Question about Husqvarna Sewing Machines
Balls up thread in bobbin compartment
980 machine bobbin compartment fills up with thread
    New Friend:
    Problem Solver:
  • 19 Answers
Rethread the machine, change the needle and make sure the bobbin is wound properly.
Posted on Feb 08, 2015
SOURCE: singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Posted on Aug 23, 2008
  • 323 Answers
SOURCE: bobbin thread jam
You can remove the thread jam by moving the hand wheel back and forth. Remove the bobbin case and bobbin.Unthread and remove the needle.Rock the handwheel back and forth. Don't be rough but you will need to exert a little pressure to get this thread to come out. What you are doing is cutting the thread which is locked inside the hook race.
sewman7
Posted on Sep 03, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
  • 3 Answers
SOURCE: Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Posted on Mar 03, 2009
  • 30 Answers
SOURCE: mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Posted on Aug 22, 2009
Tiptronic 2040 won't move forward to sew. Seems to be problem with bobbin? Thread "balls up" at bobbin.
Hello Day Fegely
Thread balling-up in the bobbin area indicates that the upper thread (the one going through the needle) is the one doing the "balling". Check that the upper thread is threaded through all the thread paths ... this specific issue seems to be due to the thread not threaded through the "take up lever" ... that is the 'thingy' that goes up and down really fast as you are sewing.
Happy Stitching
Sewingirl/
Apr 20, 2017 | Sewing Machines
When I try to fill my bobbin the thread gets all balled up on top of the bobbin instead of filling it. What should I do?
Consult your owner's manual. Chances are you may be threading the thread incorrectly. Make sure it is going through the bobbin winder tension guide before going to the bobbin winder mechanism.
If it continues, the bobbin winder may need a height adjustment. I had that issue with a machine that the case surrounding the bobbin mechanism was slightly misaligned. Once it was fixed, the bobbin winder worked perfectly.
Dec 01, 2015 | Sewing Machines
After 2 or 3 stitches needle gets locked with balled thread
Lint and or thread has collected behind or under the bobbin. use a q-tip (cotton) and swipe out and around the bobbin and bobbin case. Use a can of air and blow out and around the bobbin area. Remove the spool thread from the machine and rethread the spool and bobbin thread in machine.
Feb 03, 2014 | Janome Magnolia 7330 Sewing Machine
Bobbin threading
you can check youtube to see if they have a video
or check with husqvarna to see if they have a manual
also
sewingpartsonline.com
sewusa.com
May 29, 2012 | Husqvarna Viking 1
Bobbin thread keeps balling up
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 19, 2011 | Brother BC-1000 Computerized Sewing...
Thread is balling up and not allowing the fabric to move it isn't stitching right
This can be caused by several different things. Check the threading. Un-thread the machine and follow the guidance on the manual and re-thread the machine. The bobbin, if the bobbin thread that coming out of the bobbin case in a wrong direction, could cause this. Re-set the direction. When you pull thread from the bobbin case, bobbin should roll counter clockwise. The needle, if it is not the right size needle for the fabric or the needle is slightly bent, maybe replace the needle and try with different size of needle. Once its balling up, sometimes it's left some thread in the machine under the needle plate around the feed dog, clean them up. Thread tension, different fabric may need to be adjust the thread tension, try to check this one under the manuals/instruction. When ready, check and use a scrap of fabric/remnants!
Aug 02, 2010 | Riccar Sewing Machines
Thread balls up in the bobbin/singer sewing machine, also thread
The balance stitch control on this model is below the stitch patterns; to the far right.
If you need a manual you can download a free one at the Singer Company website.
Mar 12, 2010 | Singer 5050 Mechanical Sewing Machine
Problems with prolectrix sewin machine
you have to make sure the bobbin thread is positioned right in the middle. When the needle comes down (into the bobbin compartment), you can peer into the bobbin compartment and see a loop of thread (coming out of the needle). You want to catch that bobbin (thread) in the loop of thread (that runs from the needle).
Feb 15, 2009 | Sewing Machines
Bobbin thread is balling up in the bobbin case
try taking out the bobbin and turning it around if that dosen't fix it then you need a new bobbin case
Feb 01, 2009 | Sewing Machines
Singer 3962 Thread Catching Under face plate (catching on position finger)
I had a problem with the thread balling up under the face plate, too.
I have a Kenmore 385 16528000. I don't know if with other brands that this will pertain to them, but this was my solution:
I had the needle in the wrong way! The top part of the needle that is inserted into the machine needs to go in with the FLAT SIDE AWAY from you. So I hope that helps somebody!!
Elayna
Jul 13, 2008 | Sewing Machines
Sewing Machines Logo
50 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
