer tie rod end to steering knuckle Removing Tie Rod End Attaching Nut Nut is to be removed from tie rod end using the following procedure, hold tie rod end stud with a 11/32 socket while loosening and removing nut with a wrench.
  11. Remove tie rod end from steering knuckle using Remover, Special Tool MB-991113 Tie Rod End Removal From Steering Knuckle Arm
  12. Remove the steering knuckle to ball joint stud, clamping nut and bolt Control Arm To Steering Knuckle Attachment from the steering knuckle.
  13. Using a pry bar, separate steering knuckle from ball joint stud Separating Ball Joint Stud From Steering Knuckle Note: Use caution when separating ball joint stud from steering knuckle, so ball joint seal does not get cut. NOTE: Care must be taken not to separate the inner C/V joint during this operation. Do not allow driveshaft to hang by inner C/V joint after removing outer C/V Joint from the hub/bearing assembly in steering knuckle, end of driveshaft must be supported.
  14. Pull steering knuckle assembly out and away from the outer C/V joint of the driveshaft assembly Steering Knuckle Separation From Driveshaft
  15. Support the outer end of the driveshaft assembly. Insert a pry bar between inner tripod joint and transaxle case Disengaging Inner Tripod Joint From Transaxle Pry against inner tripod joint, until tripod joint retaining snap ring is disengaged from transaxle side gear.
  16. Hold inner tripod joint and interconnecting shaft of driveshaft assembly. Remove inner tripod joint from transaxle, by pulling it straight out of transaxle side gear and transaxle oil seal Tripod Joint Removal from Transaxle When removing tripod joint, do not let spline or snap ring drag across sealing lip of the transaxle to tripod joint oil seal.
INSTALLATION
  1. Thoroughly clean spline and oil seal sealing surface, on tripod joint. Lightly lubricate oil seal sealing surface on tripod joint with fresh clean transmission lubricant.
  2. Holding driveshaft assembly by tripod joint and interconnecting shaft, install tripod joint into transaxle side gear as far as possible by hand Tripod Joint Removal from Transaxle
  3. Grasp inner tripod joint an interconnecting shaft. Forcefully push the tripod joint into side gear of transaxle, until snap ring is engaged with transaxle side gear. Test that snap ring is fully engaged with side gear by attempting to remove tripod joint from transaxle by hand. If snap ring is fully engaged with side gear, tripod joint will not be removable by hand.
  4. Clean all debris and moisture out of steering knuckle, in the area were outer C/V joint will be installed into steering knuckle.
  5. Ensure that front of outer C/V joint which fits against the face of the hub and bearing is free of debris and moisture before installing outer C/V joint into hub and bearing assembly Outer C/V Joint Inspection
  6. Slide drive shaft back into front hub and bearing assembly. Then install steering knuckle onto the stud of the ball joint assembly Steering Knuckle Separation From Driveshaft
  7. Install a new steering knuckle to ball joint clamping bolt and nut Control Arm To Steering Knuckle Attachment Tighten the clamping bolt and nut to a torque of 135 N·m (100 ft. lbs.)
  8. Install tie rod end into steering knuckle. Start attaching nut onto stud of tie rod end. While holding stud of tie rod end stationary using a 11/32 socket, Removing Tie Rod End Attaching Nut tighten tie rod end to steering knuckle attaching nut. Then using a crowfoot and 11/32 socket Torquing Tie Rod End Attaching Nut , tighten the tie rod end attaching nut to a torque of 54 N·m (40 ft. lbs.)
  9. Install braking disc on hub and bearing assembly Remove/Install Brake Rotor
  10. Install disc brake caliper assembly on steering knuckle. Caliper is installed by first sliding bottom of caliper under abutment on steering knuckle, and then rotating top of caliper against top abutment Brake Caliper Mounting To Steering Knuckle
  11. Install disc brake caliper assembly to steering knuckle attaching bolts Front Disc Brake Caliper Attaching Bolts Tighten the disc brake caliper assembly attaching bolts to a torque of 22 N·m (195 in. lbs.)
  12. Clean all foreign matter from the threads of the outer C/V joint stub axle. Install the washer and stub axle to hub/bearing assembly nut on stub axle and securely tighten nut.
  13. Install front wheel and tire assembly. Install and tighten the wheel mounting stud nuts in proper sequence until all nuts are torqued to half the required specification. Then repeat the tightening sequence to the full specified torque of 135 N·m (100 ft. lbs.)
