Question about Kenmore Sewing Machines
The needle thread guide and bracket came off my needle shaft, how does it go back together? Kenmore 38511607
    Novelist:
  • 268 Answers
Mimito7
  • 128 Answers
SOURCE: howto thread a twin needle on Janome 6019
Hi there. If you have an acessory kit with your machine, there should be a plain spindle with a smaller bottom on it. There should also be a small hole on the top or back of your machine where your thread goes.. And yes you can thread both strands of thread thru the same areas till the needle.
Posted on Apr 28, 2009
  • 492 Answers
SOURCE: Problem: The needle threader does not line up with needle eye
Tr
Machines Support
For questions regarding Machine Support, fill out the Machines Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 774.
Technical Support
For questions regarding Technical Support, installing, updating, or using your embroidery software, fill out the Software Support Form or call anytime, Monday through Friday 8:30AM – 5:00PM EST, 1-800-631-0183, ext. 775.
General Inquiries
For general questions, please use the General Inquiries Form.
Request a Machine BrochureFill out the Brochure Request Form to request a brochure for your choice of machine.
Janome Mailing List
Click here to join the Janome Mailing List.
y this:
Posted on Apr 30, 2009
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
Zenqi
  • 208 Answers
SOURCE: which way to put the needle in the Juki, The
The indent is called the scarf.
The scarf will be at the 3 o'clock position and, if you look closely, you will see the hook pass the needle at the scarf.
Posted on Oct 01, 2009
  • 3 Answers
SOURCE: I just got a new
Do you have the bobbin thread going the right way, according to owners manual some go clock wise some go counter clock wise when you pull the thread after bobbin inserted in bobbin case
Posted on Dec 27, 2010
1250 embroidery machine how do you thread for a double needle?
Do you mean the Brother Innov-is 1250D embroidery machine? Insert your twin needle. Follow the normal directions for threading the upper thread and manually place this thread through the eye of the left-hand needle from front to back. For the right hand needle, insert the extra spool pin in the bobbin winder shaft. It gets put on perpendicular to the shaft. Swing down the spool pin so that it is horizontal, pointing towards the needle bar. Place another spool of thread on this spool pin and secure it with the appropriate-sized spool cap. The thread should come off the top front of the spool. Follow the threading directions for the upper thread from step 8 (the thread guide cover) through step 10. Do not run this second thread through the needle bar thread guide. Manually thread the right hand needle eye. Make sure to use the zig-zag foot with the twin needle.
The directions for threading the machine when the twin needle installed is on page 36-37 (pages 38-39 of the PDF) of the manual. The manual is available from Brother support on the product page: http://www.brother-usa.com/support/modelinfo.aspx?R3ModelID=NV1250D . The direct link to the manual is currently: http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_Innov_%c3%ads%201250D_EN_2825.PDF .
I hope this helps.
Apr 09, 2018 | Sewing Machines
I have a singer futura XL580 and the thread guide either flew off or broke off. I thought I bought the right replacement part no. 086046 but can not seem to figure it out
That is because the thread guide is underneath the needle clamp, and BOTH must be removed and replaced together as a unit. In addition, the wire is held by a tiny screw in the back of the shaft. That screw also serves as the stop for the end of the needle. Take a look at the shaft right above the needle, and you'll see what looks like a grey bar--that is the screw. It's difficult to access on the back, but must be loosened first -- JUST ONE OR TWO TURNS -- to remove the wire. Then, take off the needle clamp and wire as one unit.
Insert the replacement guide inside and at the back of the needle clamp, with the hook part sticking out of the clamp. You'll see that there's an indentation in the clamp to hold it. Insert the guide and clamp as one unit, then hook the wire around the screw and tighten.
FYI - If you accidentally remove the screw (which only turns about three or four times) and drop it as I did, you don't really need it to hold the wire guide, BUT you still need a needle stop. I just inserted a toothpick when I changed needles until I could get a replacement.
The above sounds relatively easy, but you'll probably have to do some manipulating, especially the first time, and if you're like me, possibly some cussing -- but it WILL fit.
