Question about NEC DTU 8D-2 Corded Phone
I cant figure out how to get the ringer to turn on
I am a new receptionist and cannot figure out how to turn the ringer on so I don't miss my phone calls. Help???
4 Suggested Answers
  • 43 Answers
SOURCE: trying to change night ringer voicemail
Ok. You will have to find someone who has access to system manager, or has system manager rights for their mailbox.
They will then be able to select System Manager Options, then Change the Greetings. It will tell you which mode you are in, and ask you if you want to change to Holiday Mode. The responses are 1 for YES and 2 for NO. Say no to Holiday Mode, and then it will go thru Day Mode and then Night Mode, playing each one first then asking if you want to change it.
If you must call in a service order with your phone system vendor, make sure he/she not only assigns someone's box with manager access, but also creates a back-door box with manager access. This way you won't be messing with the original Manager Box. It gets expensive having NEC decipher the Manager's password if it gets changed and no one remembers it.
Posted on May 10, 2008
  • 63 Answers
SOURCE: Turn the ringer on for external calls.
in system programming
Posted on Mar 14, 2009
  • 825 Answers
SOURCE: NEC Dterm80 phone, Model DTH-16D-2.
You can change these settings by logging into the phone's ip address from the computer that is connected to the same network.
You can also try to enter into the menu of the phone directly from the interface and look for these settings..
Posted on Apr 22, 2011
We have 4 RCA 25425 phones in our office. When someone calls, all phones ring. We only want main line to ring.
Page 15 of the manual shows how to turn individual phone ringers off using the "Ringer tone" setting option. RCA 25425RE1 User Manual Page 15 Hope this helps
Jan 10, 2014 | RCA 25425 / 25425RE1 4 Line Corded...
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
NEC Dterm80 phone, Model DTH-16D-2. We have an Extension that rings as a back-up to the main attendent/receptionist in the event she cannot answer an incoming call. I need to disable the incoming ring at...
Hi if you just want to silence the actual unit, most often you will find a small switch on the unit, that switches OFF the ringer, or often one can turn it down, via a control on the unit. Other times one can set it Off or down in volume via the settings, use the manual in these case to ascertain what to do.
www.southwesterntel.com/.../ITH-IP%20Installation%20Manual.pdf -
Above is a manual so you can check exactly what and how to do what you want.
If this cannot be done, then take the phones case OFF, locate the "Ringer" and disconnect it from the board, problem solved.
Apr 19, 2011 | NEC Dterm DTP 16D-1 Corded Phone
My son turned off the ringer on our uniden portable phne and I cant figure out how to turn it back on. Chris
Pick up the handset and underneath the handset is an off on switch for the ringer
Handset ringer switch
This switch turns the handset
ringer on or off.
Page 20 of the manual
EXAI985HS English 2,578 kB Product Details
Apr 17, 2009 | Uniden Cordless Phone EXAI985
Doesn't ring loud enough.
Simple, when the phone is ringing, knock up the volume button. The ringer will get louder.
Feb 10, 2009 | Panasonic VB-43223 Corded Phone
Need to set ringer on phone to ring in my office
is because the ringging assignment only set to ring at receptionist phone.
u may need contact the phone provider to set the ringging assignment to other for other phone which to ring for incoming call
Jan 14, 2009 | Toshiba DKT-2010 Corded Phone
Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
Nov 19, 2008 | Panasonic KX-TD7896 Cordless Phone
I have 6 Toshiba DKT2010SD Phone system
What Toshiba system do you guys have? On all 3 issues you will need to login to phone system and reprogram buttons on phones to ring or not to ring.
Nov 12, 2008 | Toshiba DKT2010SD Phone
Why is my phone ringing?
Your Handset has been programmed i guess by mistake to be in the same ring group as the main receptionist for C0-01 . Use Google for programming manual to make changes.
www.heymot.co.uk
Oct 17, 2008 | Panasonic KX-T7633 Corded Phone
NEC DTU 8D-2 Corded Phone Logo
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
SC Spike
Level 1 Expert
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
