Question about Farenheit TID-400 Car DVD Player
Factory stereo went out. I pulled fuse out and put it back in fixed the problem. However know it went out again. I can't get it back. I bought a knew fuse but that didn't fix it
I was pulling the fuse under the hood and then putting it back in. It worked for awhile but know I'm not getting anything. I tried a new fuse but it didn't fix the problem.
Factory Bose stereo cut off in my car. I was pulling the fuse out under the hood and when I would put it back in it would work. Know it won't work at all. I bought a new fuse thinking I blew a fuse bu
Some factory radios are designed to shut down if power is removed from them - like when they are stolen. This feature is the anti-theft device for the radio. Most seasoned thieves know it is going to be a hassle to get it turned back on again.
Contact your dealer's service manager and ask how to go about getting the radio turned back on again. Explain it exactly as you did here. You may have to pay to re-activate it - so be prepared.
Apr 22, 2014 | Cars & Trucks
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
Hey, the my tail lights arent working except when I brake. Also, my friend put in a stereo for me but since then the dashboard light hasnt worked, i dont know if this is a blown fuse or a wiring problem ):...
Hi, this is very common. The factory wiring harness has an illumination wire that is not used by the aftermarket stereo. This wire must be taped off to prevent shorting. The fuse is probably burned. Because your car is foreign, I cannot access the wire colors or fuse numbers. The fuse in question is usually labeled "tail". See if you can find and replace that fuse. If it burns again when the lights are turned on, you will have to pull the stereo out and find the illumination wire. Make sure any unused wires are isolated individually with electrical tape.
Aug 05, 2011 | Nissan Pulsar Cars & Trucks
My daughter has a 90 Thunderbird that had an original premium sound package. The stereo went kaput and she bought an after market replacement. I went to install it for her and unfortunately opened up a...
These cars have a factory amp system that will not operate correctly with an aftermarket stereo. You have two choices. You can either run new wires to the speakers your self which would bypass the factory amp. Or you can order the premium sound system Interface here http://www.myinstallkit.com/FORD/1990%20(90)%20FORD%20THUNDERBIRD%20Radio%20-%20Stereo%20Installation%20Kit.htm scroll about half way down the page.
Jan 25, 2011 | 1990 Ford Thunderbird
Changed my factory stereo with an after market stereo and now truck wont start what do i need to do or what didnt i di its a 1998 ford ranger xlt
put back the factory stereo if the car works then you have a model that depends on that head unite you will need to use a factory stereo by pass harness to solve this problem when you install you after market unite.this is a common issue with newer factory stereo's if putting back your factory stereo does not fix this then check all your fuse's generly there are more then one fuse box in newer cars
Mar 18, 2010 | Car Audio & Video
Interior stereo light
Take a Flashlight and hold it Behind the Fuses to make them Easier to See. This way you can check them all and Replace the Bad Ones. If it is not a Fuse, The Backlighting on the Stereo is Probably out and there is no way to fix this once they stop Working aside of Buying a New Head Unit or Aftermarket Stereo. Please Rate My Response! Thanks!
Feb 01, 2009 | 2000 Mitsubishi Mirage
Carolla stereo wont turn on..
Have you checked the fuse? Looks like ther is no power coming to the radio so best bet it's the fuse.
Cheers.
Nov 09, 2008 | 2004 Toyota Corolla
Sporatic problem with Stereo and Stereo Display
I have had this problem intermittently since I purchased the vehicle in 2004... the dealer could not fix but showed me that there is a relay that you can pull and re-install. It's under the hood and must be done with the ignition and lights off. Pull the relay, wait 10 secs and re-install and pblm goes away. If you are standing in front of the vehicle there is a relay box on your right/vehicle left. The relay is located in the lower left-had corner of this box. Not a permanent fix, and in my experience the problem goes away when the vehicle is parked for an hour or so but if you have a long drive and want to use the radio, this 60-second fix is worth knowing...
Oct 25, 2008 | 2004 Dodge Durango
Farenheit TID-400 Car DVD Player Logo
Top Farenheit Car Audio & Video Experts
Martin Clarke
Martin Clarke
afairman1927
Are you a Farenheit Car Audio and Video Expert? Answer questions, earn points and help others
