Question about PfaFF Sewing Machines
Pfaff varimatic 6091 how to replace side cover
Varimatic 6091
5 Suggested Answers
  • 255 Answers
SOURCE: pfaff varimatic 6091 sew a rag quilt with jean and
Hi! The bobbin tension rarely needs to be adjusted. First, make sure you're using the appropriate size needle and thread for your fabric (I'd probably use either a 'denim' needle or a universal size 14) and also that the upper thread and bobbin are threaded absolutely correctly. These can throw off the tension! Also, take the time to clean out the bobbin area. That can throw your stitch off also.
If the stitch on the bottom is loose, so that you see the top threads, then the top tension is too loose. If the top stitch is too loose and you see the bobbin threads on top, then the top tension is too tight.
It helps to thread the machine with different color thread on top and in the bobbin, and then stitch an inch or so on the same type of fabric as you're using in your quilt. Check the stitch. If you need to adjust the top tension, make sure the pressure foot is down! Adjust a little, stitch a few inches, and check again. Repeat until you don't see any (or very little) bobbin thread on the top or top thread on the bottom.
If you go through all these steps, and the bobbin thread is still loose (and you've tightened up the top tension), then there is a tiny little screw on the side of the bobbin case that you can use to adjust the bobbin tension. Turn the screw just a little bit (less than a quarter turn), stitch, check, etc. Once the bobbin tension is set, you shouldn't ever have to change it.
Let me know if this helps, ok?
Happy sewing!
Posted on Feb 10, 2010
SOURCE: How do I open the
On the top of the head there is a rectangular opening (about 1/4 inch x 1/2 inch). If you look in there with a flash light, you will see a screw with a star head. If you loosen this screw (don't take it out just loosen it) the head will come right off. The slot screw driver that came with my machine actually fits right in there and works great.
Posted on Dec 04, 2010
  • 517 Answers
SOURCE: pressor foot will not completely
Good day to you!!!
I am suggesting you to put an oil to that pressor foot and also all parts which you think need to be oiled so that it become soft and easy to use..
If this suggestion does not help please have a comment so that we can make another steps/solution to it...
Thank you and please do not forget to testify and rate me when it helps you...
Good luck...
Posted on Jul 15, 2011
SOURCE: How do you thread a Pfaff Varimatic 6091 sewing has free threading diagrams
Posted on Aug 29, 2011
Hi, I have a Pfaff Varimatic 6091. I sewed some 'too thick' fabric, and it has 'broken' my top tension unit. i.e. I can no longer set it at all, and when sewing the thread is all loopy.
If the upper tension unit is in fact broken, you will need to take it for service or find a replacement part.
This may be a shot--remove the upper thread, ALWAYS RAISE the presser foot, rethread from the beginning. Re-try your machine.
Apr 22, 2017 | PfaFF Sewing Machines
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
Apr 07, 2017 | PfaFF Sewing Machines
How do I remove a bob in case from a Pfaff 6091
Perhaps the manual would be helpful:
PFAFF 6091 Manuals (page 8)
Sep 26, 2016 | PfaFF Sewing Machines
Pfaff varimatic 6091 What type of walking foot can i purchase for this model and are they very expensive ?
You could probably get away with a generic walking foot. They are available in the fabric store for a little under $20. Once you use one, you will wonder how you got by without it before!! I've attached a sample of a product that would work for you. Just be sure to NOT get the "slant" walking foot. That is for the Singer machine, and they have a different setup. Enjoy!!
Amazon com Distinctive Even Feed Walking Sewing Machine Presser Foot...
Mar 10, 2014 | Sewing Machines
Model 6091. I can't get the presser foot to go completely down and rest on the fabric. Can you help?
This is a comon problem with the pfaff 7570. The spring that applys the presser to the foot is all gumed up and needs to be removed cleaned and lubricated. I dont know if you want to try this yourself. You will need to remove the top and side covers and upper tension unit. Can be tricky. A pfaff repair shop should charge around $30. I will go over the steps if you want, let me know. But like i said i can be tricky.
Mar 24, 2011 | PfaFF Creative 7570
How do I open the left side cover of my Pfaff 6091? The thread is stuck/twisted around something inside that compartment and I don't know how to access that area. Thanks!
Aug 22, 2010 | PfaFF Creative 7570
Have a model 6091 Pfaff. The sewing foot will not lower complete
I had this same problem. On the bottom of the head there is a slide switch. Lay your machine on its back and you can easily see it. Slide it back and your problem should be solved.
Mar 29, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
105 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