  14. Lower vehicle.
  15. With the vehicle's brakes applied to keep hub from turning, tighten the hub nut to a torque of 244 N·m (180 ft. lbs.) Torquing Front Stub Axle To Hub Nut
  16. Install the spring wave washer on the end of the stub axle.
  17. Install the hub nut lock, and a new cotter pin Hub And Bearing To Stub Axle Retaining Nut Wrap cotter pin prongs tightly around the hub nut lock as shown in Hub And Bearing To Stub Axle Retaining Nut
  18. Check for correct fluid level in transaxle assembly. Refer to Group 21, Transaxle for the correct fluid level checking procedure for the type of transaxle being checked.
  19. Set front toe on vehicle to required specification.
May 07, 2014 | 2000 Dodge Caravan
Wheel hub bearing
are the bearings new or s/h only uses new ones, and chech the hub for ware on the inner side where the hub goes into the inner bearing as these tend to were and you will have slight play on the inner bearing ... so in affect your load is on the outer bearing and no equal on both make sure that the hub is torqued up to specified torque
Dec 30, 2013 | 2003 Chevrolet Cavalier
I need to know how the front bearings look for a 2002 montero sport
YOU HAVE 2 BEARINGS INNER AND OUTER BEARING IN HUB.YOU NEED TO REMOVE BRAKE CALIPER THEN REMOVE GREASE CAP.STRAIGHTEN THE BEND COTTER PIN THEN REMOVE COTTER PIN.THEN LOOSEN REMOVE ADJUSTING NUT AND WASHER FROM END OF THE SPINDLE.PULL THE HUB OUT SLIGHTLY THEN PUSH IT BACK INTO ORIGINAL POSITION. THIS WILL FORCE THE OUTER WHEEL BEARING OFF THE SPINDLE ENOUGH SO YOU CAN REMOVE IT.PULL THE HUB OFF THE SPINDLE.USE A SCREW DRIVER TO PRY THE GREASE SEAL OUT OF THE REAR OF THE. HUB AS THIS IS DONE NOTE HOW THE SEAL IS INSTALLED.THEN REMOVE THE INNER WHEEL BEARING FROM THE HUB.
Aug 25, 2011 | 2001 Mitsubishi Montero
I've changed rotors before but never on a 4 wheel drive. Could you tell me how to on a 1989 ford ranger?
Brake Rotor (Disc) - REMOVAL & INSTALLATION
  1. Loosen the wheel lug nuts.
  2. Jack up the front of the vehicle and support on jackstands.
  3. Remove the wheel and tire.
  4. Remove the brake caliper assembly as described earlier in this section, but do not disconnect the brake hose.
  5. Suspend the caliper assembly by a piece of wire. Do not allow it to hang by the brake hose.
  6. Follow the procedure given under wheel bearing removal in Suspension and Steering for models with manual and automatic locking hubs (lines down).
New rotor assemblies come protected with an anti-rust coating which should be removed with denatured alcohol or degreaser. New hubs must be packed with EP wheel bearing grease.
  1. Installation is the reverse of the removal procedure.
Front Wheel Bearings - REMOVAL & INSTALLATION
(see Figure 1 )
Fig. 1: Inspect the bearings for abnormal wear and/or damage
With Manual Locking Hubs
(see Figures 2 through 17)
  1. Raise the vehicle and install jackstands.
  2. Remove the wheel and tire assembly.
  3. Remove the retainer washers from the lug nut studs and remove the manual locking hub assembly from the spindle.
  4. Remove the snapring and spacer from the end of the spindle shaft.
  5. Remove the outer wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
  6. Remove the locknut washer from the spindle.
  7. Remove the inner wheel bearing locknut from the spindle using 4 prong spindle nut spanner wrench, T86T-1197-A or equivalent. Make sure the tabs on the tool engage the slots in the locknut.
  8. Remove the outer bearing cone and roller assembly from the hub. Remove the hub and rotor from the spindle.
  9. Using seal removal tool 1175-AC or equivalent remove and discard the grease seal. Remove the inner bearing cone and roller assembly from the hub.
  10. Clean the inner and outer bearing assemblies in solvent. Inspect the bearings and the cones for wear and damage. Replace defective parts, as required.
  11. If the cups are worn or damaged, remove them with front hub remover tool T81P-1104-C and tool T77F-1102-A or equivalent.
  12. Wipe the old grease from the spindle. Check the spindle for excessive wear or damage. Replace defective parts, as required.
Fig. 2: Before beginning the wheel bearing removal, and after the outer hub is removed, wipe off any excess grease
Fig. 3: After the grease is wiped off, remove the axle shaft snapring ...
