Question about Golds Gym Trainer 410 Treadmill
Belt problem my treadmill turns on but my belt will not run. i can choose my exercise routine and everything but my belt will not move!
How do I re-calibrate NordicTrack treadmill T9si when distance displayed is too low?
1) Please use electronic spray for electronic and LUBE the small POT in the electronic Board.
2) Adjust the Speed sensor, and test it, and see is ok or faulty, clean it and ajust 1mms near of magnet. otherwise replace it.
Blessing
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Eletric treadmill Speed Sensor Adjustment
Nov 19, 2017 | NordicTrack Exercise & Fitness
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
The running belt keep moving to the left.
You have to adjust the tracking of running belt. Check the bellow added link and choose treadmill articles . All the treadmills have the through the same routine to adjust the tracking of the belt.
http://electro-medical.blogspot.com/
Jun 20, 2016 | Exercise & Fitness
Acd3 treadmill belt wont move
hi There.
A treadmill belt can shift to the right or left over time. If it shifts enough, this may cause the belt to stop moving. Stand at the back end of your machine and inspect the belt. If it has shifted, you will need to center it by turning the rear roller adjustment bolts. These bolts adjust both the tension and the centering of the belt. Follow the instructions in your owner's manual that explain which of the two bolts you need to tighten or loosen to shift the belt back to the center.
If the belt is too tight, it could cause enough tension that the motor can't turn the belt. This is most likely the cause of your belt not moving if you recently adjusted the belt tension due to slippage. Lift the edge of the belt. If you can't raise it at least 2 to 3 inches off the walking deck, the belt is too tight. Follow the directions in your owner's manual for loosening the belt. You will need an Allen wrench to loosen the rear roller adjustment bolts.
If the troubleshooting does not get the belt running again, you may have a tight motor belt or a bad motor. You will need to remove the motor hood to access these parts of your machine. If your treadmill is still under warranty, contact the manufacturer for a professional repair. You may void the warranty if you attempt to work on the motor yourself.
or read up some more at this link.
How to Fix Treadmill Belt That Won Move
or this one.
Acd3 treadmill belt wont move Google Search
Dec 16, 2017 | Exercise & Fitness
Possessed Treadmill!
Your problem is your motor controller is blown out. This happens when you don't replace your walking belt routinely. You'll need a new belt and a new controller. Depending on the model of treadmill you have the parts could range between $250-$400.
Jun 11, 2017 | Proform Treadmill with iFit Live
We had the lift frame crack on our Nordic Track A2550 after very limited use (but 1mo. after warranty). We replaced it in February and after 500 additional miles, the lift frame has cracked again. I...
General Construction
  • The most basic breakdown of a treadmill: a continuously moving belt powered by a motor over a deck that is mounted on a sturdy metal frame. The variables are the size of the belt, the power of the motor, the thickness and composition of the platform as well as the range of options that increase both function and cost of the treadmill. Making the right choices on all these permutations will add to the enjoyment and benefits of using your treadmill.
Frame Composition
  • Frames are generally made from aluminum or steel. Even if there's no difference in the tensile strength in the frames, steel is better because it will produce a heavier treadmill. That increases the machine's stability and lessens the vibrations generated by your exercise, especially running. Frames can be either bolted or welded together. Welded frames are stronger, and there is no risk of a bolt working loose during long periods of operating the treadmill.
Motor Size
  • Most treadmills have two electric motors. One raises and lowers the deck, allowing you to get a versatile workout. The more important motor is the one that moves the exercise belt under your feet. The drive motor turns a flywheel that is connected by a belt---similar to the belts for the engine of your car---to the front roller. The front roller pushes the exercise belt to the back of the treadmill where a free-moving rear roller serves as the exercise belt's turnaround point. Check for the continuous horsepower (CHP) and revolution per minute (RPM) rating on the motor. In fact, lift the motor cover and look for the ratings stamped directly on the motor. A motor that needs high RPMs (more than 5,000) to generate enough torque to drive the exercise belt is a candidate for overheating and is unlikely to last long. If your plan is only to walk---not run---on your treadmill, a 1.5-horsepower motor with less than 5,000 RPMs will suffice. But if you weigh more than 200 lbs. or you plan to run on your treadmill, you will need at least a 2-horsepower motor with an RPM rating of 4,000 or, preferably, less. Choosing one with 2.5 horsepower or more will be even better if you plan to run for long workouts. When in doubt, go up in horsepower. The motor not only moves the belt but it must overcome the resistance you provide with each stride. Smaller motors with high RPM ratings will allow the belt to hesitate slightly. In addition, you likely will be moving more slowly than the speed displayed on the treadmill's console if you are trying to run. Larger motors might be noisier, so look for a motor housing that absorbs some of the machine noise when the treadmill is in operation.