Dec 31, 2016 | Singer Sewing Machines
How do I thread a kenmore sewing machine model #117812
For the top thread, make sure that the needle is fully up. With the spool on the spool pin. Bring the thread in front and under the first hook and then under and behind hook two. Bring the thread down and under the third point below the spring eyelet. Bring the thread up until hooks into that spring eyelet. Continue up and get the thread into the hole in the take-lever from back to front. Bring the thread down to the needle clamp thread guide and hook it into the guide. Finally pass the thread through the needle from left to right.
The manual for the 117.812 is the same as that for the 117.552. Manuals Lib has this manual here: https://www.manualslib.com/manual/1050640/Kenmore-117-552.html . The threading diagram and instructions are on page 4, https://www.manualslib.com/manual/1050640/Kenmore-117-552.html?page=4#manual . See the later pages for winding and setting up the bobbin. The pictures may help more than the verbal description.
I hope this helps.
Nov 04, 2016 | Kenmore Sewing Machines
How do I thread the bobbin in a Kenmore 14 stitch machine
Does the top of the machine lift up ? if so, there may be a diagram under there. And you can get a manual from Sears too, which will have the directions in it. But it's not hard to thread, has a very basic threading system. Put thread on spool holder, with thread coming out from the front of the spool. Pull out a foot or so of thread, slip it into the guide at rear of machine, where the two main sections appear to join together, right at the top of the machine. Then pull thread forward from the guide, across the top of the machine. There may be a guide at the front edge of the machine top, if so, slip thread into that guide. It's been awhile so I can't recall if there is or isn't a front guide at the top. But then you go down the front of the machine, where you slip thread underneath the bottom of the section with the two vertical slots. Lift thread upward and gently over to the left 'til it catches in the hook. You can move the handwheel to move the hook if need be, it can be hard to catch if it's right at the top of it's travel. Once thread is in the hook, take the thread down to toward the needle. There's a little guide slot above the needle that you slip the thread into, just a simple wire hook mounted sideways. Slip thread into it from the open, left side, toward the right 'til it's caught, then pull down to thread needle, from the front to the back.
Oct 09, 2014 | Sewing Machines
I need help on how to thread machine model 117-812 kenmore sewing machine
Thread, thread guide, thead guide, tension, take up lever, thread guide, thread guide, needle.
Aug 24, 2013 | Kenmore 15208 Mechanical Sewing Machine
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
Top thread goes for awhile and then breaks. Alsoo
Try a fresh needle and be sure the flat side of the needle shaft is facing the back of the machine.
Thread the machine with the presser foot in the up position.
Make sure the bobbin is inserted into the case so the thread is feeding from the bobbin spool in the correct direction and through the proper guides.
Hold onto the thread end at the needle and hand-walk the needle down into the needle plate and back up, bringing the bobbin thread with it.
Take both thread ends under the presser foot and to the back of the machine.
Feb 25, 2010 | Singer 8280 Mechanical Sewing Machine
Sears Kenmore 1168280 (Old machine not used much)
Untangle any mess under and around the needleplate very gingerly trimming threads as you go if necessary....remove and clear.
Undo the needle clamp and remove the remains of the needle.
Open the door for the bobbin and bobbin case and undo the clips holding the hook in place......don't force anything, just ease any tangle loose slowly.
You may want to take a photo of how it goes back together if unfamiliar, or lay the bits out sensibly, so you can replace easily later.
Inside the bobbin/hook area is the most likely region for thread jamming the motion of everything, so make sure all is clear and clean, then.......
Without replacing the bobbin or hook, test the handwheel after cleaning before re-assembly.
You may also want to check the take-up crank for thread jams........the small arm in the top cover that moves up/down to "take-up" the top thread has a cam attached to the top shaft and often tangles thread around the shaft, open the L side cover to access.......remove thread by unwinding handwheel manually ....again be patient and careful not to break threads.
Best Wishes
bargainbox.com.au
Jun 08, 2008 | Necchi 4575 Mechanical Sewing Machine
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
How do I thread it
Follow the thread from the spool through the first thread guide at #1 straight down to #2 and up to #3 (make sure that the thread is through the take-up lever (silver hook) at #3 from three you will bring the thread straight down to the thread guide that is to the left of the needle. Thread the needle from front to back.
Mar 11, 2008 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