Fig. 4: ... then pull the splined spacer from the axle shaft end
Fig. 5: Use a 4 pronged socket to loosen the outer wheel bearing locknut ...
Fig. 6: ... then remove the outer locknut
Fig. 7: Remove the lockwasher from behind the outer locknut ...
Fig. 8: ... then loosen and remove the inner locknut-note the lockwasher engagement pin (arrow)
Fig. 9: While pushing inwards on the rotor/hub assembly, remove the outer wheel bearing ...
Fig. 10: ... then pull the rotor/hub assembly from the spindle, taking care not to scratch the bearing cups in the hub
Fig. 11: Pry out the grease seal on the back of the rotor/hub assembly ...
Fig. 12: ... then remove the inner wheel bearing. Thoroughly clean and inspect all of the parts for wear or damage
continue...
Jul 29, 2011 | 1989 Ford Ranger
WHy dose my brake pedal push back and make a grinding noise
Look through the openings in your front wheels and look at the front rotors-are they gouged up? You are probably running metal-to-metal, pads to rotors.
Chances are real good your rotors will have to be replaced along with new pads, but if you catch it early enough you might be able to have them machined, although nowadays that is hardly easy to get done and the savings usually is not as significant as it once was.
May 23, 2011 | 1995 Pontiac Bonneville
What is needed to remedy right hand front wheel bearing play on a 1990 d21 4X4 ute
replace the bearing or wheel hub assembly.
REMOVAL & INSTALLATION 2wd Models NOTE: Refer to wheel bearing service and bearing preload adjustment procedures found in Section 1.
  1. Raise the front of the truck and support it with safety stands. Remove the wheels.
  2. Remove the brake caliper and suspend it with wire, out of the way. Remove the caliper torque plate if equipped.
  3. Remove the dust cap and then remove the cotter pin, lock washer (if equipped) nut lock and nut.
  4. Pull the hub/disc assembly off the spindle with the outer bearing. Don't let the bearing fall out.
  5. Pry the inner oil seal out and remove the inner bearing. To install:
  6. Clean and inspect the bearings and outer races.
  7. Using a brass drift and a hammer, drive out the bearing outer race. Press a new one into position.
  8. Pack the bearings with grease until it oozes out the other side. Coat the inside of the hub and cap with grease.
  9. Position the inner bearing into the hub, coat the oil seal with grease and press it into the hub.
  10. Press the hub assembly onto the spindle and install the outer bearing and thrust washer.
  11. Install the hub nut. Turn the hub a few times to seat the bearings and then loosen the nut until there is 0mm axial play. Using a spring tension gauge, check that the preload (with new grease seal installed) is 2.2–6.4 lbs. (9.8–28.4N)
  12. Install the lock-nut, new cotter pin and hub grease cap.
  13. Install the brake torque plate. Install the brake caliper.
  14. Install the wheels and lower the truck.
4wd Models The hub and bearing service procedures for a 4wd models are basically the same as those for a 2wd version, with the exception of removing the free running hub assembly and the bearing preload adjustment. Refer to Sections 1 and 7 for additional information. Adjust the preload after the wheel bearing is replaced or the front axle assembly is reassembled. BEARING PRELOAD ADJUSTMENT
  1. Thoroughly clean all parts and pack the wheel bearings.
  2. Apply grease to threaded portions of the spindle, grease seal lip and wheel hub.
  3. Tighten the wheel bearing lock-nut with a socket and torque wrench to 58–72 ft. lbs. (78–98 Nm).
  4. Rotate the hub in both directions a few times to seat the bearings. Loosen wheel bearing lock-nut.
  5. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm).
  6. Turn wheel hub several times in both directions.
  7. Retighten the lock-nut to 0.4–1.1 ft. lbs. (0.5–1.5 Nm). Fig. 1: Exploded view of the front axle assembly — 2wd models 86718030.gif
    Fig. 2: Removing the bearing outer races 86718032.gif
    Fig. 3: Packing the wheel bearing with grease 86718033.gif
    Fig. 4: Pack the lip cavity of grease seal with grease 86718034.gif
    Fig. 5: Exploded view of the front axle assembly — 4wd models 86718031.gif
  8. Measure wheel bearing axial end-play. The wheel bearing end-play specification is 0.
  9. Install lock washer by tightening the lock-nut within 15–30 degrees.
  10. Turn wheel hub several times in both directions. Wheel bearing should be seated correctly.
  11. If necessary, measure wheel bearing preload. NOTE: Measure wheel bearing preload with a spring-type gauge; measure at wheel hub bolt, with tire removed. The hub assembly should rotate with 1.6–4.7 lbs. (0.73–2.13 kg) of pressure.
