Question about Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit
Error c970 cuts on won't let me print error code c970 i printed 1000 copies turned it off next day turned it back on then an error code c970
    Habit-Forming:
  • 159 Answers
1. Check and clean the main charger, replace if required.
2. Check and clean the transfer/sep. unit, replace if required.
3. Before you replace the HVT board, check HVT connector bracket (the black color plastic piece mounted on the machine frame where the main charger connects). If this part is damaged or cracked, the high voltage will arc through this, which can cause C970. (found in several machines).
Posted on May 03, 2017
I have Toshiba e-studio 257 and have an error code C970 on the screen. Can you help me?
C3D2 EPU board memory old parts detection error: The EPU board cannot detect the new process unit when the equipment is started in the EPU replacement mode ([7] + [START]). C410 Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON. C430 Thermistor abnormality after abnormality judgment: Abnormality of the thermistor is detected after a specified period of time has passed from power-ON (including ready state). C440 Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range. C450 Thermistor abnormality during printing: Abnormality of the thermistor is detected during printing. C4C0 Fuser unit new/old detection fuse abnormality C550 RADF I/F error: Communication error has occurred between the RADF and the scanner. C551 Document feeder model detection error: An optional document feeder that is not compatible to this equipment is installed. C570 Communication error between Engine-CPU and IPC board C580 Communication error between IPC board and finisher C5A0 EEPROM communication abnormality (LGC board) C8E0 ADF communication abnormality: The system has to be stopped because the control abnormality occurred C940 Engine-CPU abnormality C970 High-voltage transformer abnormality: Leakage of the main charger is detected. CA10 Polygonal motor abnormality: The polygonal motor is not rotating normally.
These are the error cods list. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 08, 2016 | Toshiba Office Equipment & Supplies
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
I have error light on. Computer won't print. I just bought the printer and it printed just fine twice. Then I turned off the power when I did not use it. When I tried to print again. the error light is...
The error light that is blinking is actually blinking out a error code. In the back of your manual under troubleshooting there should be a list.
On a printer this new about the only error you should see is a paper jam. IF anything else is wrong I'd just put it in the box and take it back. Rarely do you see something fail this new these days. It happens but not that much.
Once you look up the error code you will know what the problem is. It could be a cable unplugged or a paper jam etc. I can;t see it being serious.
Sep 11, 2011 | Brother HL-2040 Laser Printer
HP 1000 Laser Jet Printer - error printing
Turn the printer off and then back on. Does it go to the ready state? or does it come up and error? If the error only comes up when asking the printer to print then the printer probably has a worn paper pickup roller. You can take the old roller out and rotate the rubber tyre a little.
Mar 26, 2009 | HP LaserJet 1000 Printer
I have a Ink System Failure.
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Dec 20, 2008 | HP Photosmart C5180 All-In-One InkJet...
Sensor error in the Epson stylus pro 9800
sounds like you need a new sensor. call tech support
Dec 10, 2008 | Epson Stylus Pro 9800 InkJet Printer
Epson stylus R 310 "general error" message
Those generic refills are not worth i, plus they may void the warranty. Try removing them and cleaning the little circuit board sensor. Make sure leaked ink hasnt covered them.
Oct 22, 2007 | Epson Stylus 1000 InkJet Printer
Toshiba E Studio 3520c 3530c 4520c Copier Drum Kit Logo
137 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