Belt Size
  • Your workout plans also will dictate what size belt and rollers you need. The treadmill's exercise belt will be made of a thin, multiply polyester/fabric mix with a PVC top coat, which produces the best combination for reducing friction and the heat it generates. This will extend the life of the belt and prevent slipping while you're in motion. Although the surface will be smooth against the deck, the PVC coating will be waffled underneath your feet for better traction. Even if you have short legs and you only plan to walk on the treadmill, you should get a belt at least 18 inches wide and 48 inches long. If you plan to run, a 20-inch belt width is better and 22 inches is best, and you shouldn't choose anything less than 54 inches in length. Longer---up to 60 inches---is better, especially for tall runners. The treadmill will run more smoothly with bigger rollers because the rollers will have more grip surface for the belt as it is propelled over the deck. If you plan to run on your treadmill, rollers with 2-inch diameter are the minimum. Some high-end treadmills come with 3.5-inch rollers. Larger rollers also result in less stress on the bearings; a 3.5-inch roller will need to rotate roughly 60 percent less than a 2-inch roller to cover the same distance.
Platform Surface
  • Treadmill decks are made of wood or, more specifically, composite wood substitutes, either particle board or medium density fiberboard (MDF). For runners, an MDF deck at least 1-inch thick is the minimum. A 3/4-inch surface might be OK for walking, but it will be too bouncy for running and will crack more easily. The deck surface will have a laminate coating---preferably on both sides---to allow the exercise belt to slide smoothly. Treadmills commonly have rubber grommets built into the frame to provide cushioning as you exercise. Some treadmills have shock absorption only in the front (landing area) so that you have a firmer push-off for your next stride. With the built-in shock absorption and the smooth surface, a workout on a treadmill is likely to be less stressful on your joints than running outdoors, unless you have access to a perfectly level wood-chip path.
Speed and Incline
  • Most treadmills now come equipped with easy-to-reach controls that allow you to change the belt speed and the incline of the deck while the belt is in motion. The lift motor generally uses a hydraulic lift to raise and lower the treadmill on its front legs. The elevation motor should have a thrust value of at least 400---more for runners---so the deck can be shoved up without any hesitation during exercise. Some treadmills use gears for elevation. That's neither as smooth nor as reliable as hydraulic lifts. The speed of the belt is controlled from the console of the treadmill. As you raise your speed by 1/10 mile per hour, the motor subtly increases the power it is generating to the rollers, much as a hair dryer does less subtly as you click from medium to high. For runners, look for a treadmill that provides a speed of at least 12 miles per hour and allows an elevation of at least 10 percent. That will give you the opportunity to include some speed work and hill training in your workouts.
More Features
  • Some treadmills come equipped with iPod ports, built-in TVs, drink holders, cooling fans, computer-generated workouts and heart-rate monitors. The computer workouts will build in elevation-change programs, and you can punch in the starting speed of your workout and change it manually. Treadmills also allow you to create programs in which you can choose both the speed and elevation changes. Heart-rate monitors calculate your heart beats per minute and can be operated continuously using chest or arm bands or intermittently using a finger clip or by gripping a sensor on the front rail with one hand. But none of these features outweighs the importance of choosing the right belt and motor for your workout.
Safety
  • Make sure the treadmill has a safety release---usually a magnetic key---so you can stop the exercise belt dead in the event of an injury or other emergency. The treadmill is wired so that the key must be in place on or near the console to complete the electronic circuit and allow the machine to operate. Yet the key can easily be yanked free, immediately stopping the drive motor and putting the brakes on the exercise belt.
Sep 21, 2011 | Nordic Track NordicTrack Treadmill, A2550
Reebok i run treadmill stops working after 10 mins
If everything still works but no belt movement, you motor controller is more than likely shot. If replacing you want to also pay attention to the deck and belt. Sence it sut down while running, it sound it an over heating problem which is usually caused from too much friction between the walking belt and the deck(the board under it) May require lube or may need replacing.
May 28, 2009 | Reebok Vista Treadmill - RBTL13305
Proform 10.5 QM treadmill
Your problem is the motor controller. It usually burns out sometime after the 8 year mark if you don't replace the belt routinely. You'd have to replace the belt and the controller. Parts for that would be about $300.
Jun 11, 2017 | Exercise & Fitness
Golds Gym Trainer 410 Treadmill Logo
44 people viewed this question
Top Golds Gym Exercise & Fitness Experts
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Propulsive
Level 1 Expert
Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