Jul 28, 2010 | 1991 Nissan Pickup
Hub making grinding noise tie rods need replacement
A grinding from the hub sounds like a bad wheel bearing.
Jun 01, 2010 | 2001 Buick Park Avenue
Replace front wheel bearing is it hard to do on 2002 alero
its actually pretty easy if you have the basic tools needed and a little mechanical knowledge, because i dont think you can buy just the bearing at a auto parts store. they sell you the whole hub assembly which is great for the DIYer.
lift the car off the ground and block it from rolling and place a jack stand under it so it cant fall on anyone.
Removal & Installation
These vehicles are equipped with sealed hub and bearing assemblies. The hub and bearing assemblies are non-serviceable. If the assembly is damaged, the complete unit must be replaced.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Remove or disconnect the following:
    WARNING DO NOT allow the caliper to hang unsupported from the brake hose.
    Front wheel Halfshaft nut and washer Caliper from the steering knuckle and support it aside
    Brake rotor Anti-lock Brake System (ABS) connector, if equipped 3 hub/bearing assembly bolts Halfshaft from the hub/bearing assembly Hub/bearing assembly
    0900c1528023b277.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Exploded view of the front hub/bearing assembly
To install:
Install or connect the following:
Hub/bearing assembly onto the halfshaft, making sure the splines engage smoothly Hub/bearing assembly to the steering knuckle. Torque the bolts to 70 ft. lbs. (95 Nm). Anti-lock Brake System (ABS) connector, if equipped Brake rotor Caliper onto the steering knuckle. Torque the bolts to 38 ft. lbs. (51 Nm). Halfshaft nut. Torque the hub nut to 284 ft. lbs. (385 Nm) on nuts colored black, or 173 ft. lbs. (235 Nm) on gray colored nuts. Front wheel. Torque the nuts to 100 ft. lbs. (140 Nm).
Jul 27, 2009 | 2004 Oldsmobile Alero
Directions replace front wheel bearings on a 1985 nissan stanza?
NOTE: After the wheel bearings have been removed or replaced or the front axle has been reassembled be sure to adjust wheel bearing preload. Refer to the Adjustment service procedure below. On the 1989–92 240SX there is just one wheel bearing, pressed into the hub and no adjusting cap. Refer to the exploded views of the Front Axle Hub Assembly. Review the complete service procedure.
  1. Raise and support the vehicle safely.
  2. Remove the front wheels and the brake caliper assemblies. NOTE: Brake hoses do not need to be disconnected from the brake caliper assemblies. Make sure the brake hoses are secure and do not let caliper assemblies hang unsupported from the vehicle.
  3. Work off center hub cap by using thin tool. If necessary tap around it with a soft hammer while removing.
  4. Pry off cotter pin and take out adjusting cap and wheel bearing lock nut.
  5. Remove wheel hub with disc brake rotor from spindle with bearings installed. Remove the outer bearing from the hub.
  6. Remove inner bearing and grease seal from hub using long brass drift pin or equivalent.
  7. If it is necessary to replace the bearing outer races, drive them out of the hub with a brass drift pin and mallet.
  8. Install the outer bearing race with a tool (KV401021S0 special tool number) until it seats in the hub flush. NOTE: Place a large glob of grease into the palm of one hand and push the bearing through it with a sliding motion. The grease must be forced through the side of the bearing and in between each roller. Continue until the grease begins to ooze out the other side through the gaps between the rollers. The bearing must be completely packed with grease.
  9. Pack each wheel bearing with high temperature wheel bearing grease. Pack hub and hub cap with the recommended wheel bearing grease up to shaded portions. Refer to the illustration.
  10. Install the inner bearing and grease seal in the proper position in the hub.
  11. Install the wheel hub with disc brake rotor to the spindle.
  12. Install the outer wheel bearing, lock washer, wheel bearing lock nut, adjusting cap, cotter pin (always use a new cotter pin and O-ring for installation after adjustment), spread cotter pin then install the O-ring and dust cap.
  13. Install the brake caliper assemblies and bleed brakes if necessary. Install the front wheels.
Jun 23, 2009 | 1985 Nissan Stanza
1994 94 Ford Explorer Light Bulb-1994 Ford Logo
Top GE Vehicle Parts & Accessories Experts
ray012965
ray gallant
Are you a GE Vehicle Part and Accessory Expert? Answer questions, earn points and help others
